Discuss
Range not working - Error Codes F7 & 10
 in
Our 4 year old Kenmore Range displays both an F7 & 10 code on the touch panel. The range beeping
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Range not working - Error Codes F7 & 10
  #1 (permalink)
Old 02-09-2011, 11:49 AM
Junior Member
barrymatz is on a distinguished road
Default Range not working - Error Codes F7 & 10
Model Number: 790.46713602   Brand: Kenmore   Age: 1 - 5 years
Our 4 year old Kenmore Range displays both an F7 & 10 code on the touch panel. The range beeping can be turned off, it will clear when you touch the On/Off, then it will reappear in 15 – 30 seconds. The Range is Not operable. But the Oven works fine. A sears service technician said to replace the board part # 316442040 which I have done. However, this has not solved the problem. I am attaching a picture of the touch panel & fault codes displayed.
The serial # is NF63930191
And Model # 790.46713602
I appreciate you help,
Ads By Google
Related Models
Kenmore 790.468120  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812991  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46812993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468130  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813991  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468140  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468190  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46832100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46832101  SEARS/GAS RANGE
Kenmore 790.46832102  SEARS/GAS RANGE
Kenmore 790.46833100  DUAL FUEL RANGE
Kenmore 790.46833101  SEARS/GAS RANGE
Kenmore 790.46833102  SEARS/GAS RANGE
Kenmore 790.46834100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46834101  SEARS/GAS RANGE
Kenmore 790.46834102  SEARS/GAS RANGE
Kenmore 790.46839100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46839101  SEARS/GAS RANGE
Kenmore 790.5  HAIR CLIPPERS
Kenmore 790.60031100  ELECTRIC RANGE
Kenmore 790.60071790  ELECTRIC RANGE
Kenmore 790.60071791  ELECTRIC RANGE
Kenmore 790.60071792  ELECTRIC RANGE
Kenmore 790.60071793  ELECTRIC RANGE
Kenmore 790.60071794  ELECTRIC RANGE
Kenmore 790.60201200  ELECTRIC RANGE
Kenmore 790.60201201  ELECTRIC RANGE
Kenmore 790.60301300  ELECTRIC RANGE
Kenmore 790.61031100  GAS RANGE
Kenmore 790.61071790  GAS RANGE
Kenmore 790.61081890  FREESTANDING GAS RANGE
Kenmore 790.61081891  30" GAS RANGE
Kenmore 790.61081892  30" GAS RANGE
Kenmore 790.61081896  RANGE
Kenmore 790.61130100  ELECTRIC RANGE
Kenmore 790.61130101  ELECTRIC RANGE
Kenmore 790.61131100  ELECTRIC RANGE
Kenmore 790.61131101  ELECTRIC RANGE
Kenmore 790.61201200  GAS RANGE
Kenmore 790.61301300  SEARS/GAS RANGE
Kenmore 790.61750100  ELECTRIC RANGE
Kenmore 790.61750102  ELECTRIC RANGE
Kenmore 790.61750103  ELECTRIC RANGE
Kenmore 790.61750104  ELECTRIC RANGE
Kenmore 790.61751100  ELECTRIC RANGE
Kenmore 790.61751102  ELECTRIC RANGE
Kenmore 790.61751103  ELECTRIC RANGE
Kenmore 790.61751104  ELECTRIC RANGE
Kenmore 790.61752100  ELECTRIC RANGE
Kenmore 790.61752102  ELECTRIC RANGE
Kenmore 790.61752103  ELECTRIC RANGE
Kenmore 790.61752104  ELECTRIC RANGE
Kenmore 790.61754100  ELECTRIC RANGE
Kenmore 790.61754102  ELECTRIC RANGE
Kenmore 790.61754103  ELECTRIC RANGE
Kenmore 790.61754104  ELECTRIC RANGE
Kenmore 790.61759300  ELECTRIC RANGE
Kenmore 790.62090100  ELECTRIC RANGE
Kenmore 790.62090101  ELECTRIC RANGE
Kenmore 790.62090102  SEARS/ELECTRIC RANGE
Kenmore 790.62091100  ELECTRIC RANGE
Kenmore 790.62091101  ELECTRIC RANGE
Kenmore 790.62091102  SEARS/ELECTRIC RANGE
Kenmore 790.64090300  ELECTRIC RANGE
Kenmore 790.71000300  GAS RANGE
Kenmore 790.71001300  GAS RANGE
Kenmore 790.71002100  GAS RANGE
Kenmore 790.71002101  GAS RANGE
Kenmore 790.71004100  GAS RANGE
Kenmore 790.71004101  GAS RANGE
Kenmore 790.71010200  GAS RANGE
Kenmore 790.71011200  GAS RANGE
Kenmore 790.71012300  GAS RANGE
Kenmore 790.71014300  GAS RANGE
Kenmore 790.71030300  GAS RANGE
Kenmore 790.71031300  GAS RANGE
Kenmore 790.71032300  GAS RANGE
Kenmore 790.71042300  SEARS/GAS RANGE
Kenmore 790.71044300  SEARS/GAS RANGE
Kenmore 790.71102001  GAS RANGE
Kenmore 790.71102004  GAS RANGE
Kenmore 790.71105890  GAS RANGE
Kenmore 790.71105891  GAS RANGE
Kenmore 790.71105892  GAS RANGE
Kenmore 790.71105893  GAS RANGE
Kenmore 790.74403990  DUAL FUEL RANGE
Kenmore 790.74403991  DUAL FUEL RANGE
Kenmore 790.74403992  DUAL FUEL RANGE
Kenmore 790.74403993  DUAL FUEL RANGE
Kenmore 790.74403994  DUAL FUEL RANGE
Kenmore 790.74403995  DUAL FUEL RANGE
Kenmore 790.74503990  DUAL FUEL RANGE
Kenmore 790.74503991  DUAL FUEL RANGE
Kenmore 790.75503200  RANGE
Kenmore 790.75503201  RANGE
Kenmore 790.79012100  GAS RANGE
Kenmore 790.79013100  GAS RANGE
Kenmore 790.79014100  GAS RANGE
Kenmore 790.79019100  GAS RANGE
Kenmore 790.79112200  SEARS/GAS RANGE
Kenmore 790.79112201  SEARS/GAS RANGE
Kenmore 790.79112202  SEARS/GAS RANGE
Kenmore 790.79113200  SEARS/GAS RANGE
Kenmore 790.79113201  SEARS/GAS RANGE
Kenmore 790.79113202  SEARS/GAS RANGE
Kenmore 790.79114200  SEARS/GAS RANGE
Kenmore 790.79114201  SEARS/GAS RANGE
Kenmore 790.79114202  SEARS/GAS RANGE
Kenmore 790.79119200  SEARS/GAS RANGE
  #2 (permalink)
Old 02-15-2011, 09:00 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Barry,
This is not what I want to tell you but,
With your description, the oven works , but the cooktop doesn't, makes me wonder.
The F7 code indicates a problem with the self clean door latch assembly switches or wiring, but if that were the case, the oven would'nt work.
I can only guess, since I can't find that fail code,
Your problem is either in the burner control board, or the touchpanel/keypad assembly.
Part number: AP3963545
Part number: AP3963673
You may want to wait, and see if you get a response from someone else on the repair forum, who has more information and data.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Range keeps giving error codes E0/F3 and E4/F3 and the oven won’t work. amaldo77 Oven Repair (including Ranges and Cooktops) 4 11-21-2011 06:35 PM
Gas Range Posting Error Codes MellowMan Oven Repair (including Ranges and Cooktops) 0 01-30-2011 09:51 PM
Whirpool Electric Range error Codes: F1 and F3 CKarras Oven Repair (including Ranges and Cooktops) 1 12-21-2009 04:19 AM
Whirlpool gas range error codes Dan Wilshire Oven Repair (including Ranges and Cooktops) 1 07-08-2009 10:31 AM
Gas Range Error Codes dmulder Oven Repair (including Ranges and Cooktops) 3 09-15-2008 10:38 AM
