Discuss
no power
 in
While self cleaning the whole oven shut off. I pulled the oven and found the thermal-fuse going to the control
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » no power
  #1 (permalink)
Old 02-17-2011, 03:58 PM
Junior Member
burrcold is on a distinguished road
Default no power
Model Number: KEBS278DBL2   Brand: Kitchen Aid   Age: More than 10 years
While self cleaning the whole oven shut off. I pulled the oven and found the thermal-fuse going to the control board has no continuity. How do I remove this fuse from the connector that goes to the circuit board? Could there be something else causing no power?
Ads By Google
Related Models
Whirlpool KEBS278DBL2
Whirlpool KEBS278DBL4
Whirlpool KEBS278DBL6
Whirlpool KEBS278DBL7
Whirlpool KEBS278DBL8
Whirlpool KEBS278DBL9
Whirlpool KEBS278DBS10
Whirlpool KEBS278DBS11
Whirlpool KEBS278DBS6
Whirlpool KEBS278DBS7
Whirlpool KEBS278DBS8
Whirlpool KEBS278DBS9
Whirlpool KEBS278DSS10
Whirlpool KEBS278DSS11
Whirlpool KEBS278DSS6
Whirlpool KEBS278DSS7
Whirlpool KEBS278DSS8
Whirlpool KEBS278DSS9
Whirlpool KEBS278DWH1
Whirlpool KEBS278DWH10
Whirlpool KEBS278DWH11
Whirlpool KEBS278DWH2
Whirlpool KEBS278DWH4
Whirlpool KEBS278DWH6
Whirlpool KEBS278DWH7
Whirlpool KEBS278DWH8
Whirlpool KEBS278DWH9
Whirlpool KEBS278SBL00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS278SSS00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBS278SWH00 27" Built - in Electric Double Oven Thermal Convection
Whirlpool KEBU107SSS00 30" Built - in Electric Single Oven
Whirlpool KEBU208SSS00 30" Built - in Electric Double Oven
Whirlpool KEBV107PMT00 30" Built - in Electric Oven Thermal Convection
Whirlpool KEBV107PMT01 30" Built - in Electric Oven Thermal Convection
Whirlpool KEBV107PSS00 30" Built - in Electric Oven Thermal Convection
Whirlpool KEBV107PSS01 30" Built - in Electric Oven Thermal Convection
Whirlpool KEBV208MMT00 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MMT02 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MMT03 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MSS00 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MSS02 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Whirlpool KEBV208MSS03 30" Built - in Electric Double Oven Thermal Convection Self - Clean
Frigidaire KEC3M6NSAA Gib(v1) / Electric Range
Frigidaire KEC457NSAA Gib(v1) / Electric Range
Whirlpool KECC027YAL0
Whirlpool KECC027YAL1
Whirlpool KECC027YAL2
Whirlpool KECC027YBL0
Whirlpool KECC027YBL1
Whirlpool KECC027YBL2
Whirlpool KECC027YWH0
Whirlpool KECC027YWH1
Whirlpool KECC027YWH2
Whirlpool KECC051HBL0
Whirlpool KECC051HBL05 15" Electric Ceran 2 Burner Cooktop
Whirlpool KECC051HBL1
Whirlpool KECC051HBL2
Whirlpool KECC051HBL3
Whirlpool KECC051HBT0
Whirlpool KECC051HBT05 15" Electric Ceran 2 Burner Cooktop
Whirlpool KECC051HBT1
Whirlpool KECC051HBT2
Whirlpool KECC051HBT3
Whirlpool KECC051HWH0
Whirlpool KECC051HWH05 15" Electric Ceran 2 Burner Cooktop
Whirlpool KECC051HWH1
Whirlpool KECC051HWH2
Whirlpool KECC051HWH3
Whirlpool KECC056RBL00 15" Electric Ceran 2 Burner Cooktop
Whirlpool KECC056RBL01 15" Electric Ceran 2 Burner Cooktop
Whirlpool KECC056RBL02 15" Electric Ceran 2 Burner Cooktop
Whirlpool KECC500BBL0
Whirlpool KECC500BWH0
Whirlpool KECC500WBL0
Whirlpool KECC500WBL1
Whirlpool KECC500WBL2
Whirlpool KECC500WBL3
Whirlpool KECC500WWH0
Whirlpool KECC500WWH1
Whirlpool KECC500WWH2
Whirlpool KECC500WWH3
Whirlpool KECC501BAL0
Whirlpool KECC501BAL1
Whirlpool KECC501BAL2
Whirlpool KECC501BBL0
Whirlpool KECC501BBL1
Whirlpool KECC501BBL2
Whirlpool KECC501BWH0
Whirlpool KECC501BWH1
Whirlpool KECC501BWH2
Whirlpool KECC501GAL0
Whirlpool KECC501GAL1
Whirlpool KECC501GAL2
Whirlpool KECC501GBL0
Whirlpool KECC501GBL1
Whirlpool KECC501GBL2
Whirlpool KECC501GBL3
Whirlpool KECC501GBT3
Whirlpool KECC501GWH0
Whirlpool KECC501GWH1
Whirlpool KECC501GWH2
Whirlpool KECC501GWH3
Whirlpool KECC502BAL0
Whirlpool KECC502BAL1
Whirlpool KECC502BAL2
Whirlpool KECC502BBL0
Whirlpool KECC502BBL1
Whirlpool KECC502BBL2
Whirlpool KECC502BWH0
Whirlpool KECC502BWH1
Whirlpool KECC502BWH2
Whirlpool KECC502GAL0
Whirlpool KECC502GAL1
Whirlpool KECC502GAL2
Whirlpool KECC502GBL0
Whirlpool KECC502GBL05 30" Electric Built - in Cooktop
Whirlpool KECC502GBL06 30" Electric Built - in Cooktop
Whirlpool KECC502GBL1
Whirlpool KECC502GBL2
Whirlpool KECC502GBL3
  #2 (permalink)
Old 02-17-2011, 09:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can use a needle to remove the control panel thermal fuse from the connector. Order the new fuse and you'll see how this latch is working.
You also may want to check the oven thermal shut down fuse on the back of the oven (#37 on the diagram).
You did not mention which oven was self cleaning, so I'll provide part numbers for both ovens.
- The upper oven thermal fuse Part number: AP3055315
- The lower oven thermal fuse Part number: AP3055316
- The control panel thermal fuse Part number: AP3777386
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KEBS278DBL2 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-20-2011, 05:04 PM
Junior Member
Default
Thank you for the response. I ordered the thermal fuse it should be here tomorrow. The overheat sensor has continuity so I think that is OK. Thanks again
  #4 (permalink)
Old 02-21-2011, 03:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Gemini No Power to Oven/Power to Stove crashbowman Oven Repair (including Ranges and Cooktops) 2 01-12-2011 09:49 AM
power surge damaged power pack,replaced,compressor and condenser fan still not runnin shillion Refrigerator & Freezer Repair 0 11-16-2010 01:38 AM
No Power on dryer, power to outlet and cord dorn27 Dryer Repair 1 07-26-2010 05:15 PM
Maytag Neptune Dryer - no power at all after power cord poli Dryer Repair 0 07-09-2010 07:46 AM
