Discuss
Maytag F1 Code Keypad Replacement
 in
About a year ago my Maytag oven had problems with a recurring F1 code which was accompanied by a loud
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Maytag F1 Code Keypad Replacement
  #1 (permalink)
Old 03-02-2011, 05:31 PM
Junior Member
CHG9800AAB is on a distinguished road
Default Maytag F1 Code Keypad Replacement
Model Number: CHG9800AAB   Brand: Maytag   Age: More than 10 years
About a year ago my Maytag oven had problems with a recurring F1 code which was accompanied by a loud beep. It could be reset but came back at various increasing intervals. After some research I reached the conclusion that the problem was the membrane keypad which I replaced at considerable expense. I don't recall if the replacement was purchased on this web site but the one I am using looks identical to the replacement listed (and slightly different than the OEM keypad).
Unfortunately the problem has returned. While I can clear the code by pressing reset it often returns moments later. I have discovered if I clear the code and unplug the ribbon connector it does not return but you have to plug it back in to use the oven functions. When the oven is actually operating the code will not come up, only when it is off. Any thoughts on what causes the failure. The surface does get fairly warm at times though it should be designed to withstand that.
I am reluctant to just buy another expensive keypad ( Part Details - WHIRLPOOL Switch membrane black, part number: AP4101624 ) and would like some suggestions. Alternately the current operation would be improved if I could identify an extension for the ribbon connector associated with this part. The female end is difficult to access.
Any assistance would be appreciated.
JTA
Related Models
Maytag CHG9800AAB RANGE- S/C S/I GAS
Maytag CHG9800AAE RANGE- S/C S/I GAS
Maytag CHG9800BAB RANGE- S/C S/I GAS
Maytag CHG9800BAE RANGE- S/C S/I GAS
Maytag CHG9800BAM RANGE- S/C S/I GAS
Maytag CHG9830BAB RANGE- S/C S/I GAS
Maytag CHG9830BAE RANGE- S/C S/I GAS
Admiral CHGA400BAB RANGE- S/C S/I GAS
Admiral CHGA400BAE RANGE- S/C S/I GAS
Amana CHP105 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP105T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP125 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP125T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP150 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP150T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP170 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP170T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP68 COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Amana CHP68T COMMERCIAL BUNKER FREEZER (COMMERCIAL REFRIGERATION)
Whirlpool CHW8990XW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ1 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900WQ0 COMMERCIAL AUTOMATIC WASHER
Amana CI7.7 FREEZER- CHEST
Amana CI8.8 FREEZER- CHEST
Amana CI8.8-C FREEZER- CHEST
Amana CIC-3 REF - TOP MOUNT
Amana CIC-4H REF - TOP MOUNT
Amana CIC3 MISC / ACCESSORY
Amana CIC4 MISC / ACCESSORY
Amana CIC4H MISC / ACCESSORY
Amana CIC4K MISC / ACCESSORY
Maytag CIKHTM-1 MISC / ACCESSORY
Maytag CIKHTM-1V MISC / ACCESSORY
Amana CIM105 REF - BOTTOM MOUNTS
Amana CIM105L REF - BOTTOM MOUNTS
Amana CIM125 REF - BOTTOM MOUNTS
Amana CIM125L REF - BOTTOM MOUNTS
Amana CIM98 REF - BOTTOM MOUNTS
Amana CIM98L REF - BOTTOM MOUNTS
Amana CIMR-19 REF - SXS/I&W
Amana CIMR-22 REF - SXS/I&W
Hardwick CJ1616A49R RANGE- F/S STD GAS
Hardwick CJ1616W49R RANGE- F/S STD GAS
Hardwick CJ1626A49R RANGE- F/S STD GAS
Hardwick CJ1626W49R RANGE- F/S STD GAS
Thermador CJ302UB
Thermador CJ302US
Thermador CJ302UW
Thermador CJ302ZS
Hardwick CJ7121809RC WALLOVEN- STD GAS
Hardwick CJ7122809RC WALLOVEN- STD GAS
Hardwick CJ7141809RC WALLOVEN- STD GAS
Hardwick CJ7141819DE WALLOVEN- STD GAS
Hardwick CJ7142809RC WALLOVEN- STD GAS
Hardwick CJ9641A590R RANGE- F/S STD GAS
Hardwick CJ9641W590R RANGE- F/S STD GAS
Amana CJW1008.A COMMERCIAL MICROWAVES
Amana CJW1008.B COMMERCIAL MICROWAVES
Amana CJW1008.Z COMMERCIAL MICROWAVES
Amana CJW1040.A COMMERCIAL MICROWAVES
Amana CJW1040.B COMMERCIAL MICROWAVES
Amana CJW1040.Z COMMERCIAL MICROWAVES
Gaggenau CK062-604
Gaggenau CK064-604
Gaggenau CK066-604
Gaggenau CK067-604
Gaggenau CK069-604
Gaggenau CK074-604
Gaggenau CK074-614
Gaggenau CK074-624
Gaggenau CK163-604
Gaggenau CK169-604
Gaggenau CK260-604
Gaggenau CK270-604
Maytag CK277SS-1 MISC / ACCESSORY
Maytag CK277SS-1V MISC / ACCESSORY
Gaggenau CK390-615
Gaggenau CK394-615
Gaggenau CK396-615
Gaggenau CK590-615
Gaggenau CK596-615
Hardwick CKD7121810AC WALLOVEN- CONT CLEAN GAS
Hardwick CKD7122810AC WALLOVEN- STD GAS
Hardwick CKD7221819A WALLOVEN- CONT CLEAN GAS
Hardwick CKD7221819AC WALLOVEN- STD GAS
Hardwick CKD7222810AC WALLOVEN- STD GAS
Hardwick CKD7222819A WALLOVEN- STD GAS
Hardwick CKD7224810AC WALLOVEN- STD GAS
Hardwick CKD7224819A WALLOVEN- STD GAS
Hardwick CKD7241819A WALLOVEN- CONT CLEAN GAS
Hardwick CKD7242819A WALLOVEN- STD GAS
Hardwick CKD7244819A WALLOVEN- STD GAS
Hardwick CKD9512W439R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9516W421R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9517W429R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9521W439R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9521W79R RANGE- F/S STD GAS
Hardwick CKF9621K-560RQ GAS RANGE
Hardwick CKG4612MA539RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4612MW539RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4642MA639RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4642MW639RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG8421MA729RG WALLOVEN-STD DBL OVEN GAS
Hardwick CKG8421MW729RG WALLOVEN-STD DBL OVEN GAS
Hardwick CKG9622W439RGB RANGE-F/S CONT CLEAN GAS
Hardwick CKG9641W589RGC RANGE-F/S CONT CLEAN GAS
Hardwick CKJ9641A580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKJ9641W580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641A580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641A589RGD RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W589RGC RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W589RGD RANGE-F/S CONT CLEAN GAS
Amana CKS3020LL SURFACE UNIT- GAS
Amana CKS3020WW SURFACE UNIT- GAS
Amana CKU-617 RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 05-16-2011, 03:51 PM
Junior Member
Default
anybody have any suggestions?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
F3 Code, Keypad Short Skadman Microwave Repair 0 01-31-2011 04:10 PM
Frigidaire Getting F05 Code KeyPad Membrane? jp6011 Washer Repair 1 10-20-2009 02:29 PM
Keypad / control panel removal & replacement Fireweed Oven Repair (including Ranges and Cooktops) 3 08-26-2009 09:37 PM
HV Board, keypad replacement ericvt.bateman Refrigerator & Freezer Repair 3 07-02-2009 11:41 AM
Next step, Control panel or keypad replacement? tgmeyer Oven Repair (including Ranges and Cooktops) 3 12-01-2008 04:09 AM
