Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   surface elements on glass top (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/17876-surface-elements-glass-top.html)
douglo 12-21-2008 10:07 AM
I figured out how to open/lift the glass top. The elements are attached to some type of track/rail- how do I remove the element and replace it?
kayakcrzy 12-22-2008 05:32 AM
Take the screws off to the rail that holds the element in question off, and then replace. Are you sure, the element is bad? Most of the times it is the switch.
