| » FC "locked door" flashes. Door not locked. |
Model Number: j b900tok2ww Brand: GE Age: 5 - 10 years
After cleaning cycle completes, FC is on display, and "locked door" flashes, but latch on motorized switch is OPEN. Have cut power at the breaker and also tried reset procedure suggested by GE. It does not work. Only stovetop will work now. This is second time I had the problem. The last time I fixed it by using the reset procedure, and also wiggling the latch. It doesn't wok now.
The "FC" error code means that there is a failure in the door lock circuit.
You may want to check the switches in the door latch first. Then check the wire harness from the door latch to the control board. If there is nothing wrong, replace the control board. - The door latch assembly Part number: AP3993734 - The control board Part number: AP3792791 Here are the breakdown diagrams and Replacement parts for General Electric JB900TK2WW Electric range | AppliancePartsPros.com Gene. P.S. You have to have a simple multimeter to perform the troubleshooting.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Ge Oven "locked Door" Flashing | GTS1211 | Oven Repair (including Ranges and Cooktops) | 0 | 11-21-2010 08:47 AM |
| Oven door showing "LOC" on display after replacing latch door | josha3000 | Oven Repair (including Ranges and Cooktops) | 0 | 05-31-2010 07:34 AM |
| oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open | samej71 | Oven Repair (including Ranges and Cooktops) | 2 | 03-24-2010 07:05 AM |
| Oven Clock , Locked door display blinking but not locked | RaviM | Oven Repair (including Ranges and Cooktops) | 2 | 08-05-2009 05:47 PM |
| Whirlpool Dishwasher stuck in "Locked" | xltel | Dishwasher Repair | 7 | 07-04-2009 02:54 PM |
