| » Light does not work |
Model Number: pleb30s9dca Brand: Frigidaire Age: 1 - 5 years
Waht could the problem be that the lights do not work and I already replaced the bulbs. The oven does work just the lights will not work.
Replacement parts for FRIGIDAIRE PLEB30S9DCA Frigidaire/walloven | AppliancePartsPros.com Here is the wiring diagram http://manuals.frigidaire.com/prodin.../318046224.pdf Looks like the oven lights are controlled by the clock/control board. If the unit has a manual turn on for the lights and that does not work then it could be a wire has burned off or has a bad connection or the control board is toast. If there is no manual turn on then the door switch has to be added to the possible causes.
__________________
| Display Modes | |
| Range Light and Nite light won't work | Bms229 | Microwave Repair | 4 | 12-23-2009 11:22 PM |
| Touchpad light won't work | KAY_57 | Microwave Repair | 2 | 12-23-2009 12:51 PM |
| Light on fan on fridge doesn't work | mikensay | Refrigerator & Freezer Repair | 6 | 08-07-2009 05:27 PM |
| eye won't work, light comes on | ked | Oven Repair (including Ranges and Cooktops) | 1 | 07-11-2009 02:34 PM |
| Blinking light and over does not work | mmsmj | Oven Repair (including Ranges and Cooktops) | 0 | 01-12-2009 10:24 AM |
