Bottom oven bake element blew. Replaced with new element. Element will not heat. Took element back to store, checked and element is good. Re-installed and it still will not heat. What else can I check that would cause the element not to work? GE Stove model J4660R2DC 14.4 Serial # AT1196300
I would check all wires, a temperature control and a selector switch, if there is any. There are no diagrams available on-line for this model because it's very old.
