Discuss
Frigidaire Gas Oven Wont Come to Temp
 in
Hi: My gas oven (frigidaire FGF366DCD) is 6 years old. The gas oven works, but we have to use an
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire Gas Oven Wont Come to Temp
  #1 (permalink)
Old 02-23-2011, 06:18 AM
Junior Member
JeffScanlan is on a distinguished road
Default Frigidaire Gas Oven Wont Come to Temp
Model Number: FGF366DCD   Brand: Frigidaire   Age: 5 - 10 years
Hi:
My gas oven (frigidaire FGF366DCD) is 6 years old. The gas oven works, but we have to use an internal thermometer to get to the right temp. For example, if we want to bake at 375 we have set the oven 75 f (or more) higher. So in this case we would set the oven at 450 to heat it to 375.
I am assuming, but wanted to check, that the temp probe needs to be replaced.
Thoughts would be appreciated
Related Models
Frigidaire FGF366DCD Frigidaire/range
Frigidaire FGF366DCE Frigidaire/range
Frigidaire FGF366DCF Frigidaire/range
Frigidaire FGF366DCG Frigidaire/range
Frigidaire FGF366DQA Frigidaire/gas Range
Frigidaire FGF366DQB Frigidaire/range
Frigidaire FGF366DQD Frigidaire/range
Frigidaire FGF366DSA Frigidaire/gas Range
Frigidaire FGF366DSB Frigidaire/range
Frigidaire FGF366DSD Frigidaire/range
Frigidaire FGF366EBA Frigidaire/range
Frigidaire FGF366EBB Frigidaire/range
Frigidaire FGF366EBC Frigidaire/range
Frigidaire FGF366EBD Frigidaire/range
Frigidaire FGF366EBE Frigidaire/range
Frigidaire FGF366EBF GAS RANGE
Frigidaire FGF366EBG GAS RANGE
Frigidaire FGF366EBH GAS RANGE
Frigidaire FGF366ECA Frigidaire/gas Range
Frigidaire FGF366ECB Frigidaire/gas Range
Frigidaire FGF366ECC Frigidaire/range
Frigidaire FGF366ECD Frigidaire/range
Frigidaire FGF366EMB Frigidaire/gas Range
Frigidaire FGF366EMC Frigidaire/range
Frigidaire FGF366EMD Frigidaire/gas Range
Frigidaire FGF366EME Frigidaire/range
Frigidaire FGF366EQA Frigidaire/range
Frigidaire FGF366EQB Frigidaire/range
Frigidaire FGF366EQC Frigidaire/range
Frigidaire FGF366EQD Frigidaire/range
Frigidaire FGF366EQE Frigidaire/range
Frigidaire FGF366ESA Frigidaire/range
Frigidaire FGF366ESB Frigidaire/range
Frigidaire FGF366ESC Frigidaire/range
Frigidaire FGF366ESD Frigidaire/range
Frigidaire FGF366ESE Frigidaire/range
Frigidaire FGF366ESF GAS RANGE
Frigidaire FGF366ESG GAS RANGE
Frigidaire FGF366ESH GAS RANGE
Frigidaire FGF367BGDA Frg(v1) / Gas Range
Frigidaire FGF367BGDB Frg(v1) / Gas Range
Frigidaire FGF367BGDC Frg(v1) / Gas Range
Frigidaire FGF367BGWA Frg(v2) / Gas Range
Frigidaire FGF367BGWB Frg(v2) / Gas Range
Frigidaire FGF367BGWC Frg(v2) / Gas Range
Frigidaire FGF367CGSA Frg(v3) / Gas Range
Frigidaire FGF367CGSB Frg(v3) / Gas Range
Frigidaire FGF367CGSC Frg(v1) / Gas Range
Frigidaire FGF367CGSD Frg(v2) / Gas Range
Frigidaire FGF367CGTC Frg(v3) / Gas Range
Frigidaire FGF367CGTD Frg(v4) / Gas Range
Frigidaire FGF368CJBA Frigidaire/gas Range
Frigidaire FGF368CJBB Frigidaire/gas Range
Frigidaire FGF368CJSA Frigidaire/gas Range
Frigidaire FGF368CJSB Frigidaire/gas Range
Frigidaire FGF368CJTA Frigidaire/gas Range
Frigidaire FGF368CJTB Frigidaire/gas Range
Frigidaire FGF368CXASA Frigidaire/gas Range
Frigidaire FGF368GBA Frigidaire/gas Range
Frigidaire FGF368GBB GAS RANGE
Frigidaire FGF368GBC GAS RANGE
Frigidaire FGF368GBD GAS RANGE
Frigidaire FGF368GBE GAS RANGE
Frigidaire FGF368GBF GAS RANGE
Frigidaire FGF368GBG GAS RANGE
Frigidaire FGF368GBH GAS RANGE
Frigidaire FGF368GBJ GAS RANGE
Frigidaire FGF368GBK GAS RANGE
Frigidaire FGF368GCA GAS RANGE
Frigidaire FGF368GCB GAS RANGE
Frigidaire FGF368GCC GAS RANGE
Frigidaire FGF368GCD GAS RANGE
Frigidaire FGF368GCE GAS RANGE
Frigidaire FGF368GCF GAS RANGE
Frigidaire FGF368GCG GAS RANGE
Frigidaire FGF368GCH GAS RANGE
Frigidaire FGF368GCJ GAS RANGE
Frigidaire FGF368GCK GAS RANGE
Frigidaire FGF368GCM GAS RANGE
Frigidaire FGF368GCN GAS RANGE
Frigidaire FGF368GCP GAS RANGE
Frigidaire FGF368GMA GAS RANGE
Frigidaire FGF368GMB GAS RANGE
Frigidaire FGF368GMC GAS RANGE
Frigidaire FGF368GMD GAS RANGE
Frigidaire FGF368GME GAS RANGE
Frigidaire FGF368GMF GAS RANGE
Frigidaire FGF368GMG GAS RANGE
Frigidaire FGF368GMH GAS RANGE
Frigidaire FGF368GMJ GAS RANGE
Frigidaire FGF368GMK GAS RANGE
Frigidaire FGF368GMN GAS RANGE
Frigidaire FGF368GMP GAS RANGE
Frigidaire FGF368GMR GAS RANGE
Frigidaire FGF368GQA Frigidaire/gas Range
Frigidaire FGF368GQB GAS RANGE
Frigidaire FGF368GQC GAS RANGE
Frigidaire FGF368GQD GAS RANGE
Frigidaire FGF368GQE GAS RANGE
Frigidaire FGF368GQF GAS RANGE
Frigidaire FGF368GQG GAS RANGE
Frigidaire FGF368GQH GAS RANGE
Frigidaire FGF368GQJ GAS RANGE
Frigidaire FGF368GQX GAS RANGE
Frigidaire FGF368GSA Frigidaire/gas Range
Frigidaire FGF368GSB GAS RANGE
Frigidaire FGF368GSC GAS RANGE
Frigidaire FGF368GSD GAS RANGE
Frigidaire FGF368GSE GAS RANGE
Frigidaire FGF368GSF GAS RANGE
Frigidaire FGF368GSG GAS RANGE
Frigidaire FGF368GSH GAS RANGE
Frigidaire FGF368GSJ GAS RANGE
Frigidaire FGF368MXASA Frigidaire/gas Range
Frigidaire FGF374CCBA Frg(v1) / Gas Range
Frigidaire FGF374CCBB Frg(v1) / Gas Range
Frigidaire FGF374CCBC Frg(v1) / Gas Range
Frigidaire FGF374CCBD Frg(v2) / Gas Range
Frigidaire FGF374CCBE Frg(v1) / Gas Range
Frigidaire FGF374CCBF Frg(v1) / Gas Range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven heats up to Temp, but wont light back up to keep at temp Pooler Oven Repair (including Ranges and Cooktops) 1 05-06-2014 07:46 AM
Frigidaire Oven Temp Problems pwshepard Oven Repair (including Ranges and Cooktops) 0 01-01-2011 05:09 PM
GE oven wont heat to temp cuttem Oven Repair (including Ranges and Cooktops) 1 11-09-2010 03:38 PM
Frigidaire oven temp far off actual s_mack Oven Repair (including Ranges and Cooktops) 0 06-10-2010 11:48 PM
Oven wont heat to temp rickm1959 Oven Repair (including Ranges and Cooktops) 1 07-24-2007 03:52 PM
