Discuss
Problems with Thermador Cook n Vent
 in
My old Thermador Cook N Vent Downdraft model # CVS45R works fine. However, it started to partially fall at a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Problems with Thermador Cook n Vent
  #1 (permalink)
Old 02-17-2011, 09:49 AM
Junior Member
lzurcher is on a distinguished road
Default Problems with Thermador Cook n Vent
Model Number: CVS45R   Brand: Thermador   Age: More than 10 years
My old Thermador Cook N Vent Downdraft model # CVS45R works fine. However, it started to partially fall at a given point on its downward travel as if there was some obstruction, or some loose screw on the mechanism.
How do I check and remedy this?
Thank you,
Lukas
Ads By Google
Related Models
Thermador CVS45RB
Thermador CVS45RS
Thermador CVS45RW
Thermador CVSE36B
Crosley CW18C1 Washer - Top Loading
Crosley CW18C100 Washer - Top Loading
Crosley CW18C124 Washer - Top Loading
Crosley CW18C125 Washer - Top Loading
Crosley CW18C126 Washer - Top Loading
Crosley CW18C127 Washer - Top Loading
Crosley CW18C1A Washer - Top Loading
Crosley CW18C1H Washer - Top Loading
Crosley CW18C3A Washer - Top Loading
Crosley CW18C3H Washer - Top Loading
Crosley CW18C3W Washer - Top Loading
Crosley CW18M4 Washer - Top Loading
Crosley CW18M4A Washer - Top Loading
Crosley CW18M4H Washer - Top Loading
Crosley CW18M4W Washer - Top Loading
Crosley CW18P2A Washer - Top Loading
Crosley CW18P2AC Washer - Top Loading
Crosley CW18P2H Washer - Top Loading
Crosley CW18P2HC Washer - Top Loading
Crosley CW18P2W Washer - Top Loading
Crosley CW18P2WC Washer - Top Loading
Crosley CW18P6A Washer - Top Loading
Crosley CW18P6H Washer - Top Loading
Crosley CW18P6W Washer - Top Loading
Crosley CW18T2A Washer - Top Loading
Crosley CW18T2W Washer - Top Loading
Crosley CW20C5A Washer - Top Loading
Crosley CW20C5H Washer - Top Loading
Crosley CW20C5W Washer - Top Loading
Crosley CW20C7A Washer - Top Loading
Crosley CW20C7W Washer - Top Loading
Crosley CW20M4A Washer - Top Loading
Crosley CW20M6 Washer - Top Loading
Crosley CW20M6A Washer - Top Loading
Crosley CW20M8 Washer - Top Loading
Crosley CW20M8A Washer - Top Loading
Crosley CW20M8H Washer - Top Loading
Crosley CW20M9A Washer - Top Loading
Crosley CW20M9N Washer - Top Loading
Crosley CW20P4A Washer - Top Loading
Crosley CW20P4H Washer - Top Loading
Crosley CW20P4W Washer - Top Loading
Crosley CW20P5A Washer - Top Loading
Crosley CW20P5AC Washer - Top Loading
Crosley CW20P5H Washer - Top Loading
Crosley CW20P5HC Washer - Top Loading
Crosley CW20P5W Washer - Top Loading
Crosley CW20P5WC Washer - Top Loading
Crosley CW20P6 Washer - Top Loading
Crosley CW20P6A Washer - Top Loading
Crosley CW20P6AC Washer - Top Loading
Crosley CW20P6H Washer - Top Loading
Crosley CW20P6HC Washer - Top Loading
Crosley CW20P6W Washer - Top Loading
Crosley CW20P6WC Washer - Top Loading
Crosley CW20P8 Washer - Top Loading
Crosley CW20P8A Washer - Top Loading
Crosley CW20P8AC Washer - Top Loading
Crosley CW20P8AS Washer - Top Loading
Crosley CW20P8ASC Washer - Top Loading
Crosley CW20P8D Washer - Top Loading
Crosley CW20P8DS Washer - Top Loading
Crosley CW20P8DSC Washer - Top Loading
Crosley CW20P8H Washer - Top Loading
Crosley CW20P8HS Washer - Top Loading
Crosley CW20P8HSC Washer - Top Loading
Crosley CW20P8W Washer - Top Loading
Crosley CW20P8WC Washer - Top Loading
Crosley CW20P8WS Washer - Top Loading
Crosley CW20P8WSC Washer - Top Loading
Crosley CW20T5A Washer - Top Loading
Crosley CW20T5W Washer - Top Loading
Crosley CW20T5WC Washer - Top Loading
Crosley CW20T6A Washer - Top Loading
Crosley CW20T6AC Washer - Top Loading
Crosley CW20T6W Washer - Top Loading
Crosley CW20T6WC Washer - Top Loading
Crosley CW20T7A Washer - Top Loading
Crosley CW20T7V Washer - Top Loading
Crosley CW20T7W Washer - Top Loading
Crosley CW20T8A Washer - Top Loading
Crosley CW20T8AC Washer - Top Loading
Crosley CW20T8V Washer - Top Loading
Crosley CW20T8VC Washer - Top Loading
Crosley CW20T8W Washer - Top Loading
Crosley CW20T8WC Washer - Top Loading
Crosley CW22B5M Washer - Top Loading
Crosley CW22B5V Washer - Top Loading
Crosley CW22B6M Washer - Top Loading
Crosley CW22B6V Washer - Top Loading
Crosley CW22B7M Washer - Top Loading
Crosley CW22B7V Washer - Top Loading
Crosley CW22B8M Washer - Top Loading
Crosley CW22B8V Washer - Top Loading
Amana CW2303 Washer - Top Loading
Amana CW2303G Washer - Top Loading
Amana CW2303L Washer - Top Loading
Amana CW2303W Washer - Top Loading
Amana CW2502L Washer - Top Loading
Amana CW2502W Washer - Top Loading
Crosley CW25P6A Washer - Top Loading
Crosley CW25P6H Washer - Top Loading
Crosley CW25P6W Washer - Top Loading
Crosley CW26P6KA Washer - Top Loading
Crosley CW26P6KH Washer - Top Loading
Crosley CW26P6KW Washer - Top Loading
Amana CW3303L Washer - Top Loading
Amana CW3303W Washer - Top Loading
Amana CW3502L Washer - Top Loading
Amana CW3502W Washer - Top Loading
Amana CW4202L Washer - Top Loading
Amana CW4202W Washer - Top Loading
Amana CW4202W2 Washer - Top Loading
  #2 (permalink)
Old 02-17-2011, 12:26 PM
Jeff / APP Team's Avatar
Senior Expert
Jeff / APP Team is on a distinguished road
Default
You will need to disassemble it from below to see what is causing the noise. Be sure and disconnect the power to it. I'm attaching a link to the parts diagram to help you see what you will be looking at.
Downdraft system replacement parts for THERMADOR CVS45RB | AppliancePartsPros.com
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Jeff K. / APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-17-2011, 06:58 PM
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
Hello,
Most likely, the drive arm has loosened from the motor shaft, which causes it to bind up, then release on the way down.
You'll need to get to motor, resecure the arm onto the motor and tighten the screw. Applying a little lock-tite to the thread will help to insure in doesn't happen again.
Motor Access (with unit unplugged from power):
1)Lower unit all the way.
2)Remove the rectangular motor cover
3)Remove whatever is mounted just below the motor, e.g. the blower, transition or vent cover. You should now be able to see the drive arm and link arm which are connected together.
4)Disconnect the two arms
5)Remove the 4 screws that secure the motor housing to the unit
6)Lift the motor up, then out towards you.
Flip it around and you'll see the drive arm. If it's loose, reinstall it, but make sure it aligns with the two switches. On the front of the motor, near the 5 o'clock position, there's a metal, spring-loaded tab you can press that will disengage the motor and let the drive arm spin. Press this in and rotate the drive arm to make sure the arm activates both switches.
Once the drive arm is aligned with the switches, secure the drive arm and reinstall the motor into the down draft.
This should take care of it. If not, you should be able to see anything else that's wrong with it while it's out.
Good Luck,
KC
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Problems with Thermador Cook n Vent Bill2 Oven Repair (including Ranges and Cooktops) 3 02-18-2011 01:47 PM
Thermador Cook N Vent Mirtl Oven Repair (including Ranges and Cooktops) 0 10-20-2010 12:34 PM
Thermador Cook N' Vent M Mac Oven Repair (including Ranges and Cooktops) 0 12-17-2009 11:09 AM
THERMADOR Cook N Vent Vent issue PaulaM Oven Repair (including Ranges and Cooktops) 0 06-25-2009 06:59 PM
Thermador Cook n vent Aninie Oven Repair (including Ranges and Cooktops) 1 01-02-2009 05:54 PM
