I have a frigidaire oven bottom heating element not working top element works fine found a set of aux points on thermostat that are bad I want to know if those aux. points be replaced can you buy them?
Hello, We would need the model and serial number to answer the question. Im pretty sure the points you refer come as an assembly, meaning you can not get them separate. Appliance Repair Technician:
M# MEF322WGSA S# VF82405406 These aux. points have two screws and can be removed from thermostat why would they make it like that, why not have the poins built on to the thermostat
