| » Larger burger stays on high when turn on |
Model Number: JBP79W0B1WW Brand: GE Age: 5 - 10 years
Larger burner stays on high when it is turned on. All other 3 burgers and oven work fine. Only the large burner can not be control to lower the temperature when turned on.
GE #JBP79W0B1WW electic range. What do I need to check? What parts do I need to replace if any? Where can I order from? Ads By Google Related Models |
I could not find info on JBP79W0B1WW, the following parts breakdown is for a JBP79WB1WW
Replacement parts for General Electric JBP79WB1WW Electric range | AppliancePartsPros.com Sounds like you need a new infinite switch, Item 19 in Section 1. You will have to call them to ensure you get the correct part.
__________________
| Display Modes | |
| Element stays on high, Maytag Gemini | bwwais | Oven Repair (including Ranges and Cooktops) | 3 | 10-28-2010 01:52 AM |
| Element stays on high | MODEL1932 | Oven Repair (including Ranges and Cooktops) | 0 | 02-02-2010 01:13 PM |
| Burner stays on high setting. | billheider | Oven Repair (including Ranges and Cooktops) | 0 | 01-26-2010 09:25 AM |
| Dryer stays on high setting | Macman1107 | Dryer Repair | 0 | 01-07-2010 05:48 PM |
| GE Cooktop Burner Can't regulate temp, only stays on high | ecelebration | Oven Repair (including Ranges and Cooktops) | 1 | 01-05-2009 04:26 AM |
