Discuss
Another E6 F2 Problem
 in
I have read the Sticky thread on this problem and posted this question there (before I saw it was a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Another E6 F2 Problem
  #1 (permalink)
Old 02-11-2011, 11:04 PM
Junior Member
Doc Holliday is on a distinguished road
Default Another E6 F2 Problem
Brand: -brand-   Age: Less than 1 year
I have read the Sticky thread on this problem and posted this question there (before I saw it was a Sticky thread). My apologies if I shouldn't be double posting here. Also, thanks for helping me to get this far.
I have a Whirlpool Akkubake Model RBD275PDB12 double oven in black. LIke so many others, I got the E6 F2 code of death after Mrs. Doc used the cleaning cycle. The panel was blank, the only thing that worked was the oven light. Per directions read earlier in this thread, I disconnected the control panel/control board connector ribbon after tripping the breaker. Powered back up and waited. Finally saw a E1 F2 code. Based on what I read here, I believe this means I need to replace the control panel and not the control board.
Sometime later the E1 F2 code was replaced with the E6 F2 code again, which I believe means the control board needs to be replaced.
Can anybody confirm which I need to replace or maybe even both?
Thanks, Doc
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave heating problem and beeping problem dinop Microwave Repair 3 01-13-2011 04:27 PM
Control Problem or Computer Problem JEP Oven Repair (including Ranges and Cooktops) 3 03-22-2010 03:39 PM
Washer problem in LARGE load setting- timer problem? jagtianis Washer Repair 9 08-04-2008 02:49 AM
Thanksgiving Oven Problem.....its still a Problem! rbmattila Oven Repair (including Ranges and Cooktops) 1 03-03-2008 09:05 AM
