Discuss
Stove Burner Temperature Control
 in
Jenn-Air (by Maytag) Model CCE3531B Serial 15446055AX Left rear burner (the big one/ dual style) not working properly. Temperature adjustment
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Stove Burner Temperature Control
  #1 (permalink)
Old 02-18-2011, 12:07 PM
Junior Member
MBBC is on a distinguished road
Default Stove Burner Temperature Control
Model Number: CCE3531B   Brand: Jenn-Air   Age: 5 - 10 years
Model CCE3531B
Serial 15446055AX
Left rear burner (the big one/ dual style) not working properly. Temperature adjustment does not work. Regardless of what you set the temperature on, the burner heats up to high.
Suggestions appreciated / Thanks in advance!
Ads By Google
Related Models
Jenn-Air CCE3531B Surface Unit - Ele
Jenn-Air CCE3531W Surface Unit - Ele
Jenn-Air CCE406 Surface Unit - Ele
Jenn-Air CCE406B Surface Unit - Ele
Jenn-Air CCE406L Surface Unit - Ele
Jenn-Air CCE407B Surface Unit - Ele
Jenn-Air CCE407B-C Surface Unit - Ele
Jenn-Air CCE407W Surface Unit - Ele
Jenn-Air CCE407W-C Surface Unit - Ele
Maytag CCE6200ACB Walloven - Std Mwave Ele
Maytag CCE6200ACE Walloven - Std Mwave Ele
Maytag CCE700 Walloven - S/c Mwave Ele
Maytag CCE701 Walloven - S/c Mwave Ele
Jenn-Air CCE9300BF Surface Unit - Ele
Jenn-Air CCE9300BG Surface Unit - Ele
Jenn-Air CCE9300GG Surface Unit - Ele
Jenn-Air CCE9300JD Surface Unit - Ele
Jenn-Air CCE9300PL Surface Unit - Ele
Jenn-Air CCE9300SL Surface Unit - Ele
Jenn-Air CCE9300SS Surface Unit - Ele
Jenn-Air CCE9300TG Surface Unit - Ele
Maytag CCF200  Freezer - Chest
Jenn-Air CCG2420B Surface Unit - Gas
Jenn-Air CCG2420W Surface Unit - Gas
Jenn-Air CCG2421A Surface Unit - Gas
Jenn-Air CCG2421B Surface Unit - Gas
Jenn-Air CCG2421W Surface Unit - Gas
Jenn-Air CCG2422B Surface Unit - Gas
Jenn-Air CCG2422W Surface Unit - Gas
Jenn-Air CCG2423B Surface Unit - Gas
Jenn-Air CCG2423Q Surface Unit - Gas
Jenn-Air CCG2423S Surface Unit - Gas
Jenn-Air CCG2423W Surface Unit - Gas
Jenn-Air CCG2520B Surface Unit - Gas
Jenn-Air CCG2520W Surface Unit - Gas
Jenn-Air CCG2521A Surface Unit - Gas
Jenn-Air CCG2521B Surface Unit - Gas
Jenn-Air CCG2521W Surface Unit - Gas
Jenn-Air CCG2522B Surface Unit - Gas
Jenn-Air CCG2522W Surface Unit - Gas
Jenn-Air CCG2523B Surface Unit - Gas
Jenn-Air CCG2523S Surface Unit - Gas
Jenn-Air CCG2523W Surface Unit - Gas
Jenn-Air CCG406 Surface Unit - Gas
Jenn-Air CCG406B Surface Unit - Gas
Jenn-Air CCG406L Surface Unit - Gas
Jenn-Air CCG406S Surface Unit - Gas
Jenn-Air CCG456 Surface Unit - Gas
Jenn-Air CCG456B Surface Unit - Gas
Jenn-Air CCG456BC Surface Unit - Gas
Jenn-Air CCG456W Surface Unit - Gas
Jenn-Air CCG457B Surface Unit - Gas
Jenn-Air CCG457W Surface Unit - Gas
Jenn-Air CCG556B Surface Unit - Gas
Jenn-Air CCG556W Surface Unit - Gas
Jenn-Air CCGP2420P Surface Unit - Gas
Jenn-Air CCGP2420PF Surface Unit - Gas
Jenn-Air CCGP2420PG Surface Unit - Gas
Jenn-Air CCGP2420PR Surface Unit - Gas
Jenn-Air CCGP2420PU Surface Unit - Gas
Jenn-Air CCGP2720P Surface Unit - Gas
Jenn-Air CCGP2720PG Surface Unit - Gas
Jenn-Air CCGP2720PK Surface Unit - Gas
Jenn-Air CCGP2720PR Surface Unit - Gas
Jenn-Air CCGP2720PU Surface Unit - Gas
Jenn-Air CCGP2820P Surface Unit - Gas
Jenn-Air CCGP2820PR Surface Unit - Gas
Jenn-Air CCGP2820PU Surface Unit - Gas
Jenn-Air CCGX2420B Surface Unit - Gas
Jenn-Air CCGX2420W Surface Unit - Gas
Jenn-Air CCGX2620B Surface Unit - Gas
Jenn-Air CCGX2620W Surface Unit - Gas
Whirlpool CCH12AEK
Whirlpool CCH12ASK
Whirlpool CCH12WEK
Whirlpool CCH12WSK
Whirlpool CCH470AE2
Whirlpool CCH470WE2
Whirlpool CCH9AEK
Whirlpool CCH9ASK
Whirlpool CCH9WEK
Whirlpool CCH9WSK
Whirlpool CCK401TS
Amana CCMA2000 Commercial Microwaves
Amana CCMA2000BK Commercial Microwaves
Amana CCMA2230 Commercial Microwaves
Jenn-Air CCP457B Surface Unit - Gas
Jenn-Air CCP457W Surface Unit - Gas
Jenn-Air CCP556B Surface Unit - Gas
Jenn-Air CCP556W Surface Unit - Gas
Jenn-Air CCR466 Surface Unit - Ele
Jenn-Air CCR466B Surface Unit - Ele
Jenn-Air CCR467B Surface Unit - Ele
Jenn-Air CCR467B-C Surface Unit - Ele
Jenn-Air CCR467W Surface Unit - Ele
Jenn-Air CCR467W-C Surface Unit - Ele
Jenn-Air CCR567B Surface Unit - Ele
Jenn-Air CCR567B-C Surface Unit - Ele
Jenn-Air CCR567W Surface Unit - Ele
Jenn-Air CCR567W-C Surface Unit - Ele
Jenn-Air CCS446 Surface Unit - Ele
Jenn-Air CCS446-C Surface Unit - Ele
Jenn-Air CCS446W Surface Unit - Ele
Jenn-Air CCS446W-C Surface Unit - Ele
Jenn-Air CCS447B Surface Unit - Ele
Jenn-Air CCS447B-C Surface Unit - Ele
Jenn-Air CCS447W Surface Unit - Ele
Jenn-Air CCS447W-C Surface Unit - Ele
Whirlpool CCS50AE
Whirlpool CCS50AE1
Whirlpool CCS51AE
Whirlpool CCS51AE1
Whirlpool CCS51AEL
Amana CCU-514 Range - S/c S/i Ddraft Gas
Amana CCU-514C Range - S/c S/i Ddraft Gas
Amana CCU-514D Range - S/c S/i Ddraft Gas
Amana CCU-514E Range - S/c S/i Ddraft Gas
Amana CCU-514F Range - S/c S/i Ddraft Gas
Amana CCU-516 Range - S/c S/i Ddraft Gas
Amana CCU-516C Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 02-18-2011, 01:10 PM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
You have a bad switch. This is the part you will need according to your model number. Hope this helps. Part number: AP4008679
Body replacement parts for JENN-AIR CCE3531B SURFACE UNIT- ELE | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-18-2011, 01:20 PM
Junior Member
Default
Thanks Jeff!
  #4 (permalink)
Old 02-18-2011, 01:23 PM
Senior Expert
Default
Your welcome!
__________________
Jeff K. / APP TEAM
  #5 (permalink)
Old 03-25-2011, 09:57 AM
Junior Member
jubtub is on a distinguished road
Default same problem: maytag model MER5770AAA
I actually have the same problem. I just replaced the dual-burner element (front right on our stove) because the outer (high) ring wasn't coming on at all. That now works, but now it's either on full blast or completely off. It appears I need to replace the switch, too. Agree? If so, what is the part # I need. If not, what else could it be?
Thanks in advance!
N
  #6 (permalink)
Old 03-25-2011, 10:23 AM
Senior Expert
Default
Hello Jubtub. You will need to replace the dual switch. Here is the part number for you. Hope this helps.
Part number: AP4092288
Control panel replacement parts for MAYTAG MER5770AAA RANGE- S/C F/S ELE | AppliancePartsPros.com
__________________
Jeff K. / APP TEAM
  #7 (permalink)
Old 04-03-2011, 09:46 AM
Junior Member
Default
Hey Jeff,
So, I replaced the switch and no luck. Same behavior as before with the old switch: the burner comes on full-on or not at all - no variable control. I have some more info, though. Interestingly, I discovered that the front right burner also comes on when I turn on the *back right* burner (which also turns on). This happens with both the old and the new switch, I just didn't notice it before. Turning on the front right burner does *not* turn on the back right, if that matters. That would seem to point to a more central flaw. I don't believe this happened before I replaced the front right burner element last week.
Any ideas? This is getting expensive (element + switch) .
Thanks in advance.
Nate
  #8 (permalink)
Old 04-04-2011, 06:28 AM
Senior Expert
Default
Hello Nate. It sounds like you may have it wired wrong, or you may have the wrong part. Please provide a complete model and serial number so we can help you with this. Thanks.
__________________
Jeff K. / APP TEAM
  #9 (permalink)
Old 04-08-2011, 03:56 AM
Junior Member
Default
The stove is a Maytag MER5770AAA. I replaced the burner element with a AP4009116 (12002144) after which I had the problem where the element was either full on or not on at all. To fix that, I replaced the switch with a "AP4092288 (74002144) Sw, dual element (pri)" per this thread. Would it help if I sent photos of how the two parts are wired now?
N
  #10 (permalink)
Old 04-08-2011, 05:06 AM
Senior Expert
Default
That would be great!
__________________
Jeff K. / APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replaced stove top burner and infinite switch but burner still does not work rcaple Oven Repair (including Ranges and Cooktops) 1 09-23-2010 05:34 PM
temperature probe in a gas stove treeman542002 Oven Repair (including Ranges and Cooktops) 0 01-21-2010 10:58 AM
No Control of Heat in Stove Top Burner dehooten Oven Repair (including Ranges and Cooktops) 3 07-15-2009 04:45 PM
Stove Pre-Heats before desired temperature. trichar Oven Repair (including Ranges and Cooktops) 0 02-05-2009 01:46 PM
