Discuss
Tappan Oven help
 in
we have been having problems with our oven for a while now. The preheating light will stay on for a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan Oven help
  #1 (permalink)
Old 12-15-2008, 02:13 PM
Junior Member
Blackhawk141 is on a distinguished road
Default Tappan Oven help
Model Number: TGF355BFDB   Brand: Tappan   Age: 5 - 10 years
we have been having problems with our oven for a while now. The preheating light will stay on for a long time before it will beep to let you know it is done. Now sometimes the oven turns on and sometimes it doesn't, when it doesn't all you smell is gas. From what I have been reading it sounds like i might need a new ignitor for the oven and a gas regulator. Since I'm going to be working on the stove, but range has a ignitor to light the range, but not all of them work. Is this also something that can be easily fixed. Thank you in advance for any help, on what part numbers I might need and how to put them in.
Ads By Google
Related Models
Frigidaire TGF355BFDB Tap(v1) / Gas Range
Frigidaire TGF355BFWA Tap(v2) / Gas Range
Frigidaire TGF355BFWB Tap(v2) / Gas Range
Frigidaire TGF355BHDA Tap(v1) / Gas Range
Frigidaire TGF355BHDB Tap(v2) / Gas Range
Frigidaire TGF355BHDC Tap(v3) / Gas Range
Tappan TGF355BHDF Tappan/gas Range
Frigidaire TGF355BHWA Tap(v4) / Gas Range
Frigidaire TGF355BHWB Tap(v5) / Gas Range
Frigidaire TGF355BHWC Tap(v6) / Gas Range
Tappan TGF355BHWF Tappan/gas Range
Frigidaire TGF355BXDA Tap(v1) / Gas Range
Frigidaire TGF355BXWA Tap(v2) / Gas Range
Frigidaire TGF356BCDA Tap(v1) / Gas Range
Frigidaire TGF356BCDB Tap(v1) / Gas Range
Frigidaire TGF356BCDC Tap(v1) / Gas Range
Frigidaire TGF356BCDD Tap(v2) / Gas Range
Frigidaire TGF356BCDE Tap(v1) / Gas Range
Frigidaire TGF356BCWA Tap(v2) / Gas Range
Frigidaire TGF356BCWB Tap(v2) / Gas Range
Frigidaire TGF356BCWC Tap(v3) / Gas Range
Frigidaire TGF356BCWD Tap(v4) / Gas Range
Frigidaire TGF356BCWE Tap(v2) / Gas Range
Frigidaire TGF356CCSA Tap(v0) / Gas Range
Frigidaire TGF356CCSC Tap(v0) / Gas Range
Frigidaire TGF356CCSD Tap(v0) / Gas Range
Frigidaire TGF357BCDA Tap(v1) / Gas Range
Frigidaire TGF357BCDC Tap(v1) / Gas Range
Frigidaire TGF357BCDD Tap(v2) / Gas Range
Frigidaire TGF357BCDE Tap(v1) / Gas Range
Frigidaire TGF357BCWA Tap(v2) / Gas Range
Frigidaire TGF357BCWC Tap(v3) / Gas Range
Frigidaire TGF357BCWD Tap(v4) / Gas Range
Frigidaire TGF357BCWE Tap(v2) / Gas Range
Frigidaire TGF357CCSA Tap(v1) / Gas Range
Frigidaire TGF357CCSB Tap(v1) / Gas Range
Frigidaire TGF357CCSC Tap(v1) / Gas Range
Frigidaire TGF357CCSD Tap(v2) / Gas Range
Frigidaire TGF357CCSE Tap(v1) / Gas Range
Frigidaire TGF357CCSF Tap(v3) / Gas Range
Frigidaire TGF357CCSG Tap(v0) / Gas Range
Frigidaire TGF357CCTA Tap(v2) / Gas Range
Frigidaire TGF357CCTB Tap(v2) / Gas Range
Frigidaire TGF357CCTC Tap(v3) / Gas Range
Frigidaire TGF357CCTD Tap(v4) / Gas Range
Frigidaire TGF357CCTE Tap(v2) / Gas Range
Frigidaire TGF357CCTF Tap(v4) / Gas Range
Frigidaire TGF362BBBA Tap(v0) / Gas Range
Frigidaire TGF362BBBB Tap(v0) / Gas Range
Frigidaire TGF362BBBC Tap(v1) / Gas Range
Frigidaire TGF362BBBD Tap(v2) / Gas Range
Frigidaire TGF362BBBE Tap(v0) / Gas Range
Frigidaire TGF362BBBF Tap(v0) / Gas Range
Frigidaire TGF362BBBH Tap(v0) / Gas Range
Tappan TGF363AUA Tappan/range
Tappan TGF363AUB Tappan/gas Range
Tappan TGF363AUC Tappan/gas Range
Tappan TGF363AUD Tappan/gas Range
Tappan TGF363AUE Tappan/gas Range
Tappan TGF363AUF Tappan/gas Range
Tappan TGF363AWA Tappan/range
Tappan TGF363AWB Tappan/gas Range
Tappan TGF363AWC Tappan/gas Range
Tappan TGF363AWD Tappan/gas Range
Tappan TGF363AWE Tappan/gas Range
Tappan TGF363AWF Tappan/gas Range
Tappan TGF364AQA Tappan/range
Tappan TGF364AQB Tappan/range
Tappan TGF364AQC Tappan/gas Range
Tappan TGF364AQD Tappan/gas Range
Tappan TGF364AQE Tappan/gas Range
Tappan TGF364AQF Tappan/gas Range
Tappan TGF364AQG Tappan/gas Range
Tappan TGF364ASA Tappan/range
Tappan TGF364ASB Tappan/range
Tappan TGF364ASC Tappan/gas Range
Tappan TGF364ASD Tappan/gas Range
Tappan TGF364ASE Tappan/gas Range
Tappan TGF364ASF Tappan/gas Range
Tappan TGF364ASG Tappan/gas Range
Frigidaire TGF364SCDA Tap(v1) / Gas Range
Frigidaire TGF364SCWA Tap(v2) / Gas Range
Frigidaire TGF365BEDA Tap(v1) / Gas Range
Frigidaire TGF365BEDB Tap(v1) / Gas Range
Frigidaire TGF365BEDC Tap(v1) / Gas Range
Frigidaire TGF365BEWA Tap(v2) / Gas Range
Frigidaire TGF365BEWB Tap(v2) / Gas Range
Frigidaire TGF365BEWC Tap(v2) / Gas Range
Frigidaire TGF365BFDA Tap(v1) / Gas Range
Frigidaire TGF365BFWA Tap(v2) / Gas Range
Frigidaire TGF365CHSA Tap(v1) / Gas Range
Frigidaire TGF365CHSB Tap(v2) / Gas Range
Frigidaire TGF365CHSC Tap(v3) / Gas Range
Tappan TGF365CHSF Tappan/gas Range
Frigidaire TGF365CHTA Tap(v4) / Gas Range
Frigidaire TGF365CHTB Tap(v5) / Gas Range
Frigidaire TGF365CHTC Tap(v6) / Gas Range
Tappan TGF365CHTF Tappan/gas Range
Frigidaire TGF366CFBC Frg(v1) / Gas Range
Frigidaire TGF366CFSA Tap(v1) / Gas Range
Frigidaire TGF366CFSD Frg(v2) / Gas Range
Frigidaire TGF366CFSE Frg(v3) / Gas Range
Frigidaire TGF366CFTA Tap(v2) / Gas Range
Frigidaire TGF366CFTD Frg(v4) / Gas Range
Frigidaire TGF366CFTE Frg(v5) / Gas Range
Frigidaire TGF367CFSA Tap(v1) / Gas Range
Frigidaire TGF367CFTA Tap(v2) / Gas Range
Tappan TGF375BHBF Tappan/gas Range
Tappan TGF375CHSF Tappan/gas Range
Tappan TGF377WJCA Tappan/gas Range
Frigidaire TGF602PGD1 Tap(v0) / Gas Range
Frigidaire TGF602PGW1 Tap(v0) / Gas Range
Tappan TGF602PGW3 Tappan/gas Range
Tappan TGF602PGW4 Tappan/gas Range
Tappan TGF605EU1 Tappan/gas Range
Tappan TGF605EW1 Tappan/gas Range
Tappan TGF605EW2 Tappan/range
Frigidaire TGF605WCD1 Tap(v1) / Gas Range
Frigidaire TGF605WCD2 Tap(v1) / Gas Range
Frigidaire TGF605WCDA Tap(v2) / Gas Range
  #2 (permalink)
Old 12-16-2008, 01:27 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The problem with your oven most likely caused by a weak igniter. About the top burners problem I need more specific description.
- The part number for the oven igniter is AP2150412
You have to remove the oven floor and the flame spreader to access the igniter.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Old Tappan gas oven despot5 Oven Repair (including Ranges and Cooktops) 0 06-16-2009 08:06 AM
tappan oven will not come on busterhess Oven Repair (including Ranges and Cooktops) 0 10-05-2008 07:20 PM
How do I replace the oven glass on my Tappan oven??? CCrews00 Oven Repair (including Ranges and Cooktops) 0 09-04-2008 06:47 PM
Tappan oven wren Oven Repair (including Ranges and Cooktops) 0 08-28-2008 07:21 AM
Tappan Oven Niteshay Oven Repair (including Ranges and Cooktops) 2 02-29-2008 05:29 PM
