Discuss
oven/range top has no heat
 in
there is power to the electronic control unit for our range/oven. Everything indicates that it should be working as it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven/range top has no heat
  #1 (permalink)
Old 02-12-2011, 09:50 AM
Junior Member
jetswalz is on a distinguished road
Angry oven/range top has no heat
Model Number: rf365pxmw1   Brand: Whirlpool   Age: 5 - 10 years
there is power to the electronic control unit for our range/oven. Everything indicates that it should be working as it did the day before but now no burners work. In the oven or on the stove top. The light to the oven doesn't even work. The only thing that works is what's on the control panel (indicator lights, clock, etc). Is this a bad relay or what?
Ads By Google
Related Models
Whirlpool RF365PXMW1 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMW2 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXMW3 30" Electric Freestanding Self Clean Range
Whirlpool RF365PXWN0
Whirlpool RF365PXWW0
Whirlpool RF365PXXN0
Whirlpool RF365PXXN1
Whirlpool RF365PXXN2
Whirlpool RF365PXXW0
Whirlpool RF365PXXW1
Whirlpool RF365PXXW2
Whirlpool RF365PXYN0
Whirlpool RF365PXYN1
Whirlpool RF365PXYN2
Whirlpool RF365PXYQ0
Whirlpool RF365PXYQ1
Whirlpool RF365PXYQ2
Whirlpool RF365PXYW0
Whirlpool RF365PXYW1
Whirlpool RF365PXYW2
Whirlpool RF365PXYZ2
Whirlpool RF3661XDN0
Whirlpool RF3661XDW0
Whirlpool RF3663XDN0
Whirlpool RF3663XDW0
Whirlpool RF366BXDN0
Whirlpool RF366BXDN1
Whirlpool RF366BXDW0
Whirlpool RF366BXDW1
Whirlpool RF366BXVN0
Whirlpool RF366BXVN1
Whirlpool RF366BXVN2
Whirlpool RF366BXVN3
Whirlpool RF366BXVW0
Whirlpool RF366BXVW1
Whirlpool RF366BXVW2
Whirlpool RF366BXVW3
Whirlpool RF366LXKQ0
Whirlpool RF366LXKT0
Whirlpool RF366PXDN0
Whirlpool RF366PXDQ0
Whirlpool RF366PXDW0
Whirlpool RF366PXDZ0
Whirlpool RF366PXGN0
Whirlpool RF366PXGN1
Whirlpool RF366PXGQ0
Whirlpool RF366PXGQ1
Whirlpool RF366PXGQ2
Whirlpool RF366PXGT1
Whirlpool RF366PXGT2
Whirlpool RF366PXGW0
Whirlpool RF366PXGW1
Whirlpool RF366PXGW2
Whirlpool RF366PXXB0
Whirlpool RF366PXXB1
Whirlpool RF366PXXB2
Whirlpool RF366PXXN0
Whirlpool RF366PXXN1
Whirlpool RF366PXXN2
Whirlpool RF366PXXQ0
Whirlpool RF366PXXQ1
Whirlpool RF366PXXQ2
Whirlpool RF366PXXW0
Whirlpool RF366PXXW1
Whirlpool RF366PXXW2
Whirlpool RF366PXYB0
Whirlpool RF366PXYB1
Whirlpool RF366PXYB2
Whirlpool RF366PXYB3
Whirlpool RF366PXYB4
Whirlpool RF366PXYN0
Whirlpool RF366PXYN1
Whirlpool RF366PXYN2
Whirlpool RF366PXYN3
Whirlpool RF366PXYN4
Whirlpool RF366PXYQ0
Whirlpool RF366PXYQ1
Whirlpool RF366PXYQ2
Whirlpool RF366PXYQ3
Whirlpool RF366PXYQ4
Whirlpool RF366PXYW0
Whirlpool RF366PXYW1
Whirlpool RF366PXYW2
Whirlpool RF366PXYW3
Whirlpool RF366PXYW4
Whirlpool RF366PXYZ4
Whirlpool RF367BXPW0
Whirlpool RF367BXVN0
Whirlpool RF367BXVW0
Whirlpool RF367BXWN0
Whirlpool RF367BXWN1
Whirlpool RF367BXWN2
Whirlpool RF367BXWW0
Whirlpool RF367BXWW1
Whirlpool RF367BXWW2
Whirlpool RF367LXKB0
Whirlpool RF367LXKQ0
Whirlpool RF367LXKT0
Whirlpool RF367LXKV0
Whirlpool RF367LXKW0
Whirlpool RF367LXMB0 30" Electric Freestanding Self Clean Range
Whirlpool RF367LXMQ0 30" Electric Freestanding Self Clean Range
Whirlpool RF367LXMT0 30" Electric Freestanding Self Clean Range
Whirlpool RF367LXMV0 30" Electric Freestanding Self Clean Range
Whirlpool RF367LXMW0 30" Electric Freestanding Self Clean Range
Whirlpool RF367LXSB0 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSB1 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSB2 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSB3 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSB4 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSQ0 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSQ1 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSQ2 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSQ3 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSQ4 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSS0 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSS1 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSS2 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSS3 30" Electric Ceran Freestanding Range Self Clean Oven
Whirlpool RF367LXSS4 30" Electric Ceran Freestanding Range Self Clean Oven
  #2 (permalink)
Old 02-12-2011, 09:56 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Odds are that you have a power problem.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 02-12-2011, 10:35 AM
Junior Member
Smile
thanks for the advice!! I went to pull out the stove and it sparked. Shut off the breaker and took off the cover for adding the power cable and found one side "falling" out. It was not in place like the others. Will have to get another "holder" as hooked all back up and everything works now.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana electric range (oven) wont heat up flukekiller Oven Repair (including Ranges and Cooktops) 6 12-23-2011 06:01 AM
GE Profile - range works, oven won't heat marms Oven Repair (including Ranges and Cooktops) 5 12-14-2010 01:38 PM
Viking range oven won't heat mitchelllee Oven Repair (including Ranges and Cooktops) 0 10-04-2009 12:22 PM
Maytag Gas Range-Oven will not heat up, but broiler works jnastasiuk Oven Repair (including Ranges and Cooktops) 0 12-22-2008 04:39 PM
Gas Range Oven will not heat wetheridge Oven Repair (including Ranges and Cooktops) 1 10-14-2008 07:55 AM
