Discuss
Assistance with Temperature Calibration
 in
I have a Tappan gas oven (model 12-2299-10/06) which was installed over 18 years old. Within the past 6 months,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Assistance with Temperature Calibration
  #1 (permalink)
Old 02-13-2011, 06:15 PM
Junior Member
hiosilv4 is on a distinguished road
Default Assistance with Temperature Calibration
Model Number: 12-2299-10/06   Brand: Tappan   Age: More than 10 years
I have a Tappan gas oven (model 12-2299-10/06) which was installed over 18 years old. Within the past 6 months, the oven is not reaching the desired temperature. According to the thermometer I placed inside the oven, the temperature is off 50 degrees (too low).
For over 2 hours tonight, I made an attempt to recalibrate the temperature. After pulling off the control dial, the two small screws on opposite side were exposed. I turned the screws either clockwise and/or counterclockwise and waited 15 minutes to see if the temperature increased. I tried different variations to the screw adjustment procedure. Unfortunately, I was not successful in achieving the temperature noted on the inside oven thermometer. I learned about the calibration procedure by searching the Internet. However, the instructions about what direction to turn the screws varied from one tech to another.
At this time, I'm ready to leave the temperature calibration fixes to a pro. Does anyone have a service or owner's manual for my oven? Is calibration a difficult task? I think so! I also understand the temperature issue could be related to a broken part.
Any assistance you can offer would be greatly appreciated!
Ads By Google
Related Models
Amana 12-2MW ROOM AIR CONDITIONER
Amana 12-2N ROOM AIR CONDITIONER
Amana 12-2NM ROOM AIR CONDITIONER
Frigidaire 12-3219-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-3699-00-05 Tap(v1) / Gas Wall Oven
Frigidaire 12-3883-00-01 Tap(v11) / Gas Range
Frigidaire 12-3883-23-01 Tap(v12) / Gas Range
Frigidaire 12-3883-45-01 Tap(v13) / Gas Range
Frigidaire 12-3883-57-01 Tap(v14) / Gas Range
Frigidaire 12-3883-66-01 Tap(v15) / Gas Range
Frigidaire 12-3893-00-01 Tap(v11) / Gas Range
Frigidaire 12-3893-23-01 Tap(v12) / Gas Range
Frigidaire 12-3893-45-01 Tap(v13) / Gas Range
Frigidaire 12-3893-57-01 Tap(v14) / Gas Range
Frigidaire 12-3893-66-01 Tap(v15) / Gas Range
Amana 12-3G ROOM AIR CONDITIONER
Amana 12-3GH ROOM AIR CONDITIONER
Amana 12-3GM ROOM AIR CONDITIONER
Amana 12-3J ROOM AIR CONDITIONER
Amana 12-3JH ROOM AIR CONDITIONER
Amana 12-3JM ROOM AIR CONDITIONER
Frigidaire 12-4980-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-4980-00-05 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-01 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-02 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-03 Tap(v1) / Gas Wall Oven
Frigidaire 12-4990-00-04 Tap(v1) / Gas Wall Oven
Frigidaire 12-5063-00-04 Tap(v16) / Gas Range
Frigidaire 12-5063-00-05 Tap(v17) / Gas Range
Frigidaire 12-5063-23-04 Tap(v18) / Gas Range
Frigidaire 12-5063-23-05 Tap(v19) / Gas Range
Frigidaire 12-5063-45-04 Tap(v20) / Gas Range
Frigidaire 12-5063-45-05 Tap(v21) / Gas Range
Frigidaire 12-5063-57-04 Tap(v22) / Gas Range
Frigidaire 12-5063-57-05 Tap(v23) / Gas Range
Frigidaire 12-5063-66-04 Tap(v24) / Gas Range
Frigidaire 12-5063-66-05 Tap(v25) / Gas Range
Frigidaire 12-5299-00-01 Tap(v2) / Wall Oven
Frigidaire 12-5299-00-02 Tap(v1) / Wall Oven
Frigidaire 12-5299-00-04 Tap(v2) / Wall Oven
Frigidaire 12-6219-00-01 Tap(v2) / Gas Wall Oven
Frigidaire 12-6263-00-01 Tap(v16) / Gas Range
Frigidaire 12-6263-23-01 Tap(v17) / Gas Range
Frigidaire 12-6263-45-01 Tap(v18) / Gas Range
Frigidaire 12-6263-57-01 Tap(v19) / Gas Range
Frigidaire 12-6263-66-01 Tap(v20) / Gas Range
Frigidaire 12-6663-00-01 Tap(v21) / Gas Range
Frigidaire 12-6663-23-01 Tap(v22) / Gas Range
Frigidaire 12-6663-45-01 Tap(v23) / Gas Range
Frigidaire 12-6663-57-01 Tap(v24) / Gas Range
Frigidaire 12-6663-66-01 Tap(v25) / Gas Range
Frigidaire 12-6699-00-01 Tap(v2) / Gas Wall Oven
Amana 120.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 120.001 MWAVE - FAMILY SIZE (60 HZ)
Maytag 12001294 MISC / ACCESSORY
Maytag 12001302 MISC / ACCESSORY
Maytag 12001685 MISC / ACCESSORY
Maytag 12001686 MISC / ACCESSORY
Maytag 12001687 MISC / ACCESSORY
Maytag 12001688 MISC / ACCESSORY
Maytag 12001747 MISC / ACCESSORY
General Electric 1200L02 DISHWASHER
Thermador 1201
Thermador 1205
Jenn-Air 12103 SURFACE UNIT- DDRAFT GAS
Jenn-Air 12104 SURFACE UNIT- DDRAFT GAS
Roper 1213*2A GAS RANGE
Roper 1213*3A GAS RANGE
Roper 1213W1A GAS RANGE
Roper 1213Z2A GAS RANGE
Roper 1213Z3A GAS RANGE
Roper 1215*0A GAS RANGE
Roper 1215*1A GAS RANGE
Roper 1215W0A GAS RANGE
Roper 1215W1A GAS RANGE
Roper 1225*0A GAS RANGE
Roper 1225*1A GAS RANGE
Roper 1225*2A GAS RANGE
Roper 1225*3A GAS RANGE
Roper 1225W1A GAS RANGE
Roper 1225W2A GAS RANGE
Roper 1225W3A GAS RANGE
Roper 1233*0A GAS RANGE
Roper 1233*1A GAS RANGE
Roper 1233*2A GAS RANGE
Roper 1233Z1A GAS RANGE
Roper 1233Z2A GAS RANGE
Roper 1234*0A GAS RANGE
Whirlpool 1234W0A
Whirlpool 1234^0A
Roper 1235*0A GAS RANGE
Roper 1235*1A GAS RANGE
Roper 1235W0A GAS RANGE
Roper 1235W1A GAS RANGE
Frigidaire 1236B DISHWASHER
Frigidaire 1236C DISHWASHER
Roper 1245*0A GAS RANGE
Roper 1245*1A GAS RANGE
Roper 1245*2A GAS RANGE
Roper 1245*3A GAS RANGE
Maytag 12500048 MISC / ACCESSORY
Roper 1255*0A GAS RANGE
Roper 1255*1A GAS RANGE
Roper 1255*2A GAS RANGE
Roper 1255*3A GAS RANGE
Admiral 1255AF-CLW WALLOVEN- S/C ELE
Admiral 1255AF-CLZ WALLOVEN- S/C ELE
  #2 (permalink)
Old 02-13-2011, 06:21 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
are you reading your oven thermometer after preheat, if so check your thermometer 20 minutes after preheat, this will give you a pretty good idea of the temp, as these thermometers are not very acurate. Next the 2 screws on the back of the knob should be loose then you should be able to rotate the inner dial to increase or decrease the temp, but I believe only 35 degrees in either direction, not 50
__________________
  #3 (permalink)
Old 02-13-2011, 06:22 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
one more thing, taking a temp reading takes time and patience. 15 minutes is not long enough to get a true oven temp reading
__________________
  #4 (permalink)
Old 02-13-2011, 06:47 PM
Junior Member
Default
Quote:
Thanks for your quick reply! I'm checking temperature after preheat. It's definitely off 50 degress --too low. I now understand the screw loosening/dial turning process. I'm going to make a few more attempts tonight and remember that being patient is a key element.
  #5 (permalink)
Old 02-13-2011, 06:50 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
Let the oven preheat, then check you oven thermometer 20 minutes after it has preheated. this will give you your best temp reading....let us know what you find.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need to replace gas thermostat, or is calibration possible? strawbale Oven Repair (including Ranges and Cooktops) 1 08-24-2010 01:42 PM
Oven Calibration squier3 Oven Repair (including Ranges and Cooktops) 1 02-03-2010 03:51 AM
barb the calibration tech Barbara Edgar Refrigerator & Freezer Repair 4 10-02-2009 10:07 AM
calibration of oven temp rg4656 Oven Repair (including Ranges and Cooktops) 0 04-04-2008 12:11 PM
Oven calibration CHARLES EALLONARDO Oven Repair (including Ranges and Cooktops) 0 09-06-2007 06:29 PM
