Discuss
Jenn-Air Electric Slide-In "on" but no burners or oven
 in
We have a fairly new Jenn-Air Downdraft Slide-In Electric Range (JES9900B) which was working fine last night until, well, basically
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Jenn-Air Electric Slide-In "on" but no burners or oven
  #1 (permalink)
Old 02-10-2011, 07:06 AM
Junior Member
ehode is on a distinguished road
Default Jenn-Air Electric Slide-In "on" but no burners or oven
Brand: -brand-   Age: Less than 1 year
We have a fairly new Jenn-Air Downdraft Slide-In Electric Range (JES9900B) which was working fine last night until, well, basically it just stopped working.
The console display still receives power but turning burners on does nothing (no light above the knob) and turning the heat on in the oven also does nothing.
I was wondering if this is a known problem? Is there a relay to replace or did it over heat and something needs to be reset?
Any help would be great. The kids are getting restless for their mac n cheese.
Ads By Google
  #2 (permalink)
Old 02-10-2011, 08:19 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
It sounds like you have a power problem.
The fan, oven light and control board all work on 120 volts, while all the heating elements require 240 volts.
Could be something else but that is where I would start.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 02-10-2011, 05:56 PM
Junior Member
Default
Hey thanks for the reply. I just pulled the stove out and noticed that the red wire looks like it melted/caught fire.
I've included a picture here.
I'm perplexed how this happened and what I can do to prevent it in the future.
  #4 (permalink)
Old 02-11-2011, 05:23 AM
Senior Expert
APP Volunteer
Default
Could be that there was a poor connection at this point on the terminal strip from day one. As current passes through a bad connection it produces heat, this degrades the connection so more heat and so on and so on till the connection fails.
Remove the wires from the connection and check them and the terminal strip.
You may need a new terminal strip.
All connectors must be cleaned up with fine emery cloth or a file.
I would not try putting a new connector on the line cord unless you have some experience. It can be difficult to get it crimped on correctly.
Also the wire has to be cut back till you get to nice clean copper.
You could replace the line cord or strip it and attach the wire directly to the terminal strip. Be sure to put a washer under the nut and over the wire so that when you tighten it up the wire does not twist.
Another possibility is to use a set screw type wire connector and connect the 3 wires directly together. Be sure it is the high temperature type (hard plastic/bakelite shell (see below). They are available at any hardware or electrical supply store.
IDEAL INDUSTRIES, INC. - Set Screw Wire Connectors
I also use antioxidant grease on the connections. In my neck of the woods it is used on all high current connections even though it was originally designed for aluminum wire. Just do not go crazy with it as it does conduct electricity.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Jenn Air double Oven Error code "Fr" Conor Oven Repair (including Ranges and Cooktops) 1 01-17-2011 08:50 AM
Kenmore oven defaults from "bake" to "broil" big blue Oven Repair (including Ranges and Cooktops) 0 11-06-2010 03:26 PM
Whirlpool 30" Slide - in Electric Oven Self Clean vusua4me Oven Repair (including Ranges and Cooktops) 0 05-05-2010 11:35 AM
oven "moaning" sound then faint "poof" sound; later, large "poof" popped door open samej71 Oven Repair (including Ranges and Cooktops) 2 03-24-2010 07:05 AM
"Probe error" on Bosch electric oven HBL 765 hbl765 Oven Repair (including Ranges and Cooktops) 2 01-28-2008 06:27 PM
