| » replacing thermistat |
Model Number: 91f-4kx Brand: Magic Chef Age: More than 10 years
i think my thermistat is out. going to replace it. how hard is it to install.
What are the two plugs in the back? i just replaced the igniter. Is the thermstat harder or easier to do? MAX Ads By Google Related Models |
Why do you think the oven thermostat is bad?
What is the serial number of the oven? Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 91F-4KX WALLOVEN- STD GAS | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
the number I got off the oven is either ser. 05c951163440 or ANS.221.1b-1984. The gas doesnt come on and i put in a new igniter and it doesnt get hot or turn on. Oven is about 35 + yrs old. So i think it has to be the thermistat.
Not necessarily. You may want to check the gas safety valve (#7 on the diagram) for continuity first.
If there is no continuity then the gas safety valve is the culprit. The oven thermostat for this model with the serial number 05C... is no longer available. - The gas safety valve Part number: AP4009111 Gene.
__________________
In order to perform the continuity test you have to have a simple multimeter.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter Unfortunately there are no any other thermostats I can recommend to use for this oven. Gene.
__________________
| Display Modes | |
| Need help replacing tub bearing | schaub01 | Washer Repair | 1 | 11-29-2010 07:25 AM |
| Replacing Maytag glass cootktop element does switch need replacing too? | rneumann1962 | Oven Repair (including Ranges and Cooktops) | 1 | 01-18-2010 10:19 AM |
| need help on replacing hub | barryh | Washer Repair | 2 | 06-09-2009 03:26 PM |
| Replacing EOC | kevin lombardi | Oven Repair (including Ranges and Cooktops) | 2 | 04-03-2009 03:54 AM |
| F1 after replacing the EOC | tjc1204 | Oven Repair (including Ranges and Cooktops) | 6 | 11-20-2008 03:11 PM |
