| » Temp Pro electric range oven doesnt work |
Quote:
In most cases and in most older ranges, an F4 error code usually indicates a bad oven temperature sensor and or a bad ERC(clock/control). We'd be better able to assist you with a proper model number. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I looked all over for the model # and I cant find one. I did see where the appliance was produced in Mexico in 1997 though. It is in a rental and I going on the information given to me by the renter. I did try the oven and it was heating up so maybe after it is on for a while it gets the F4 error message. Any thoughts on what causes that?
Quote:
On that vintage a unit, an F4 code usually indicates a bad sensor or loose connection in the temp. sensor harness, or a bad ERC/Clock. Based on the statement, that it heats for a while, I can only guess you have a loose connection in the harness,that may be expanding and loosing contact when the heat gets to the connector and so forth. You may want to inspect the connector, if it's discolored or shows signs of arcing inside the connector, you can cut the connector out and hard wire the leads with high temperature, porcelain, wire nuts. and see what effect that has on the F4 code.
__________________
| Display Modes | |
| Electric Range - loud bang - oven doesn't work | lwild | Oven Repair (including Ranges and Cooktops) | 20 | 03-17-2011 07:11 AM |
| frigidaire oven (electric) doesnt work | kyllrelf | Oven Repair (including Ranges and Cooktops) | 1 | 05-14-2010 04:58 PM |
| Kenmore Fabric Temp Switch doesnt seem to work | dtailer | Dryer Repair | 4 | 12-05-2009 03:19 PM |
| GE RANGE HOOD JV666H1SS fan doesnt work | qnewbie | Oven Repair (including Ranges and Cooktops) | 0 | 11-03-2009 11:25 AM |
| Electric Range Oven and Stove do not work | mcki272 | Oven Repair (including Ranges and Cooktops) | 1 | 10-16-2009 10:49 AM |
