Discuss
oven control problem
 in
I recently wrote about a problem with the oven control. There was no response to the up arrow touch pad
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven control problem
  #1 (permalink)
Old 02-16-2011, 10:44 AM
Junior Member
icandoitto is on a distinguished road
Question oven control problem
Model Number: 629.45769   Brand: Kenmore   Age: More than 10 years
I recently wrote about a problem with the oven control. There was no response to the up arrow touch pad for the oven and broiler temp control. When the oven temp is pushed the display read 000. When the oven temp up arrow was pushed nothing happened. Push the down arrow is pushed the temp read 350. from this point I could decrease the temp but not increase. Similarly pressing the broil button the display showed 000. Press the up arrow and no response. Press the down arrow and the display reads LO broil.
I was advised to replace the clock part 12001607 . Ordered from you folks and got terrific response (two days). Just installed it and when I touch the oven temp or broil buttons I get an F3 error message. Have tried turning off the power and restarting several times and continue to get the F3 message.
Would appreciate any thoughts you might offfer.
Related Models
Maytag 629.45769 KENMORE COOKING
Maytag 629.46775 KENMORE COOKING
Maytag 629.46776 KENMORE COOKING
Maytag 629.46779 KENMORE COOKING
Jenn-Air 629.46965 RANGE- S/C S/I DDRAFT ELE
Jenn-Air 629.46969 RANGE- S/C S/I DDRAFT ELE
Hardwick 629.70131 RANGE- F/S STD GAS
Hardwick 629.70138 RANGE- F/S STD GAS
Hardwick 629.70231 RANGE- F/S STD GAS
Hardwick 629.70238 RANGE- F/S STD GAS
Jenn-Air 629.80515 MISC / ACCESSORY
Jenn-Air 629.80519 MISC / ACCESSORY
Kenmore 62912103 COOKTOPS
Kenmore 62912104 COOKTOPS
Kenmore 62920245 ELECTRIC/GAS SLIDE-IN RANGE
Kenmore 62921136 Built-In Oven, Electric
Kenmore 62921137 Built-In Oven, Electric
Kenmore 62921238 WALL OVEN
Kenmore 62921239 WALL OVEN
Kenmore 62921336 WALL OVEN
Kenmore 62922001 COOKTOP
Kenmore 62922112 COOKTOPS
Kenmore 62922113 COOKTOPS
Kenmore 62922114 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922115 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922116 ELECTRIC COOKTOP
Kenmore 62922401 COOKTOP
Kenmore 62942015 COIL MODULE
Kenmore 62942019 COIL MODULE
Kenmore 62942025 GLASS CARTRIDGE
Kenmore 62942029 GLASS CARTRIDGE
Kenmore 62942032 GRIDDLE MODULE
Kenmore 62942035 GRILL COVER
Kenmore 62942039 GRILL COVER
Kenmore 62942765 ELECTRIC COOKTOP
Kenmore 62942769 ELECTRIC COOKTOP
Kenmore 62942865 ELECTRIC COOKTOP
Kenmore 62942869 ELECTRIC COOKTOP
Kenmore 62942975 COUNTER UNIT
Kenmore 62942975790 COUNTER UNIT
Kenmore 62942979 COUNTER UNIT
Kenmore 62942979790 COUNTER UNIT
Kenmore 6294576 ELECTRIC SLIDE-IN RANGE
Kenmore 62945765 ELECTRIC RANGE
Kenmore 62945765690 ELECTRIC RANGE
Kenmore 62945765790 ELECTRIC RANGE
Kenmore 62945766790 ELECTRIC RANGE
Kenmore 62945769790 ELECTRIC RANGE
Kenmore 62945775 KENMORE COOKING
Kenmore 62945776 KENMORE COOKING
Kenmore 62945779 KENMORE COOKING
Kenmore 62946775690 ELECTRIC RANGE
Kenmore 62946775790 ELECTRIC RANGE
Kenmore 62946776790 ELECTRIC RANGE
Kenmore 62946779790 ELECTRIC RANGE
Kenmore 62946795 ELECTRIC RANGE
Kenmore 62946796 ELECTRIC RANGE
Kenmore 62946799 ELECTRIC RANGE
Kenmore 62946965 ELECTRIC RANGE
Kenmore 62946969 ELECTRIC RANGE
Kenmore 6294697 ELECTRIC RANGE
Kenmore 62946975 WIRING DIAGRAM-RANGE
Kenmore 62946979 WIRING DIAGRAM-RANGE
Kenmore 62960002600 KENMORE COOKING
Kenmore 62960002601 KENMORE COOKING
Kenmore 62960002606 ELECTRIC RANGE
Kenmore 62960003600 KENMORE COOKING
Kenmore 62960008600 KENMORE COOKING
Kenmore 62960008601 KENMORE COOKING
Kenmore 62960008606 ELECTRIC RANGE
Kenmore 62960009600 KENMORE COOKING
Kenmore 62960009601 KENMORE COOKING
Kenmore 62960009606 ELECTRIC RANGE
Kenmore 62970131 GAS RANGE
Kenmore 62970138 GAS RANGE
Kenmore 62990131 ELECTRIC RANGE
Kenmore 62990138 ELECTRIC RANGE
Kenmore 629CG200 GAS COOKTOP
Magic Chef 62S14XAA RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAS RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAW RANGE- S/I CONT CLEAN GAS
Hoover 63
Amana 630.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.002 RANGE- S/C S/I DDRAFT GAS
Amana 630.003 RANGE- S/C S/I DDRAFT GAS
Frigidaire 6307B WASHER
Frigidaire 6308A WASHER
Frigidaire 6309A WASHER
Amana 631.000 RANGE- S/C S/I DDRAFT GAS
Amana 631.001 RANGE- S/C S/I DDRAFT GAS
Amana 631.002 RANGE- S/C S/I DDRAFT GAS
Amana 631.003 RANGE- S/C S/I DDRAFT GAS
Amana 631.004 RANGE- S/C S/I DDRAFT GAS
Amana 631.006 RANGE- S/C S/I DDRAFT GAS
Amana 632-3J ROOM AIR CONDITIONER
Frigidaire 6337B WASHER
Frigidaire 6338A WASHER
Frigidaire 6339A WASHER
Hoover 634
Frigidaire 6347B WASHER
Frigidaire 6348A WASHER
Frigidaire 6358A WASHER
Frigidaire 6389-80A WASHER
Frigidaire 6389-80B WASHER
Frigidaire 6389-87A WASHER
Frigidaire 6389-87B WASHER
Hoover 64
Maytag 640C DRYER- GAS
Maytag 640W DRYER- GAS
Magic Chef 6458XRA RANGE- S/C S/I GAS
Magic Chef 6458XRS RANGE- S/C S/I GAS
Magic Chef 6458XRW RANGE- S/C S/I GAS
Magic Chef 6458XTA RANGE- S/C S/I GAS
Magic Chef 6458XTS RANGE- S/C S/I GAS
Magic Chef 6458XTW RANGE- S/C S/I GAS
Kenmore 6476037210 KENMORE 30 IN GAS RANGE
Kenmore 6476037220 KENMORE 30 IN GAS RANGE
Kenmore 6476037240 KENMORE 30 IN GAS RANGE
  #2 (permalink)
Old 02-17-2011, 05:07 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I could not find any tech info on your specific model.
The 629 does tell us that it was made by Maytag.
When I look up fault codes the most common F3 for Maytags is an oven sensor problem so that is where I would start. Perhaps you did not get the plug seated correctly on the new control board.
Here is a link, check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
__________________
  #3 (permalink)
Old 02-17-2011, 06:44 PM
Junior Member
Default Problem solved
Thanks for your reply . I went back in and rchecked the seating of the plugs and it did the trick
  #4 (permalink)
Old 02-18-2011, 03:53 AM
Senior Expert
APP Volunteer
Default
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven control problem PatinKY Oven Repair (including Ranges and Cooktops) 2 01-09-2011 12:08 PM
Oven Control Display Problem scottishlad Oven Repair (including Ranges and Cooktops) 0 08-02-2009 07:24 AM
Oven Control problem drhydro04 Oven Repair (including Ranges and Cooktops) 0 04-03-2009 07:42 AM
Oven control problem - HELP!! razorblade Oven Repair (including Ranges and Cooktops) 1 12-31-2008 06:06 AM
Oven Control Problem griggmi Oven Repair (including Ranges and Cooktops) 1 11-10-2007 07:43 PM
