| » dacor double oven |
Model Number: mcs227s Brand: Dacor Age: 1 - 5 years
I was testing the unit and I had everything on then lost power to everything I went inside the unit and found the 24v transformer had power going in but not comeing out can the transformer cause the unit to lose power to everything the wiring diagram showed an inline fuse but there wasn't one
It shows in the diagram that the fuse is located at the control panel. It is a black wire coming off the secondary side of the transformer. I would check there and see if I could locate it. If not, then test for continuity from the black wire on your board to the black wire on the seconday side of the transformer. Hope this helps.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Jeff K. / APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Dacor Double Wall Oven-replace lower oven relay board | CatsR | Oven Repair (including Ranges and Cooktops) | 3 | 01-28-2011 07:29 AM |
| dacor double oven | brandy9 | Oven Repair (including Ranges and Cooktops) | 1 | 10-09-2009 04:54 PM |
| Dacor double wall oven | balm | Oven Repair (including Ranges and Cooktops) | 0 | 09-29-2009 12:05 PM |
| ? Dacor Double Oven Door Removal | dianeb | Oven Repair (including Ranges and Cooktops) | 0 | 01-23-2009 08:44 AM |
| Dacor double oven, lower oven failure | tuckspub | Oven Repair (including Ranges and Cooktops) | 2 | 09-02-2008 09:48 AM |
