Discuss
Whirlpool oven - no power, blank display
 in
Oven has had occasional problem since new (3-4 times over two years)where it would suddenly display "PF" and turn off
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Whirlpool oven - no power, blank display
  #1 (permalink)
Old 12-21-2008, 10:16 PM
Junior Member
KingBiscuit is on a distinguished road
Default Whirlpool oven - no power, blank display
Model Number: RBS305PRS00   Brand: Whirlpool   Age: 1 - 5 years
Oven has had occasional problem since new (3-4 times over two years)where it would suddenly display "PF" and turn off in use. Now, the display has gone completely dark and oven appears to have no power. Resetting the breaker has no effect, however leaving the breaker off for several hours then turning back on results in oven working again (temporarily). Oven will "go dark" again, even if not used at all.
What should I check - control board? Thermal fuse?
Any insights appreciated...
-KB
Ads By Google
Related Models
Whirlpool RBS305PRS00 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool RBS305PRS02 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool RBS305PRT00 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool RBS305PRT02 30" BUILT-IN ELECTRIC OVEN SELF CLEAN
Whirlpool RBS305PVB00 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS305PVB02 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS305PVB03 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS305PVB04 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS305PVQ00 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS305PVQ02 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS305PVQ03 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS305PVQ04 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS305PVS00 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS305PVS02 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS305PVS03 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS305PVT00 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS305PVT02 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS305PVT03 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS305PVT04 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS307PDB1 Built-In Oven, Electric
Whirlpool RBS307PDB2 Built-In Oven, Electric
Whirlpool RBS307PDB4 30" ELECTRIC OVEN
Whirlpool RBS307PDQ1 Built-In Oven, Electric
Whirlpool RBS307PDQ2 Built-In Oven, Electric
Whirlpool RBS307PDQ4 30" ELECTRIC OVEN
Whirlpool RBS307PVB00 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS307PVB02 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS307PVB03 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS307PVQ00 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS307PVQ02 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS307PVQ03 30" BUILT-IN ELECTRIC SINGLE OVEN
Whirlpool RBS307PVS00 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS307PVS02 30" BUILT-IN ELECTRIC SINGLE OVEN SELF-CLEAN
Whirlpool RBS307PVS03 30" BUILT-IN ELECTRIC SINGLE OVEN
Frigidaire RBSF117E1 BLACK Frg(v3) / Electric Cooktops and Control Box
Frigidaire RBSF117EL1 Frg(v2) / Electric Cooktops and Control Box
Frigidaire RBSF117EW1 Frg(v1) / Electric Cooktops and Control Box
Frigidaire RBSF129EL0 Frg(v4) / Electric Range
Frigidaire RBSF129EW0 Frg(v3) / Electric Range
Frigidaire RBUGCF95ED Frg(v6) / Wall Oven
Frigidaire RBUGCF95EK Frg(v7) / Wall Oven
Frigidaire RBUGCF95EW Frg(v5) / Wall Oven
Amana RC-10B COMMERCIAL MICROWAVES
Amana RC-10B-DD COMMERCIAL MICROWAVES
Amana RC-10B-PB COMMERCIAL MICROWAVES
Amana RC-10D COMMERCIAL MICROWAVES
Amana RC-10PB COMMERCIAL MICROWAVES
Amana RC-10S COMMERCIAL MICROWAVES
Amana RC-10SD COMMERCIAL MICROWAVES
Amana RC-10SE COMMERCIAL MICROWAVES
Amana RC-14 COMMERCIAL MICROWAVES
Amana RC-14B COMMERCIAL MICROWAVES
Amana RC-14S COMMERCIAL MICROWAVES
Amana RC-14SD COMMERCIAL MICROWAVES
Amana RC-14SE COMMERCIAL MICROWAVES
Amana RC-14T COMMERCIAL MICROWAVES
Amana RC-14TD COMMERCIAL MICROWAVES
Amana RC-14TE COMMERCIAL MICROWAVES
Amana RC-20 COMMERCIAL MICROWAVES
Amana RC-20SE COMMERCIAL MICROWAVES
Amana RC-6D COMMERCIAL MICROWAVES
Amana RC-6PB COMMERCIAL MICROWAVES
Amana RC-7D COMMERCIAL MICROWAVES
Amana RC-7PB COMMERCIAL MICROWAVES
Amana RC-8 COMMERCIAL MICROWAVES
Amana RC04880A1D ROOM AIR CONDITIONER
Amana RC04880A1D REV ROOM AIR CONDITIONER
Amana RC04880A1DR ROOM AIR CONDITIONER
Amana RC04880A1DR REV ROOM AIR CONDITIONER
Amana RC04880A1E ROOM AIR CONDITIONER
Amana RC04880A1X ROOM AIR CONDITIONER
Amana RC04880A1X REV ROOM AIR CONDITIONER
Amana RC04880A1XR ROOM AIR CONDITIONER
Amana RC04880A1XR REV ROOM AIR CONDITIONER
Amana RC05010A1D ROOM AIR CONDITIONER
  #2 (permalink)
Old 12-22-2008, 04:22 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Here is your parts breakdown
Model RBS305PRS00
Here is your tech sheet
https://www.servicematters.com/docs/...%208301758.pdf
I would lean toward the control board being bad,.
Sounds like something on the board is heating up and causing the shutdown.
In the past it only did it intermittently causing your Power Failure error now it has become a full open.
Since I do not have info on exactly what trips the Power Failure error I would try removing and reconnecting the ribbon cable (keyboard to control).
Perhaps cleaning the connectors with isopropyl or electronics cleaner.
Most likely it is a bad solder joint on the control board or a bad winding in the transformer.
__________________
  #3 (permalink)
Old 12-22-2008, 05:10 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Look at #37 on the oven breakdown of your product. It is the thermostat, and it is located in the back of the oven. If you pull the oven out, and take the back off, you will see the thermostat. Make sure the oven breaker is off, and take the 2 wires off the thermostat, and put them together, and put some tape around it, so it does not hit metal, and turn the power on and see if it works. If so DO NOT run it like that, it is for testing reasons only. If it works replace the oven sensor, and the thermostat. If it does not work replace the board.
  #4 (permalink)
Old 12-22-2008, 07:01 AM
Junior Member
Default
Thanks, guys...
Interestingly, the problem recurs wihout the oven being used (not heating up).
Last night I tripped the breaker back on, the oven came back in "PF" mode as expected, I reset the clock, and all was fine. This morning there was a clicking sound, then the display went back to "PF". Oven hasn't been used at all.
-KB
  #5 (permalink)
Old 12-22-2008, 04:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I agree with denman - there is an intermittent power interruption, most likely on the low voltage power supply side for the control board. Possible a micro crack somewhere or a bad winding in the low voltage transformer which breaks as soon as it heats up.
The oven shutdown thermostat, mentioned by Tom, in case if it's blown will interrupt power to the heating elements only.
- The part number for the control board is AP3873711
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #6 (permalink)
Old 12-26-2008, 05:42 PM
Junior Member
Default
Yeah, it's looking like it must be the control board. I got it working again for a few days, then it just went dark again. Heat doesn't seem to be an issue, as it does this when the oven is never even turned on.
Can I get at the control board without pulling the oven out?
Thanks again.
  #7 (permalink)
Old 12-27-2008, 12:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by KingBiscuit View Post
1. ...Heat doesn't seem to be an issue, as it does this when the oven is never even turned on...
2. ....Can I get at the control board without pulling the oven out?...
1. The low voltage transformer is heating up as long as the oven powered up.
2. Yes, you can. Just open the control panel.
__________________
  #8 (permalink)
Old 12-31-2008, 08:31 PM
Junior Member
Default
Thanks guys - replacing the control board did the trick.
-KB
  #9 (permalink)
Old 01-03-2009, 10:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
We are glad you were able to fix it. Happy New Year!
__________________
  #10 (permalink)
Old 01-04-2009, 07:03 AM
Senior Expert
APP Volunteer
Default
Good Job!!! Its a good thing you didn't have to cook christmas, and new years eve dinner!!!! Tom
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool double oven display is blank jrgaytan Oven Repair (including Ranges and Cooktops) 7 01-29-2013 06:46 PM
jenn-air oven display blank but oven works fine elyot450 Oven Repair (including Ranges and Cooktops) 2 07-04-2009 01:44 PM
Display on my oven is blank butch69 Oven Repair (including Ranges and Cooktops) 0 05-18-2009 09:12 PM
The Oven display went blank johnep Oven Repair (including Ranges and Cooktops) 1 12-03-2008 01:20 PM
Oven clock, timer, display is blank. dorannj Oven Repair (including Ranges and Cooktops) 0 09-12-2007 08:17 AM
