| » Frigidare burner not working |
Model Number: FES365ECD Brand: Frigidaire Age: 1 - 5 years
The front left burner on my Frigidaire range is not working. It is one of two 6 inch elements on the cook top.
I took apart the the cook top and switched the 6 inch elements to see if it was the element. The element that I switched from the back to the front where it was not working also did not work. The element that was not working in the front did work in the back, so it is not the element. I think it has to be something in the wiring then. Can someone help me find the correct wiring parts to get it to work? The light in the center of the cooktop to alert you that there is a burner on does light up when the burner that is not working is turned on if that helps any. Thanks for your assistance. I am new to this forum so if there is additional information you need please let me know. Ads By Google Related Models |
Replacement parts for FRIGIDAIRE FES365ECD Frigidaire/electric Range | AppliancePartsPros.com Sounds like you need a new infinite switch (items 54 in Section 1) There are a couple different ones depending on the element it controls. The parts desk people can help you choose the correct one.
__________________
You were right. I swapped the switches since this stove has two of the same switches on it and the same switch did not work. Thanks for your help. I will order the part right away. Guessing I saved a few hundred bucks this way.
You are welcome.
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
__________________
| Display Modes | |
| Cooktop burner not working-How do I know if its the burner or switch? | joelake | Oven Repair (including Ranges and Cooktops) | 3 | 01-27-2011 07:13 AM |
| Burner not working on JEC9530ADB cooktop, is it burner or Switch? | joelake | Oven Repair (including Ranges and Cooktops) | 0 | 12-29-2010 11:07 AM |
| Dual burner has only small burner working | bobmorris13@comcast.net | Oven Repair (including Ranges and Cooktops) | 3 | 06-03-2010 11:45 PM |
| frigidare refridgerater door pannel not working | jj20375 | Refrigerator & Freezer Repair | 0 | 03-21-2010 04:38 PM |
| Frigidare freezer not working | Allan2 | Refrigerator & Freezer Repair | 2 | 12-13-2009 07:25 PM |
