Appliance Repair Forum
-   Oven Repair (including Ranges and Cooktops) (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/)
-   -   how to lift cooktop (http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/172610-how-lift-cooktop.html)
hilly 02-13-2011 04:34 PM
how to lift cooktop
ordered replacement heat indicator light. how do i lift the top to replace the light?? thanks.
denman 02-14-2011 05:45 AM
1 Attachment(s)
Not sure what light you are replacing.
Looks like the heat indicators are nixies which are pretty reliable.
So if it is an element on indicator then if the light does not fix it you will need a new infinite switch.
The attached should help you with the install.
