Discuss
Thermador Wall Oven - self clean not working
 in
My nearly 10 year old Thermador Wall oven is having issues again with the control panel. I have had the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Thermador Wall Oven - self clean not working
  #1 (permalink)
Old 12-15-2008, 11:17 AM
myvineyardtwins myvineyardtwins is offline
Junior Member
myvineyardtwins is on a distinguished road
Default Thermador Wall Oven - self clean not working
Model Number: SCD?   Brand: Thermador   Age: 5 - 10 years
My nearly 10 year old Thermador Wall oven is having issues again with the control panel. I have had the control panel replaced three times (first time was under warranty) because it dimmed over time or the touch pad was not functioning properly. I had the control in the panel replaced last year and just went to clean my oven and the self clean feature does not function. It lights up "self clean" but nothing happens. Is this another problem with the control panel?
I am unable to locate the model number for my oven on the oven itself. Anyone know where it is?
Related Models
Amana SCDE25J Ref - SXS/I&W
Amana SCDT20H Ref - SXS/I&W
Amana SCDT22H Ref - SXS/I&W
Amana SCDT25H Ref - SXS/I&W
Jenn-Air SCE30500B Range - S/c S/i Ele
Jenn-Air SCE30500W Range - S/c S/i Ele
Jenn-Air SCE30600B Range - S/c S/i Ele
Jenn-Air SCE30600BC Range - S/c S/i Ele
Jenn-Air SCE30600W Range - S/c S/i Ele
Jenn-Air SCE30600WC Range - S/c S/i Ele
Jenn-Air SCE4320B Range - S/c S/i Ele
Jenn-Air SCE4320W Range - S/c S/i Ele
Jenn-Air SCE4340B Range - S/c S/i Ele
Jenn-Air SCE4340B-C Range - S/c S/i Ele
Jenn-Air SCE4340W Range - S/c S/i Ele
Jenn-Air SCE4340W-C Range - S/c S/i Ele
Jenn-Air SCE70600B Range - S/c S/i Ele
Jenn-Air SCE70600W Range - S/c S/i Ele
Whirlpool SCF0710HQ00
Whirlpool SCF0710HQ01
Whirlpool SCF0710HW00
Whirlpool SCF0710HW01
Whirlpool SCF0710HW05
Whirlpool SCF0710KQ00
Whirlpool SCF0710KQ01
Whirlpool SCF0710KQ02 Chest Freezer
Whirlpool SCF0710KQ03 Chest Freezer
Whirlpool SCF0710KQ04 Chest Freezer
Whirlpool SCF1510HW00
Whirlpool SCF1510HW02
Whirlpool SCF1510HW05
Jenn-Air SCG20200A Range - S/c S/i Gas
Jenn-Air SCG20200B Range - S/c S/i Gas
Jenn-Air SCG20200W Range - S/c S/i Gas
Thermador SCM-1
Whirlpool SCS3004GN0
Whirlpool SCS3004GN1
Whirlpool SCS3004GS0
Whirlpool SCS3004GS1
Whirlpool SCS3004GS2
Whirlpool SCS3004GV1
Whirlpool SCS3004GV2
Whirlpool SCS3004GW0
Whirlpool SCS3004GW1
Whirlpool SCS3004GW2
Whirlpool SCS3004LW0
Whirlpool SCS3004LW01 30" Gas Cooktop
Whirlpool SCS3014GB0
Whirlpool SCS3014GB1
Whirlpool SCS3014GB2
Whirlpool SCS3014GB3
Whirlpool SCS3014GQ0
Whirlpool SCS3014GQ1
Whirlpool SCS3014GQ2
Whirlpool SCS3014GQ3
Whirlpool SCS3014GS0
Whirlpool SCS3014GS1
Whirlpool SCS3014GS2
Whirlpool SCS3014GS3
Whirlpool SCS3014GT1
Whirlpool SCS3014GT2
Whirlpool SCS3014GT3
Whirlpool SCS3014GZ0
Whirlpool SCS3014GZ1
Whirlpool SCS3014LB0
Whirlpool SCS3014LB01 30" Gas Cooktop
Whirlpool SCS3014LB02 30" Gas Cooktop
Whirlpool SCS3014LQ0
Whirlpool SCS3014LQ01 30" Gas Cooktop
Whirlpool SCS3014LQ02 30" Gas Cooktop
Whirlpool SCS3014LS0
Whirlpool SCS3014LS01 30" Gas Cooktop
Whirlpool SCS3014LS02 30" Gas Cooktop
Whirlpool SCS3014LT0
Whirlpool SCS3014LT01 30" Gas Cooktop
Whirlpool SCS3014LT02 30" Gas Cooktop
Whirlpool SCS3017RB00 30" Gas Cooktop
Whirlpool SCS3017RB01 30" Gas Cooktop
Whirlpool SCS3017RB02 30" Gas Cooktop
Whirlpool SCS3017RB03 30" Gas Cooktop
Whirlpool SCS3017RQ00 30" Gas Cooktop
Whirlpool SCS3017RQ01 30" Gas Cooktop
Whirlpool SCS3017RQ02 30" Gas Cooktop
Whirlpool SCS3017RQ03 30" Gas Cooktop
Whirlpool SCS3017RS00 30" Gas Cooktop
Whirlpool SCS3017RS01 30" Gas Cooktop
Whirlpool SCS3017RS02 30" Gas Cooktop
Whirlpool SCS3017RS03 30" Gas Cooktop
Whirlpool SCS3017RT00 30" Gas Cooktop
Whirlpool SCS3017RT01 30" Gas Cooktop
Whirlpool SCS3017RT02 30" Gas Cooktop
Whirlpool SCS3017RT03 30" Gas Cooktop
Whirlpool SCS3514GB1
Whirlpool SCS3614GB0
Whirlpool SCS3614GB1
Whirlpool SCS3614GB2
Whirlpool SCS3614GB3
Whirlpool SCS3614GQ0
Whirlpool SCS3614GQ1
Whirlpool SCS3614GQ2
Whirlpool SCS3614GQ3
Whirlpool SCS3614GS0
Whirlpool SCS3614GS1
Whirlpool SCS3614GS2
Whirlpool SCS3614GS3
Whirlpool SCS3614GT1
Whirlpool SCS3614GT2
Whirlpool SCS3614GT3
Whirlpool SCS3614GZ0
Whirlpool SCS3614GZ1
Whirlpool SCS3614LB0
Whirlpool SCS3614LB01 36" Gas Cooktop
Whirlpool SCS3614LB02 36" Gas Cooktop
Whirlpool SCS3614LQ0
Whirlpool SCS3614LQ01 36" Gas Cooktop
Whirlpool SCS3614LQ02 36" Gas Cooktop
Whirlpool SCS3614LS0
Whirlpool SCS3614LS01 36" Gas Cooktop
Whirlpool SCS3614LS02 36" Gas Cooktop
Whirlpool SCS3614LT0
  #2 (permalink)
Old 12-19-2008, 09:51 PM
Servicer Servicer is offline
Senior Expert
APP Volunteer
Servicer is on a distinguished road
Default
The data tag is located in the vents to the left or right of the latch arm of the upper oven.
What happens after you set the time? Does the door lock, or does the fan run?
  #3 (permalink)
Old 12-20-2008, 05:37 AM
Junior Member
Default
Wow, would have never thought to look there...it's SC301TP.
After I set the time, the door does not lock but the fan runs.
  #4 (permalink)
Old 12-20-2008, 06:53 AM
Senior Expert
APP Volunteer
Default
The oven has to latch before the unit can heat up in the clean cycle.
If you would like to diagnose it yourself, you would need to slide the oven forward about 10" so you can remove the black access cover on top of the oven.
Once the top is removed you'll have access to the relay board. One the front left corner of the relay board you'll find a terminal labeled, "DRLK". This terminal is where the 120vac which runs that latch leaves the board. If you're comfortable with working with electricity you can measure for 120vac on this terminal when you start a self clean cycle. If there is no power there the board is the problem. If the power is there the latch is bad. You can also jump 120v to that wire to see if the latch runs. To do this, you'll need to touch the wire on the DRLK to a on one of the terminals labeled L2; be careful not to electrocute yourself if you decide to do this. Obviously, if the latch runs it's good. If not, the it's bad.
Part numbers:
Relay Board: 492069
I'm assuming one of the parts you've had installed was the 492067 display kit. If so, this is the relay board from that kit. If you find that this kit has yet to be installed it will need to be ordered instead of the 492069. The reason is that the kit relay board from the kit and the display which is not sold in this kit are not compatible.
Lock: 489102
This is also a redesigned part (not because of motor issues), and rather than having two switches it will have three. There may be a new wiring diagram with the new part, but I've found that most do not. If you end up ordering the latch and need help with the wiring let me know and I'll tell you how to wire it.
Good Luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador oven self clean F2 error code Vic C Oven Repair (including Ranges and Cooktops) 0 01-09-2010 11:44 AM
Need help with Thermador wall oven kshaase Oven Repair (including Ranges and Cooktops) 0 11-23-2009 11:25 AM
Thermador oven will not Bake,only Broil and Self-clean pjflirty Oven Repair (including Ranges and Cooktops) 0 06-28-2009 08:23 AM
Thermador Double Oven No self clean top JWLloyd Oven Repair (including Ranges and Cooktops) 3 05-11-2009 04:18 PM
Thermador wall oven bartt21999 Oven Repair (including Ranges and Cooktops) 0 10-30-2007 10:23 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
