craigdblom
#1 Posted : Sunday, December 14, 2008 6:38:26 PM(UTC)
craigdblom
My GE electric oven (model # J BP78G S2BB) will preheat perfectly, but the temperature drops steadily without reheating to maintain temperature.
If I turn the oven off every few minutes, then reset the temp dial, it will keep baking (the heating elements will produce heat until the proper temperature is reached). If I don't keep doing this the oven just steadily cools.
I have a medium amount of electrical knowledge. I can do some basic stuff with a volt-ohm meter. I am trying to decide whether to attempt a repair myself, or just buy a new oven/range. I don't want to end up replacing all the possible problem parts then also end up paying as much as purchasing a new oven. Similarly, I suspect that paying a repairman to come out and fix it will cost a significant percentage of a brand new appliance.
I was hoping it would be something as simple as replacing a relay - but I'm not sure this oven uses one to regulate the temperature.
Anyone willing to help me take this on?
#2 Posted : Monday, December 15, 2008 7:53:14 PM(UTC)
Most likely the problem is a bad control board which has to be replaced together with the face plate according to the manufacturer instructions.
- The part number for the control board is AP2026779
- The part number for the face plate is AP2025969
craigdblom
#3 Posted : Tuesday, December 16, 2008 4:22:57 AM(UTC)
craigdblom
First I want to say thanks very much for the help.
Is there a way I can test the control board to be sure that is the problem before I replace the parts?
AND
Are there other likely causes if that doesn't do the job?
craigdblom
#4 Posted : Tuesday, December 16, 2008 4:27:30 AM(UTC)
craigdblom
AND
#5 Posted : Tuesday, December 16, 2008 6:49:23 PM(UTC)
I do no think it is possible to diagnose the electronic control board without very special equipment and the complete technical specifications.
I do not see anything else what can cause such problem.
craigdblom
#6 Posted : Tuesday, December 16, 2008 7:33:46 PM(UTC)
craigdblom
Thanks, Gene, for taking the time to help.
Much appreciated.
