Discuss
Oven Help!
 in
We are having problems with our gas oven. First of all the broiler and the range work fine. The oven
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Help!
  #1 (permalink)
Old 12-15-2008, 02:05 PM
Junior Member
nedwards is on a distinguished road
Question Oven Help!
Model Number: ARG7600LL   Brand: Amana   Age: 5 - 10 years
We are having problems with our gas oven. First of all the broiler and the range work fine. The oven is another story. When we turn on the oven the glo light comes on. If the oven does actually come on it takes forever and we get a loud bang. The oven may come on and stay on or it may go off when it should come back on to re-heat up to a certain temperature. I have had two appliance men tell me two different parts that need to be replaced. One told me the oven igniter needs to be replaced and the other told me the gas valve. I don't know who to believe or where to start. If the gas valve was bad would the range top and broiler still work properly? Any help you could give me would be greatly appreciated.
Nancy
Ads By Google
Related Models
Amana ARG7600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7600W RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C F/S GAS
Amana ARG7800CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7800E RANGE- S/C S/I DDRAFT GAS
Amana ARG7800LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7800SS RANGE- S/C S/I DDRAFT GAS
Amana ARG7800WW RANGE- S/C S/I DDRAFT GAS
Amana ARGS7650CC RANGE- S/C S/I GAS
Amana ARGS7650E RANGE- S/C S/I GAS
Amana ARGS7650LL RANGE- S/C S/I GAS
Amana ARGS7650SS RANGE- S/C S/I GAS
Amana ARGS7650WW RANGE- S/C S/I GAS
Amana ARH660 RANGE- S/C S/I DDRAFT GAS
Amana ARH660 RANGE- S/C S/I DDRAFT ELE
Amana ARH660HR RANGE- S/C S/I DDRAFT ELE
Amana ARH664E RANGE- S/C S/I DDRAFT ELE
Amana ARH664WW RANGE- S/C S/I DDRAFT ELE
Amana ARH665E RANGE- S/C S/I DDRAFT ELE
Amana ARH665WW RANGE- S/C S/I DDRAFT ELE
Amana ARH667E RANGE- S/C F/S ELE
Amana ARH667WW RANGE- S/C S/I DDRAFT ELE
Amana ARH6700E RANGE- S/C S/I DDRAFT GAS
Amana ARH6700E RANGE- S/C F/S ELE
Amana ARH6700LL RANGE- S/C S/I DDRAFT GAS
Amana ARH6700LL RANGE- S/C F/S ELE
Amana ARH6700WW RANGE- S/C S/I DDRAFT GAS
Amana ARH6710E RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 12-16-2008, 01:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Nancy,
Most likely the problem is a bad oven igniter but there is a small (about 5%) chance the gas valve is bad too. I would recommend to replace the igniter first.
- The part number for the Bake igniter is Part number: AP172397
You can use the mounting bracket from the old igniter.
Call the customer service (877-477-7278) for ETA on this part.
Here are the break down diagrams for the Amana range Model ARG7600LL
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-18-2008, 06:28 PM
Junior Member
Question
Gene-
Thanks for your help. One more question. If we lightly tap on the gas valve the oven ignites. Would that make your answer to the problem any different?
  #4 (permalink)
Old 12-18-2008, 10:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can learn how the igniter and gas valve work from one of our previous posts: Oven won't lite?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
