Discuss
oven temperature gets higher and higher
 in
Hi My wall oven was taking too long to heat up and the temperature was fluctuating all over the place.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven temperature gets higher and higher
  #1 (permalink)
Old 02-12-2011, 02:44 PM
Junior Member
susanshann is on a distinguished road
Default oven temperature gets higher and higher
Brand: Kitchen Aid   Age: 5 - 10 years
Hi
My wall oven was taking too long to heat up and the temperature was fluctuating all over the place. Things were taking too long to cook and raw in the centre. After reading the responses on this site I replaced the oven sensor.
The first time I used it, after setting the temperature at 350 F the oven just got hotter and hotter. I turned it off at 475F (measured on a separate oven thermometer). There is no error message and everything else seems to work.
Please suggest what I should do next. Is it the sensor or something else?
Many thanks
Sue
Ads By Google
  #2 (permalink)
Old 02-13-2011, 03:40 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Cannot say.
Following is a good site with info on how to check the sensor.
http://www.applianceaid.com/elecrange.html
See 7, 8, 20 and 21.
If the sensor is OK then odds are that your control board is toast.
__________________
  #3 (permalink)
Old 02-13-2011, 11:19 AM
Junior Member
Default I give up!
Thanks for your quick response. I've removed the sensor and will try to return it. I fear you are right about the control board. I think i'm finished with this oven. Too many problems. Too expensive to repair.
Cheers
Sue
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My oven temperature is higher than normal gabaldini@gmail.com Oven Repair (including Ranges and Cooktops) 0 05-25-2010 06:04 PM
Oven will not reach higher then 400 degree solkeys Oven Repair (including Ranges and Cooktops) 0 04-11-2010 01:21 PM
oven doesn't heat higher than 375 degrees aml14103 Oven Repair (including Ranges and Cooktops) 5 10-17-2009 05:28 PM
Oven only works at 450° or higher. Jack.Straw Oven Repair (including Ranges and Cooktops) 0 11-17-2008 10:47 AM
oven temp no higher then 200 swilson1224 Oven Repair (including Ranges and Cooktops) 1 12-28-2007 10:51 AM
