Discuss
No baking or broiling PLEASE HELP
 in
Last week I left the oven on overnight and in the morning the oven had gone cold and will not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » No baking or broiling PLEASE HELP
  #1 (permalink)
Old 02-16-2011, 08:32 PM
Junior Member
johnrp99 is on a distinguished road
Default No baking or broiling PLEASE HELP
Model Number: FEFL77ABH   Brand: Frigidaire   Age: 1 - 5 years
Last week I left the oven on overnight and in the morning the oven had gone cold and will not heat up. No heat from the bake or broil element. I did extensive research and tested all the components in the oven. My results indicated that that the elements both ohm'd out at around 16 (not a bad element). The P4 connection (L2 out) on the EOC is not putting out the 120 volts that it should be. I replaced the the probe and tested it at 1000 ohms. What would cause that port on the EOC to not be transmitting the voltage? Thanks in advance for the help.
Ads By Google
Related Models
Frigidaire FEFL77ABH Frigidaire/electric Range
Frigidaire FEFL77AQA Frigidaire/range
Frigidaire FEFL77AQB Frigidaire/range
Frigidaire FEFL77AQC Frigidaire/electric Range
Frigidaire FEFL77AQD Frigidaire/electric Range
Frigidaire FEFL77AQE Frigidaire/electric Range
Frigidaire FEFL77AQF Frigidaire/electric Range
Frigidaire FEFL77AQG Frigidaire/electric Range
Frigidaire FEFL77AQH Frigidaire/electric Range
Frigidaire FEFL77ASA Frigidaire/range
Frigidaire FEFL77ASB Frigidaire/range
Frigidaire FEFL77ASC Frigidaire/electric Range
Frigidaire FEFL77ASD Frigidaire/electric Range
Frigidaire FEFL77ASE Frigidaire/electric Range
Frigidaire FEFL77ASF Frigidaire/electric Range
Frigidaire FEFL77ASG Frigidaire/electric Range
Frigidaire FEFL77ASH Frigidaire/electric Range
Frigidaire FEFL78CBA Frigidaire/electric Range
Frigidaire FEFL78CBB Frigidaire/electric Range
Frigidaire FEFL78CBC Frigidaire/electric Range
Frigidaire FEFL78CBD Frigidaire/electric Range
Frigidaire FEFL78CQA Frigidaire/electric Range
Frigidaire FEFL78CQB Frigidaire/electric Range
Frigidaire FEFL78CQC Frigidaire/electric Range
Frigidaire FEFL78CQD Frigidaire/electric Range
Frigidaire FEFL78CSA Frigidaire/electric Range
Frigidaire FEFL78CSB Frigidaire/electric Range
Frigidaire FEFL78CSC Frigidaire/electric Range
Frigidaire FEFL78CSD Frigidaire/electric Range
Frigidaire FEFL79DBA Frigidaire/electric Range
Frigidaire FEFL79DBB Frigidaire/electric Range
Frigidaire FEFL79DBD Frigidaire/electric Range
Frigidaire FEFL79DBF Frigidaire/range
Frigidaire FEFL79DBG Frigidaire/range
Frigidaire FEFL79DBH Frigidaire/electric Range
Frigidaire FEFL79DBJ Frigidaire/range
Frigidaire FEFL79DBK Frigidaire/range
Frigidaire FEFL79DBL Frigidaire/range
Frigidaire FEFL79DCA Frigidaire/electric Range
Frigidaire FEFL79DCB Frigidaire/electric Range
Frigidaire FEFL79DCC Frigidaire/electric Range
Frigidaire FEFL79DCD Frigidaire/refrigerator
Frigidaire FEFL79DCF Frigidaire/range
Frigidaire FEFL79DCG Frigidaire/range
Frigidaire FEFL79DQA Frigidaire/electric Range
Frigidaire FEFL79DQB Frigidaire/electric Range
Frigidaire FEFL79DQD Frigidaire/electric Range
Frigidaire FEFL79DQF Frigidaire/range
Frigidaire FEFL79DQG Frigidaire/range
Frigidaire FEFL79DQH Frigidaire/electric Range
Frigidaire FEFL79DQJ Frigidaire/range
Frigidaire FEFL79DQK Frigidaire/range
Frigidaire FEFL79DQL Frigidaire/range
Frigidaire FEFL79DSA Frigidaire/electric Range
Frigidaire FEFL79DSB Frigidaire/electric Range
Frigidaire FEFL79DSD Frigidaire/electric Range
Frigidaire FEFL79DSF Frigidaire/range
Frigidaire FEFL79DSG Frigidaire/range
Frigidaire FEFL79DSH Frigidaire/electric Range
Frigidaire FEFL79DSJ Frigidaire/range
Frigidaire FEFL79DSK Frigidaire/range
Frigidaire FEFL79DSL Frigidaire/range
Frigidaire FEFL79ECA Frigidaire/electric Range
Frigidaire FEFL79ECB Frigidaire/electric Range
Frigidaire FEFL79ECC Frigidaire/range
Frigidaire FEFL79ECD Frigidaire/electric Range
Frigidaire FEFL79ECE Frigidaire/range
Frigidaire FEFL79FCA Frigidaire/electric Range
Frigidaire FEFL79FCB Frigidaire/range
Frigidaire FEFL79FCC Frigidaire/range
Frigidaire FEFL79GBA Frigidaire/range
Frigidaire FEFL79GCA Frigidaire/range
Frigidaire FEFL79GQA Frigidaire/range
Frigidaire FEFL79GSA Frigidaire/range
Frigidaire FEFL79HBA ELECTRIC RANGE
Frigidaire FEFL79HBB ELECTRIC RANGE
Frigidaire FEFL79HCA ELECTRIC RANGE
Frigidaire FEFL79HCB ELECTRIC RANGE
Frigidaire FEFL79HQA ELECTRIC RANGE
Frigidaire FEFL79HQB ELECTRIC RANGE
Frigidaire FEFL79HSA ELECTRIC RANGE
Frigidaire FEFL79HSB ELECTRIC RANGE
Frigidaire FEFL79JBA ELECTRIC RANGE
Frigidaire FEFL79JBB ELECTRIC RANGE
Frigidaire FEFL79JCA ELECTRIC RANGE
Frigidaire FEFL79JCB ELECTRIC RANGE
Frigidaire FEFL79JCC ELECTRIC RANGE
Frigidaire FEFL79JCE ELECTRIC RANGE
Frigidaire FEFL79JQA ELECTRIC RANGE
Frigidaire FEFL79JQB ELECTRIC RANGE
Frigidaire FEFL79JSA ELECTRIC RANGE
Frigidaire FEFL79JSB ELECTRIC RANGE
Frigidaire FEFL88ABA Frigidaire/electric Range
Frigidaire FEFL88ABB Frigidaire/electric Range
Frigidaire FEFL88ABC Frigidaire/electric Range
Frigidaire FEFL88ACA Frigidaire/electric Range
Frigidaire FEFL88ACB Frigidaire/electric Range
Frigidaire FEFL88ACC Frigidaire/electric Range
Frigidaire FEFL88ASA Frigidaire/electric Range
Frigidaire FEFL88ASB Frigidaire/electric Range
Frigidaire FEFL88ASC Frigidaire/electric Range
Frigidaire FEFL89CCA Frigidaire/electric Range
Frigidaire FEFL89CCB Frigidaire/electric Range
Frigidaire FEFLM600DQA Frigidaire/electric Range
Frigidaire FEFLM600DSA Frigidaire/electric Range
Frigidaire FEFLM605DBB Frigidaire/electric Range
Frigidaire FEFLM605DBD Frigidaire/electric Range
Frigidaire FEFLM605DCB Frigidaire/electric Range
Frigidaire FEFLM605DCC Frigidaire/electric Range
Frigidaire FEFLM605DCD Frigidaire/range
Frigidaire FEFLM605DCE Frigidaire/electric Range
Frigidaire FEFLM605DCG Frigidaire/range
Frigidaire FEFLM605DCH Frigidaire/range
Frigidaire FEFLM605DCJ Frigidaire/range
Frigidaire FEFLM605DQB Frigidaire/electric Range
Frigidaire FEFLM605DQD Frigidaire/electric Range
Frigidaire FEFLM605DSB Frigidaire/electric Range
Frigidaire FEFLM605DSD Frigidaire/electric Range
Frigidaire FEFLM66EBA Frigidaire/electric Range
Frigidaire FEFLM66EBB Frigidaire/electric Range
  #2 (permalink)
Old 02-16-2011, 08:56 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
I suspect your board is bad, but look closely at the wire connections on the bake and broil element, a broken wire can cause no bake or broil
__________________
  #3 (permalink)
Old 02-16-2011, 09:03 PM
Junior Member
Default
I am taking the voltage reading directly off the EOC. When the relay "Clicks" the Bake port Energizes the yellow lead down to the bake element but the P4 (L2 OUT) port does not energize the orange wire that leads down to the other side of the bake element.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
replacing broiling element bigdadrob Oven Repair (including Ranges and Cooktops) 1 11-19-2009 08:37 PM
Broiling element does not heat up rameshdesai44@gmail.com Oven Repair (including Ranges and Cooktops) 0 08-02-2008 10:38 AM
baking lm144 Oven Repair (including Ranges and Cooktops) 1 10-17-2007 10:52 AM
Oven not Broiling scottg Oven Repair (including Ranges and Cooktops) 0 09-21-2007 07:37 AM
oven not broiling scottg Oven Repair (including Ranges and Cooktops) 0 09-12-2007 06:42 AM
