Discuss
maytag range
 in
We purchased a maytag range. The large front burner did not heat. We removed the old burner cracked. We replaced
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » maytag range
  #1 (permalink)
Old 02-10-2011, 04:29 PM
Junior Member
Tdiddy is on a distinguished road
Default maytag range
Model Number: MER5710AAW   Brand: Maytag   Age: 5 - 10 years
We purchased a maytag range. The large front burner did not heat. We removed the old burner cracked. We replaced the burner. Assembled the cooktop turned on the dial and the indicator light besided the switch and the heat indicator light went on immediately but burner did not heat up. We returned the burner, was given a new burner and the same problem. burner did not heat up. We went back to parts store and repair man suggested new dial swiitch. We installed the new switch, the same thing with the 2 lights but the burner did not heat up. The burner costs $100.00, the switch $50.00. We do not know where to go from here. Please help and thank you in advance.
Ads By Google
Related Models
Maytag MER5710AAW Range - S/c F/s Ele
Maytag MER5720BAF Range - F/s Std Ele
Maytag MER5720BAQ Range - F/s Std Ele
Maytag MER5721BAF Range - F/s Std Ele
Maytag MER5721BAQ Range - F/s Std Ele
Maytag MER5730AAA Range - S/c F/s Ele
Maytag MER5730AAH Range - S/c F/s Ele
Maytag MER5730AAL Range - S/c F/s Ele
Maytag MER5730AAQ Range - S/c F/s Ele
Maytag MER5730AAW Range - S/c F/s Ele
Maytag MER5730ACW Range - S/c F/s Ele
International MER5730AGW Range - S/c F/s Ele
Maytag MER5730BAB Range - S/c F/s Ele
Maytag MER5730BAQ Range - S/c F/s Ele
Maytag MER5730BAW Range - S/c F/s Ele
International MER5730BGW Range - S/c F/s Ele
Maytag MER5750AAA Range - S/c F/s Ele
Maytag MER5750AAB Range - S/c F/s Ele
Maytag MER5750AAW Range - S/c F/s Ele
Maytag MER5750BAB Range - S/c F/s Ele
Maytag MER5750BAQ Range - S/c F/s Ele
Maytag MER5750BAW Range - S/c F/s Ele
Maytag MER5751AAB Range - S/c F/s Ele
Maytag MER5751AAQ Range - S/c F/s Ele
Maytag MER5751AAS Range - S/c F/s Ele
Maytag MER5751AAW Range - S/c F/s Ele
Maytag MER5751ACS Range - S/c F/s Ele
Maytag MER5751ACW Range - S/c F/s Ele
Maytag MER5751BAB Range - S/c F/s Ele
Maytag MER5751BAQ Range - S/c F/s Ele
Maytag MER5751BAS Range - S/c F/s Ele
Maytag MER5751BAW Range - S/c F/s Ele
Maytag MER5752AAB Range - S/c F/s Ele
Maytag MER5752AAQ Range - S/c F/s Ele
Maytag MER5752AAS Range - S/c F/s Ele
Maytag MER5752AAW Range - S/c F/s Ele
Maytag MER5752ACB Range - S/c F/s Ele
Maytag MER5752ACS Range - S/c F/s Ele
Maytag MER5752ACW Range - S/c F/s Ele
Maytag MER5752BAB Range - S/c F/s Ele
Maytag MER5752BAQ Range - S/c F/s Ele
Maytag MER5752BAS Range - S/c F/s Ele
Maytag MER5752BAW Range - S/c F/s Ele
Maytag MER5754QAQ Range - S/c F/s Ele
Maytag MER5754QAW Range - S/c F/s Ele
Maytag MER5755AAB Range - S/c F/s Ele
Maytag MER5755AAQ Range - S/c F/s Ele
Maytag MER5755AAW Range - S/c F/s Ele
Maytag MER5755QAB Range - S/c F/s Ele
Maytag MER5755QAQ Range - S/c F/s Ele
Maytag MER5755QAS Range - S/c F/s Ele
Maytag MER5755QAW Range - S/c F/s Ele
Maytag MER5755QCB Range - S/c F/s Ele
Maytag MER5755QCW Range - S/c F/s Ele
Maytag MER5765QAB Range - S/c F/s Ele
Maytag MER5765QAF Range - S/c F/s Ele
Maytag MER5765QAN Range - S/c F/s Ele
Maytag MER5765QAQ Range - S/c F/s Ele
Maytag MER5765QAW Range - S/c F/s Ele
Maytag MER5765RAB Range - S/c F/s Ele
Maytag MER5765RAQ Range - S/c F/s Ele
Maytag MER5765RAS Range - S/c F/s Ele
Maytag MER5765RAW Range - S/c F/s Ele
Maytag MER5765RCB Range - S/c F/s Ele
Maytag MER5765RCS Range - S/c F/s Ele
Maytag MER5765RCW Range - S/c F/s Ele
Maytag MER5770AAA Range - S/c F/s Ele
Maytag MER5770AAB Range - S/c F/s Ele
Maytag MER5770AAQ Range - S/c F/s Ele
Maytag MER5770AAW Range - S/c F/s Ele
Maytag MER5770ACA Range - S/c F/s Ele
Maytag MER5770ACB Range - S/c F/s Ele
Maytag MER5770ACQ Range - S/c F/s Ele
Maytag MER5770ACW Range - S/c F/s Ele
Maytag MER5770BAB Range - S/c F/s Ele
Maytag MER5770BAQ Range - S/c F/s Ele
Maytag MER5770BAW Range - S/c F/s Ele
Maytag MER5770BCB Range - S/c F/s Ele
Maytag MER5770BCQ Range - S/c F/s Ele
Maytag MER5770BCW Range - S/c F/s Ele
Maytag MER5775AAB Range - S/c F/s Ele
Maytag MER5775AAQ Range - S/c F/s Ele
Maytag MER5775AAW Range - S/c F/s Ele
Maytag MER5775QAB Range - S/c F/s Ele
Maytag MER5775QAF Range - S/c F/s Ele
Maytag MER5775QAN Range - S/c F/s Ele
Maytag MER5775QAQ Range - S/c F/s Ele
Maytag MER5775QAS Range - S/c F/s Ele
Maytag MER5775QAW Range - S/c F/s Ele
Maytag MER5775QCB Range - S/c F/s Ele
Maytag MER5775QCF Range - S/c F/s Ele
Maytag MER5775QCQ Range - S/c F/s Ele
Maytag MER5775QCS Range - S/c F/s Ele
Maytag MER5775QCW Range - S/c F/s Ele
Maytag MER5775RAB Range - F/s Std Ele
Maytag MER5775RAQ Range - F/s Std Ele
Maytag MER5775RAS Range - F/s Std Ele
Maytag MER5775RAW Range - F/s Std Ele
Maytag MER5775RCB Range - S/c F/s Ele
Maytag MER5775RCF Range - S/c F/s Ele
Maytag MER5775RCQ Range - S/c F/s Ele
Maytag MER5775RCS Range - S/c F/s Ele
Maytag MER5780BAB Range - S/c F/s Ele
Maytag MER5780BAQ Range - S/c F/s Ele
Maytag MER5780BAS Range - S/c F/s Ele
Maytag MER5780BAW Range - S/c F/s Ele
Maytag MER5870AAA Range - S/c F/s Ele
Maytag MER5870AAB Range - S/c F/s Ele
Maytag MER5870AAQ Range - S/c F/s Ele
Maytag MER5870AAW Range - S/c F/s Ele
Maytag MER5870ACA Range - S/c F/s Ele
Maytag MER5870ACB Range - S/c F/s Ele
Maytag MER5870ACW Range - S/c F/s Ele
Maytag MER5870BAB Range - S/c F/s Ele
Maytag MER5870BAQ Range - S/c F/s Ele
Maytag MER5870BAW Range - S/c F/s Ele
Maytag MER5870BCQ Range - S/c F/s Ele
Maytag MER5870BCS Range - S/c F/s Ele
Maytag MER5870BCW Range - S/c F/s Ele
Maytag MER5875QAB Range - S/c F/s Ele
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Performa Range & Display do not work; oven works after turning range knob on duong_tom@yahoo.com Oven Repair (including Ranges and Cooktops) 0 06-23-2010 01:15 PM
Maytag Range danettelincoln Oven Repair (including Ranges and Cooktops) 0 05-31-2010 08:29 PM
maytag range blerd2 Oven Repair (including Ranges and Cooktops) 0 05-15-2010 09:48 AM
maytag range torbell Oven Repair (including Ranges and Cooktops) 1 01-08-2009 03:11 PM
Range / Maytag jonathan831 Oven Repair (including Ranges and Cooktops) 0 09-06-2007 05:38 PM
