Discuss
Jenn Air Grill Element
 in
I recently purchased a new element for the grill because one side of the old one did not heat appropriately.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn Air Grill Element
  #1 (permalink)
Old 02-21-2011, 08:55 AM
Junior Member
cardiacpac is on a distinguished road
Default Jenn Air Grill Element
Model Number: CVEX4370   Brand: Jenn-Air   Age: 1 - 5 years
I recently purchased a new element for the grill because one side of the old one did not heat appropriately. I assumed it was going bad. I installed the new one (this is where it gets confusing) and it does not heat correctly. It heats opposite the old one. Also the downdraft fan does not work with the new element in place. It makes a humming noise. If I put the old element in, the fan works fine. Any ideas or suggestions appreciated.
Ads By Google
Related Models
Jenn-Air CVEX4370B Surface Unit - Ddraft Ele
Jenn-Air CVEX4370W Surface Unit - Ddraft Ele
Jenn-Air CVG2420B Surface Base Unit - Ddraft Gas
Jenn-Air CVG2420W Surface Base Unit - Ddraft Gas
Jenn-Air CVG316B Surface Unit - Ddraft Gas
Jenn-Air CVG316W Surface Unit - Ddraft Gas
Jenn-Air CVG4100B Surface Unit - Ddraft Gas
Jenn-Air CVG4280B Surface Unit - Ddraft Gas
Jenn-Air CVG4280S Surface Unit - Ddraft Gas
Jenn-Air CVG4280W Surface Unit - Ddraft Gas
Jenn-Air CVG4380B Surface Unit - Ddraft Gas
Jenn-Air CVG4380P Surface Unit - Ddraft Gas
Jenn-Air CVG4380PD Surface Unit - Ddraft Gas
Jenn-Air CVG4380PF Surface Unit - Ddraft Gas
Jenn-Air CVG4380PG Surface Unit - Ddraft Gas
Jenn-Air CVG4380PK Surface Unit - Ddraft Gas
Jenn-Air CVG4380PR Surface Unit - Ddraft Gas
Jenn-Air CVG4380PU Surface Unit - Ddraft Gas
Jenn-Air CVG4380W Surface Unit - Ddraft Gas
Jenn-Air CVGX2423B Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423Q Surface Base Unit - Ddraft Gas
Jenn-Air CVGX2423W Surface Base Unit - Ddraft Gas
Whirlpool CVR1000
Whirlpool CVR2000
Whirlpool CVR3000
Whirlpool CVR500
Whirlpool CVR600
Whirlpool CVR6001
Thermador CVS30RB
Thermador CVS30RS
Thermador CVS30RW
Thermador CVS36RB
Thermador CVS36RS
Thermador CVS36RW
Thermador CVS45RB
Thermador CVS45RS
Thermador CVS45RW
Thermador CVSE36B
Crosley CW18C1 Washer - Top Loading
Crosley CW18C100 Washer - Top Loading
Crosley CW18C124 Washer - Top Loading
Crosley CW18C125 Washer - Top Loading
Crosley CW18C126 Washer - Top Loading
Crosley CW18C127 Washer - Top Loading
Crosley CW18C1A Washer - Top Loading
Crosley CW18C1H Washer - Top Loading
Crosley CW18C3A Washer - Top Loading
Crosley CW18C3H Washer - Top Loading
Crosley CW18C3W Washer - Top Loading
Crosley CW18M4 Washer - Top Loading
Crosley CW18M4A Washer - Top Loading
Crosley CW18M4H Washer - Top Loading
Crosley CW18M4W Washer - Top Loading
Crosley CW18P2A Washer - Top Loading
Crosley CW18P2AC Washer - Top Loading
Crosley CW18P2H Washer - Top Loading
Crosley CW18P2HC Washer - Top Loading
Crosley CW18P2W Washer - Top Loading
Crosley CW18P2WC Washer - Top Loading
Crosley CW18P6A Washer - Top Loading
Crosley CW18P6H Washer - Top Loading
Crosley CW18P6W Washer - Top Loading
Crosley CW18T2A Washer - Top Loading
Crosley CW18T2W Washer - Top Loading
Crosley CW20C5A Washer - Top Loading
Crosley CW20C5H Washer - Top Loading
Crosley CW20C5W Washer - Top Loading
Crosley CW20C7A Washer - Top Loading
Crosley CW20C7W Washer - Top Loading
Crosley CW20M4A Washer - Top Loading
Crosley CW20M6 Washer - Top Loading
Crosley CW20M6A Washer - Top Loading
Crosley CW20M8 Washer - Top Loading
Crosley CW20M8A Washer - Top Loading
Crosley CW20M8H Washer - Top Loading
Crosley CW20M9A Washer - Top Loading
Crosley CW20M9N Washer - Top Loading
Crosley CW20P4A Washer - Top Loading
Crosley CW20P4H Washer - Top Loading
Crosley CW20P4W Washer - Top Loading
Crosley CW20P5A Washer - Top Loading
Crosley CW20P5AC Washer - Top Loading
Crosley CW20P5H Washer - Top Loading
Crosley CW20P5HC Washer - Top Loading
Crosley CW20P5W Washer - Top Loading
Crosley CW20P5WC Washer - Top Loading
Crosley CW20P6 Washer - Top Loading
Crosley CW20P6A Washer - Top Loading
Crosley CW20P6AC Washer - Top Loading
Crosley CW20P6H Washer - Top Loading
Crosley CW20P6HC Washer - Top Loading
Crosley CW20P6W Washer - Top Loading
Crosley CW20P6WC Washer - Top Loading
Crosley CW20P8 Washer - Top Loading
Crosley CW20P8A Washer - Top Loading
Crosley CW20P8AC Washer - Top Loading
Crosley CW20P8AS Washer - Top Loading
Crosley CW20P8ASC Washer - Top Loading
Crosley CW20P8D Washer - Top Loading
Crosley CW20P8DS Washer - Top Loading
Crosley CW20P8DSC Washer - Top Loading
Crosley CW20P8H Washer - Top Loading
Crosley CW20P8HS Washer - Top Loading
Crosley CW20P8HSC Washer - Top Loading
Crosley CW20P8W Washer - Top Loading
Crosley CW20P8WC Washer - Top Loading
Crosley CW20P8WS Washer - Top Loading
Crosley CW20P8WSC Washer - Top Loading
Crosley CW20T5A Washer - Top Loading
Crosley CW20T5W Washer - Top Loading
Crosley CW20T5WC Washer - Top Loading
Crosley CW20T6A Washer - Top Loading
Crosley CW20T6AC Washer - Top Loading
Crosley CW20T6W Washer - Top Loading
Crosley CW20T6WC Washer - Top Loading
Crosley CW20T7A Washer - Top Loading
Crosley CW20T7V Washer - Top Loading
Crosley CW20T7W Washer - Top Loading
Crosley CW20T8A Washer - Top Loading
Crosley CW20T8AC Washer - Top Loading
  #2 (permalink)
Old 02-21-2011, 09:01 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Is your element one of these?
Part number: AP4283838
Part number: AP4511038
  #3 (permalink)
Old 02-21-2011, 09:05 AM
Junior Member
Default
exactly like that
  #4 (permalink)
Old 02-21-2011, 09:30 AM
Senior Expert
APP Volunteer
Default
Remove the element and test the recepticles on both sides. Tell us what voltages you're getting.
  #5 (permalink)
Old 02-21-2011, 09:43 AM
Junior Member
Default
Sure will. Will repost later when I get home. Thank you.
  #6 (permalink)
Old 02-22-2011, 05:12 AM
Junior Member
Default
I tested the recepticles and the left one was 110V, the right did not read anything. The funny thing is that the right side heats up. I still do not understand why the fan does not run as it use to when turning the grill on. With the old element, the fan will run as it should. I also checked the continuity of the element and it was intact.
  #7 (permalink)
Old 02-22-2011, 06:52 AM
Senior Expert
APP Volunteer
Default
I think you may have a bad switch.
  #8 (permalink)
Old 02-24-2011, 04:53 PM
Junior Member
Default
I replaced the switch. Still not working. Is it possible the fan switch is bad and causing this problem?
  #9 (permalink)
Old 02-25-2011, 06:41 AM
Senior Expert
APP Volunteer
Default
There is a leg of the element receptacle that goes through the fan switch. Here's a link to the wiring diagram. Does the fan also not work?
Wiring information replacement parts for JENN-AIR CVEX4370B SURFACE UNIT- DDRAFT ELE | AppliancePartsPros.com
  #10 (permalink)
Old 02-25-2011, 10:26 AM
Junior Member
Default
The fan only makes a humming noise. Not high speed as it should be.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ceramic Cooktop Grill Element Shunt Fred Sowerby Oven Repair (including Ranges and Cooktops) 0 10-01-2010 11:24 AM
Jenn Air Element Replacement mjterry Oven Repair (including Ranges and Cooktops) 0 06-26-2010 08:22 AM
jenn-air element wiring breonw@bellsouth.net Heating, Ventilation, and Air Conditioning (HVAC) 1 11-20-2009 08:29 AM
GE grill/griddle element replacement oljoe Oven Repair (including Ranges and Cooktops) 1 10-10-2009 07:58 PM
Jenn-Air counter top range/grill switch problems ms03028 Oven Repair (including Ranges and Cooktops) 1 01-09-2009 01:33 PM
