| » G.E. cooktop |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: jgp328wec1ww Brand: GE Age: 5 - 10 years
When triing to ignite cooktop, igniter sparks but gas takes at least 1 min. to start flowing. Then it works ok. Problem is with all burners. Could this be a bad gas pressure regulator or safety valves.
Hi Jeff
There are a couple things which are very important for the proper ignition: the burner and the igniter have to be clean and dry, the burner head should be placed properly on the burner base. To clean the igniters I would recommend to use a rubbing alcohol and to clean the burner you can use a soft metal brush. Inspect all igniters and if you found the ceramic part of the igniter cracked, replace the igniter. - The part number for the new igniter AP3191250 - Here are the break down diagrams for the GE cook top Model JGP328WEC1WW Good luck. Gene.
__________________
Professional appliance repair services in Orange County, California. |
| Display Modes | |
| GE Mongram Cooktop Fans | Cooktop Crap | Oven Repair (including Ranges and Cooktops) | 0 | 10-01-2007 08:24 AM |
| Thermador Cooktop Help | jojo77 | Oven Repair (including Ranges and Cooktops) | 0 | 09-29-2007 12:04 PM |
| Modular cooktop not working | AzingerChamp | Oven Repair (including Ranges and Cooktops) | 2 | 09-20-2007 02:00 PM |
| Cooktop lite | Stu Mills | Microwave Repair | 0 | 08-24-2007 11:23 AM |
| cooktop igniters | bobertj | Oven Repair (including Ranges and Cooktops) | 5 | 08-17-2007 05:29 PM |
