Discuss
Tappan range oven burnt element/replaced/ still no heat
 in
Oven (bake) element burnt in two. replacement element was installed. Still no heat. Rest of stove works fine. Oven light
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappan range oven burnt element/replaced/ still no heat
  #1 (permalink)
Old 02-11-2011, 01:56 PM
Junior Member
bandit571 is on a distinguished road
Question Tappan range oven burnt element/replaced/ still no heat
Brand: Tappan   Age: 1 - 5 years
Oven (bake) element burnt in two. replacement element was installed. Still no heat. Rest of stove works fine. Oven light also burnt out at same time as the element. Element did not trip breakers when it burnt in two. Reset in stove somewhere?
  #2 (permalink)
Old 02-12-2011, 02:39 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
A model number may help other help you.
I am assuming that the broil relay works OK.
Some units have a hi-limit thermostat in the bake element circuit.
Usually though it is the control board that is shot, if the bake relay is on that board.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappan electric range, unable to heat oven c.clowe Oven Repair (including Ranges and Cooktops) 1 01-14-2011 03:21 PM
Burnt out element on Hotpoint oven dpaunovic Oven Repair (including Ranges and Cooktops) 0 01-04-2010 06:16 PM
Oven Bake Element Replaced, still no heat hawkeye1315 Oven Repair (including Ranges and Cooktops) 3 12-22-2009 01:50 PM
Jenn-Air range oven, heating element burnt, clock won't display wuchinguo Oven Repair (including Ranges and Cooktops) 0 04-15-2008 08:41 AM
Replaced Bake Element; Oven will not heat slkcd@suddenlink.net Oven Repair (including Ranges and Cooktops) 1 01-21-2008 10:46 AM
