My oven signals it has preheated when the temperature is 200 degrees below the temperature I have set. Then the bake temperature fluctuates between 20 and 50 degrees or more, but usually on the high side. The temperature sensor inside the oven has been replaced. Is there a way to troubleshoot this problem?
if you replaced sensor,+bake element gets red , then it appears the only part to replace is clock erc
Thank you. I will try replacing the clock erc.
