Discuss
Ram stuck down on compactor
 in
Ram stays in down postion, while motor just hums. Removed chain cover and if I turn the large sprocket the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Ram stuck down on compactor
  #1 (permalink)
Old 02-20-2011, 02:05 PM
Junior Member
Russ55 is on a distinguished road
Default Ram stuck down on compactor
Model Number: 655.1350594   Brand: Kenmore   Age: 5 - 10 years
Removed chain cover and if I turn the large sprocket the ram will go back up. Happens on every cycle
Ads By Google
Related Models
Magic Chef 6551WRA Range - S/i Std Ele
Magic Chef 6551WRW Range - S/i Std Ele
Magic Chef 6551WUA Range - S/i Std Ele
Magic Chef 6551WUB Range - S/i Std Ele
Magic Chef 6551WUW Range - S/i Std Ele
Magic Chef 6551XRA Range - S/i Std Ele
Magic Chef 6551XRL
Magic Chef 6551XRS
Magic Chef 6551XRW Range - S/i Std Ele
Magic Chef 6551XUA Range - S/i Std Ele
Magic Chef 6551XUB Range - S/i Std Ele
Magic Chef 6551XUW Range - S/i Std Ele
Admiral 655AH-CVW Range - F/s Std Ele
Admiral 655WH-CVW Range - F/s Std Ele
Admiral 656AH-EHVW Range - F/s Std Ele
Admiral 656HH-EHVW Range - F/s Std Ele
Admiral 656WH-EHVW Range - F/s Std Ele
Maytag 65C Dryer - Gas
Magic Chef 65HA-1 Range - S/i Std Ele
Magic Chef 65HA-3W Range - S/i Std Ele
Magic Chef 65HA-3X Range - S/i Std Ele
Magic Chef 65HN-1 Range - S/i Std Ele
Magic Chef 65HN-3W Range - S/i Std Ele
Magic Chef 65HN-3X Range - S/i Std Ele
Hoover 66
Admiral 663AH-CV Range - S/c F/s Ele
Admiral 663WH-CV Range - S/c F/s Ele
Kenmore 665.1330590  COMPACTOR
Kenmore 665.1336580  TRASH COMPACTOR
Kenmore 665.1336581  TRASH COMPACTOR/
Kenmore 665.1336582  COMPACTOR
Kenmore 665.1338550  TRASH COMPACTOR
Kenmore 665.1338580  TRASH COMPACTOR
Kenmore 665.1338581  TRASH COMPACTOR
Kenmore 665.1338582  COMPACTOR
Kenmore 665.1339580  COMPACTOR
Kenmore 665.1339581  COMPACTOR
Kenmore 665.1340590  COMPACTOR
Kenmore 665.1340591  COMPACTOR
Kenmore 665.1340592  COMPACTOR
Kenmore 665.1340593  COMPACTOR
Kenmore 665.1340594  COMPACTOR
Kenmore 665.1350190  COMPACTOR
Kenmore 665.1350191  COMPACTOR
Kenmore 665.1350192  COMPACTOR
Kenmore 665.1350193  COMPACTOR
Kenmore 665.1350194  COMPACTOR
Kenmore 665.1350195  COMPACTOR
Kenmore 665.1350196  COMPACTOR
Kenmore 665.1350590  COMPACTOR
Kenmore 665.1350591  COMPACTORS
Kenmore 665.1350592  COMPACTOR
Kenmore 665.1350593  COMPACTOR
Kenmore 665.1350594  COMPACTORS
Kenmore 665.1350595  COMPACTOR
Kenmore 665.1350596  COMPACTOR
Kenmore 665.1358550  TRASH COMPACTOR
Kenmore 665.1358551  TRASH COMPACTOR
Kenmore 665.13601790  COMPACTOR
Kenmore 665.13603000  COMPACTORS
Kenmore 665.13604000  COMPACTORS
Kenmore 665.13605790  COMPACTOR
Kenmore 665.13608790  COMPACTOR
Kenmore 665.13612100  COMPACTORS
Kenmore 665.13613100  COMPACTORS
Kenmore 665.13614100  COMPACTORS
Kenmore 665.13619100  COMPACTORS
Kenmore 665.1386580  TRASH COMPACTOR
Kenmore 665.1386581  TRASH COMPACTOR
Kenmore 665.1386582  COMPACTOR
Kenmore 665.1388550  TRASH COMPACTOR
Kenmore 665.1388580  TRASH COMPACTOR
Kenmore 665.1388581  TRASH COMPACTOR
Kenmore 665.1388582  COMPACTOR
Kenmore 665.1396580  TRASH COMPACTOR
Kenmore 665.1396581  TRASH COMPACTOR
Kenmore 665.1396582  COMPACTOR
Kenmore 665.4098450  BUILT-IN OVEN
Kenmore 665.4098451  RANGE - ELEC
Kenmore 665.4098452  BUILT-IN OVEN
Kenmore 665.4098890  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098910  ELEC. BUILT-IN OVEN
Kenmore 665.4098911  BUILT IN-ELEC. OVEN
Kenmore 665.4098912  BUILT-IN OVEN
Kenmore 665.4098913  BUILT-IN OVEN
Kenmore 665.4098914  ELEC. BUILT-IN OVEN
Kenmore 665.4098915  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098990  BUILT IN WALL OVEN
Kenmore 665.4098991  BUILT-IN ELEC. OVEN
Kenmore 665.4098992  BUILT-IN OVEN
Kenmore 665.4098993  BUILT-IN OVEN
Kenmore 665.4098994  ELEC. BUILT-IN OVEN
Kenmore 665.4098995  ELECTRIC BUILT-IN OVEN
Kenmore 665.4098996  RANGE - ELEC
Kenmore 665.4098997  BUILT IN OVEN
Kenmore 665.42500  KENMORE COMPACTOR
Kenmore 665.42501  KENMORE COMPACTOR
Kenmore 665.42550  KENMORE COMPACTOR
Kenmore 665.42551  KENMORE COMPACTOR
Kenmore 665.42600  KENMORE COMPACTOR
Kenmore 665.42601  KENMORE COMPACTOR
Kenmore 665.427303-1  COMPACTOR
Kenmore 665.427303-2  COMPACTOR
Kenmore 665.427303-3  COMPACTOR
Kenmore 665.427303-4  COMPACTOR
Kenmore 665.427303-5  COMPACTOR
Kenmore 665.4428451  RANGE - ELEC
Kenmore 665.4428996  ELECTRIC DOUBLE OVEN BUILT-IN
Kenmore 665.4428997  RANGE - ELEC KENMORE
Kenmore 665.4428998  BUILT IN OVEN
Kenmore 665.4433450  BUILT-IN OVEN AND MICROWAVE
Kenmore 665.4433451  BUILT IN OVEN WITH MICROWAVE OVEN
Kenmore 665.4433452  ELEC BUILT-IN OVEN / MICROWAVE
Kenmore 665.4438890  MICRO/ELECTRIC BUILT-IN OVEN
Kenmore 665.4438913  BUILT-IN OVEN/MICRO
Kenmore 665.4438990  MICROWAVE OVEN
Kenmore 665.4438995  BUILT-IN OVEN/MICRO
Kenmore 665.4493392  MICROWAVE
Kenmore 665.4493393  ELEC BUILT-IN OVEN AND MICROWAVE
Kenmore 665.4558953  ELECTRIC COOKTOP / BUILT-IN OVEN
  #2 (permalink)
Old 02-21-2011, 01:11 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Russ,
Do I understand this correctly ?
You start the machine, the compaction ram runs down and compresses the trash, when it's time for the motor to reverse and run back up, the motor only hums, and the ram wont return to the up/ off position.
Here are motor winding and direction resistance checks from the service manual,
1. Set the ohmmeter at the Rx1 setting.
2. Zero the ohmmeter.
3. Check the motor for ground.
a. All terminals grounded to the metal frame should show an open circuit.
1) If they do not show an open circuit, the motor sould be replaced.
4. Check terminals GY to BR ( ram up direction)
a. Should read 1 to 4 ohms.
5. Check terminals R to BR (ram down direction).
6. Check between terminals W to Y (motor run winding).
a. Should read 1 to 3 ohms.
7. Check between terminals Y to BU (motor run winding).
That will most likely eliminate or confirm, the motor as the problem.
And then you'd need to check the gray wire from the motor to the directional switch,make sure it's not frayed or damaged/loose.
At that point you'd have a bad contact in the top limit/directional switch.
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
trash compactor won't stay shut and ram gets stuck down gj0709 Trash Compactor Repair 0 02-20-2011 11:16 AM
Trash Compactor Stuck in down position gideon1234 Trash Compactor Repair 0 02-07-2011 05:02 PM
Trash compactor ram stuck in down position John W G Trash Compactor Repair 0 01-05-2011 06:09 PM
GE MONOGRAM Trash Compactor RAM stuck danzenvoyz Trash Compactor Repair 14 02-14-2010 01:00 PM
Whirlpool Trash Compactor Stuck In Closed cdmue Trash Compactor Repair 4 02-25-2009 05:40 PM
