| » Replaced bake element,but oven won't work |
Model Number: fefb66ece Brand: Frigidaire Age: 5 - 10 years
Bake element burned out so I replaced it, but oven (broiler included) doesn't work. Stove top / control panel all work. Thanks.
Replacement parts for FRIGIDAIRE FEFB66ECE Frigidaire/range | AppliancePartsPros.com I am assuming you can program everything but the elements do not come on. I could not find a wiring for an ECE but looked at ae ECC and an ECF neither had a thermal cutout also I could not find one in the parts. So that leaves you with a bad control board, burned off wire or a temperature probe. Unplug the unit and check the wires from the control board to the elements. Check the oven sensor, should be around 1100 ohms. This is a long shot as usually an error would come up if there was a problem with it. If the above are OK then odds are your control board is toast.
__________________
| Display Modes | |
| replaced heating element oven still does not work | acinom | Oven Repair (including Ranges and Cooktops) | 10 | 05-27-2011 02:29 PM |
| oven bake element replaced not working | thewife | Oven Repair (including Ranges and Cooktops) | 0 | 11-13-2010 05:58 AM |
| Replaced bake element and still will not work | OrwellMOM | Oven Repair (including Ranges and Cooktops) | 0 | 03-31-2010 06:00 PM |
| Oven Bake Element Replaced, still no heat | hawkeye1315 | Oven Repair (including Ranges and Cooktops) | 3 | 12-22-2009 01:50 PM |
| Replaced Bake Element; Oven will not heat | slkcd@suddenlink.net | Oven Repair (including Ranges and Cooktops) | 1 | 01-21-2008 10:46 AM |
