Discuss
Kenmore Range Hood Light Not Working
 in
I have a Kenmore Range Vent Hood that the light is not working on. The vent comes on and works
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Range Hood Light Not Working
  #1 (permalink)
Old 02-14-2011, 07:40 PM
Junior Member
rgodsey is on a distinguished road
Default Kenmore Range Hood Light Not Working
Model Number: 23352445590   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore Range Vent Hood that the light is not working on. The vent comes on and works fine for most uses (one time last week it went off after being on for a long time while I was cooking). The main issue is the lights, though.
I read on some other forums about this problem and suspect it is the switch assembly (which might fix the blower as well), however I don't readily see how to remove it to test for continuity. Any guidance is appreciated!!
  1. Is the switch assembly most likley the problem?
  2. Are there other potential problems?
  3. How do I access the switch for removal, testing, and installation?
Thank you!
Related Models
Kenmore 23352445590 RANGE HOOD
Kenmore 23352449590 RANGE HOOD
Kenmore 2335247810 RANGE HOOD
Kenmore 2335247811 RANGE HOOD
Kenmore 2335248510 RANGE HOOD
Kenmore 2335248910 RANGE HOOD
Kenmore 2335249590 RANGE HOOD
Kenmore 23352540590 RANGE HOOD
Kenmore 23352544590 RANGE HOOD
Kenmore 23352545590 RANGE HOOD
Kenmore 23352549590 RANGE HOOD
Kenmore 2335257810 RANGE HOOD
Kenmore 2335257811 RANGE HOOD
Kenmore 2335258510 RANGE HOOD
Kenmore 2335258910 RANGE HOOD
Kenmore 2335259590 RANGE HOOD
Kenmore 23352602000 RANGE HOOD
Kenmore 23352603000 RANGE HOOD
Kenmore 23352604000 RANGE HOOD
Kenmore 23352607000 RANGE HOOD
Kenmore 23352609000 RANGE HOOD
Kenmore 23352612000 RANGE HOOD
Kenmore 23352613000 RANGE HOOD
Kenmore 23352614000 RANGE HOOD
Kenmore 23352617000 RANGE HOOD
Kenmore 23352619000 RANGE HOOD
Kenmore 23352702000 RANGE HOOD
Kenmore 23352703000 RANGE HOOD
Kenmore 23352704000 RANGE HOOD
Kenmore 23352707000 RANGE HOOD
Kenmore 23352709000 RANGE HOOD
Kenmore 23352712000 RANGE HOOD
Kenmore 23352713000 RANGE HOOD
Kenmore 23352714000 RANGE HOOD
Kenmore 23352717000 RANGE HOOD
Kenmore 23352719000 RANGE HOOD
Kenmore 23353244591 RANGE HOOD
Kenmore 23353245590 RANGE HOOD
Kenmore 23353245591 RANGE HOOD
Kenmore 23353248591 RANGE HOOD
Kenmore 23353344591 RANGE HOOD
Kenmore 23353345590 RANGE HOOD
Kenmore 23353345591 RANGE HOOD
Kenmore 23353348591 RANGE HOOD
Kenmore 23353349591 RANGE HOOD
Kenmore 23353363 RANGE HOOD
Kenmore 2335337810 KENMORE RANGE HOOD
Kenmore 2335337811 KENMORE RANGE HOODS
Kenmore 2335337812 KENMORE RANGE HOOD
Kenmore 2335337813 KENMORE RANGE HOOD
Kenmore 2335338910 KENMORE RANGE HOOD
Kenmore 2335338911 RANGE HOOD
Kenmore 2335338912 RANGE HOOD
Kenmore 23354060591 KENMORE RANGE HOOD
Kenmore 23354065591 KENMORE RANGE HOOD
Kenmore 23354066591 KENMORE RANGE HOOD
Kenmore 23354069591 KENMORE RANGE HOOD
Kenmore 23354363200 RANGE HOOD
Kenmore 2335437810 KENMORE RANGE HOOD
Kenmore 2335437811 KENMORE RANGE HOODS
Kenmore 2335447810 KENMORE RANGE HOOD
Kenmore 2335447811 KENMORE RANGE HOODS
Kenmore 23354800010 RANGE HOOD
Kenmore 23354810010 RANGE HOOD
Kenmore 23354820010 RANGE HOOD
Kenmore 23354830010 RANGE HOOD
Kenmore 23354840010 RANGE HOOD
Kenmore 23355012000 RANGEHOOD
Kenmore 23355013000 RANGEHOOD
Kenmore 23355014000 RANGEHOOD
Kenmore 23355017000 RANGE HOOD
Kenmore 23355019000 RANGEHOOD
Kenmore 23355022000 RANGE HOOD
Kenmore 23355023000 RANGE HOOD
Kenmore 23355024000 RANGE HOOD
Kenmore 23355027000 RANGE HOOD
Kenmore 23355029000 RANGE HOOD
Kenmore 23355112000 RANGEHOOD
Kenmore 23355113000 RANGEHOOD
Kenmore 23355114000 RANGEHOOD
Kenmore 23355117000 RANGE HOOD
Kenmore 23355119000 RANGEHOOD
Kenmore 23355122000 RANGE HOOD
Kenmore 23355123000 RANGE HOOD
Kenmore 23355124000 RANGE HOOD
Kenmore 23355127000 RANGE HOOD
Kenmore 23355129000 RANGE HOOD
Kenmore 23355212000 RANGEHOOD
Kenmore 23355213000 RANGEHOOD
Kenmore 23355214000 RANGEHOOD
Kenmore 23355217000 RANGE HOOD
Kenmore 23355219000 RANGEHOOD
Kenmore 23355222000 RANGE HOOD
Kenmore 23355223000 RANGE HOOD
Kenmore 23355224000 RANGE HOOD
Kenmore 23355227000 RANGE HOOD
Kenmore 23355229000 RANGE HOOD
Kenmore 23355345590 RANGE HOOD
Kenmore 23355359591 RANGE HOOD
Kenmore 2335537910 RANGE HOODS
Kenmore 2335537911 KENMORE RANGE HOODS
Kenmore 2335538090 KENMORE RANGE HOOD
Kenmore 2335538590 KENMORE RANGE HOOD
Kenmore 2335538610 KENMORE RANGE HOOD
Kenmore 2335538910 RANGE HOOD
Kenmore 2335538911 RANGE HOOD
Kenmore 2335538912 RANGE HOOD
Kenmore 23355445590 RANGE HOOD
Kenmore 2335547910 RANGE HOODS
Kenmore 2335547911 KENMORE RANGE HOODS
Kenmore 2335548090 KENMORE RANGE HOOD
Kenmore 2335548590 KENMORE RANGE HOOD
Kenmore 2335548910 RANGE HOOD
Kenmore 2335548911 RANGE HOOD
Kenmore 2335548912 RANGE HOOD
Kenmore 23355545590 RANGE HOOD
Kenmore 2335558910 RANGE HOOD
Kenmore 2335558911 RANGE HOOD
Kenmore 2335558912 RANGE HOOD
Kenmore 2335607510 KENMORE DELUXE CANOPY RANGE HOOD
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing GE Range Hood fan & light switch sheshi Oven Repair (including Ranges and Cooktops) 0 01-24-2011 05:03 PM
R&R light sw. on a range hood quincyguy Oven Repair (including Ranges and Cooktops) 2 04-10-2010 06:11 PM
light fixture for range hood cehender Oven Repair (including Ranges and Cooktops) 0 07-28-2008 08:05 PM
Range Hood Light Cover - Where to Buy? Tanu Oven Repair (including Ranges and Cooktops) 0 05-17-2008 01:34 PM
Range hood,light cover ZippyDSMlee Oven Repair (including Ranges and Cooktops) 1 05-16-2008 03:54 PM
