Discuss
oven door latch
 in
The door latch on this Jennair oven is locked up and needs to be replaced. I know the part number
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven door latch
  #1 (permalink)
Old 02-10-2011, 11:32 AM
Junior Member
garyab is on a distinguished road
Default oven door latch
Model Number: jmw8330das   Brand: Jenn-Air   Age: 1 - 5 years
The door latch on this Jennair oven is locked up and needs to be replaced. I know the part number but don't know how to get at the part. The door latch is attached by 2 screws to a plate on the front of the oven (the plate is at the top of the oven opening when the door is open). How do I remove this plate and then replace the door latch? There are 2 screws (one of each side of the trim plate but when I remove them the trim plate still doesn't come off. Does anyone know how to get at the door latch and replace it?
I figured it out by myself so here is the approach in case someone else needs the information. That is, to remove the trim plate which holds the door latch, first remove the 2 screws at the sides of the trim plate (ie, the 2 screws holding the black buttons). Then remove the 2 screws holding the door latch to the trim piece--this allows the whole trip piece to be pulled forward and removed. The door latch assy can then be removed from the wiring harness and replaced. put back in reverse order. (as it turns out, my door latch was not defective--a loose screw left during installation had fallen into the latch mechanism and jammed it. when i removed the jammed screw it now works properly. go figure).
Ads By Google
Related Models
Jenn-Air JMW8330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9130DAB Walloven - Std Mwave Ele
Jenn-Air JMW9130DAS Walloven - Std Mwave Ele
Jenn-Air JMW9130DAW Walloven - Std Mwave Ele
Jenn-Air JMW9330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAW Walloven - S/c Mwave Ele
General Electric JN30*01 Electric range
General Electric JN30*02 Electric range
General Electric JN319WIW Electric range
General Electric JN322*01 Electric range
General Electric JN322*02 Electric range
General Electric JN322*03 Electric range
General Electric JN322*J1 Electric range
General Electric JN322*J2 Electric range
General Electric JN322J3 Electric range
General Electric JN322S2 Gas range
General Electric JN322S3AD Range accessory
General Electric JN322S3WH Range accessory
General Electric JN322V1AD Range accessory
General Electric JN322V1WH Range accessory
General Electric JN327H1AA Electric range
General Electric JN327H1BB Electric range
General Electric JN327H1CC Electric range
General Electric JN327H1WW Electric range
General Electric JN327X1AD Range accessory
General Electric JN327X1CT Range accessory
General Electric JN327X1WH Range accessory
General Electric JN330*01 Electric range
General Electric JN330*02 Electric range
General Electric JN330*03 Electric range
General Electric JN334*01 Electric range
General Electric JN334*02 Electric range
General Electric JN334*03 Electric range
General Electric JN334*J1 Electric range
General Electric JN334*J2 Electric range
General Electric JN334J3 Electric range
General Electric JN334R1 Electric range
General Electric JN334S1 Gas range
General Electric JN335R1 Electric range
General Electric JN335S1AA Range accessory
General Electric JN335S1BB Range accessory
General Electric JN335S1WW Range accessory
General Electric JN361*01 Range accessory
General Electric JN361001 Electric range
General Electric JN630*01 Electric range
General Electric JN630*02 Electric range
General Electric JN630*03 Electric range
General Electric JN634*01 Electric range
General Electric JN634*02 Electric range
General Electric JN634*03 Electric range
General Electric JN634*J1 Electric range
General Electric JN634*J2 Electric range
General Electric JN634J3 Electric range
General Electric JN634R1 Electric range
General Electric JN634S1 Gas range
General Electric JN635R1 Electric range
General Electric JN635S1AA Range accessory
General Electric JN635S1BB Range accessory
General Electric JN635S1WW Range accessory
General Electric JNM1541DM1BB Counter top microwave
General Electric JNM1541DM1CC Counter top microwave
General Electric JNM1541DM1WW Counter top microwave
General Electric JNM1541SM1SS Counter top microwave
General Electric JNM1731DMBB01 Counter top microwave
General Electric JNM1731DMCC01 Counter top microwave
General Electric JNM1731DMWW01 Counter top microwave
General Electric JNM1851DMBB01 Counter top microwave
General Electric JNM1851DMCC01 Counter top microwave
General Electric JNM1851DMWW01 Counter top microwave
General Electric JNM1851SMSS01 Counter top microwave
Last edited by garyab : 02-10-2011 at 12:25 PM. Reason: figured the problem out myself
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Door Latch Locked W/O Door hseeger Oven Repair (including Ranges and Cooktops) 7 04-04-2011 06:15 PM
Oven door will not latch greyson1 Oven Repair (including Ranges and Cooktops) 1 08-17-2010 02:34 PM
Oven door still beeping and showing as locked after replacing latch door josha3000 Oven Repair (including Ranges and Cooktops) 0 05-31-2010 07:10 AM
Kenmore oven door latch 260wildcat Oven Repair (including Ranges and Cooktops) 3 09-05-2009 03:07 PM
My Oven Door Latch Won't unlock so the door won"t close Victorine Ravenell Oven Repair (including Ranges and Cooktops) 1 11-14-2007 10:40 AM
