| » thermador c302 oven error code f19 |
The F19 code is for Power board Communication error. First check and make sure you have 240 volts coming to the oven. There is a high limit switch that you will need to check as well. It should read closed or 0 for continuity. Here is a link to the parts diagram page where the switch is located, as well as the part number for you. Hope this helps. Part number: AP2832064
Mid plenum replacement parts for THERMADOR C302U | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Hello MarkE. You need to look for a bad wiring harness on the unit or the main power board or control board is bad. This is a communication issue between the boards on the unit.
__________________
| Display Modes | |
| Error code 21 on Thermador | CAA111 | Oven Repair (including Ranges and Cooktops) | 5 | 10-20-2010 12:59 PM |
| thermador oven error f-64 | appliancesurgeons | Oven Repair (including Ranges and Cooktops) | 0 | 05-06-2010 05:55 PM |
| Thermador Double Oven Error Code | GatorFLHX | Oven Repair (including Ranges and Cooktops) | 0 | 01-12-2010 05:04 PM |
| Thermador oven self clean F2 error code | Vic C | Oven Repair (including Ranges and Cooktops) | 0 | 01-09-2010 10:44 AM |
| Thermador oven F7 error code | cherie40 | Oven Repair (including Ranges and Cooktops) | 0 | 12-28-2009 11:56 AM |
