Discuss
Is my Control Panel bad?
 in
OK, I'm stuck. The repairman came out and replaced the control board in my oven (whirlpool double oven/RDB275PDB14), but now
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Is my Control Panel bad?
  #1 (permalink)
Old 02-08-2011, 10:00 AM
Junior Member
GADIYman is on a distinguished road
Default Is my Control Panel bad?
Model Number: RDB275PDB14   Brand: Whirlpool   Age: 5 - 10 years
OK, I'm stuck. The repairman came out and replaced the control board in my oven (whirlpool double oven/RDB275PDB14), but now I'm being told I may need several other parts (control panel and/or smaller circuit board on the left of control board$$$ .
I'm seeing error codes F5/E1 initially then two beeps followed by error E1/F2. After reading other posts, I’m beginning to second guess this “repairman”. Any thoughts ? I really need help!!!
Ads By Google
Related Models
Thermador RDDS30
Thermador RDDS30 PRIOR TO S/N 9707
Thermador RDDS30 S/N 9707 & UP
Thermador RDDS30QW PRIOR TO S/N 9708
Thermador RDDS30QW S/N 9708 & UP
Thermador RDDS30V RANGE
Thermador RDDS30VQB PRIOR TO S/N 9707
Thermador RDDS30VQB S/N 9707 & UP
Thermador RDDS30VRS PRIOR TO S/N 9707
Thermador RDDS30VRS S/N 9707 & UP
Roper RDE22302 ELECTRIC RANGES AND OVENS
Whirlpool RDE32302
Thermador RDF30 30" DUAL-FUEL RANGE
Thermador RDF30QB PRIOR TO S/N 9708
Thermador RDF30QB S/N 9708 & UP
Thermador RDF30QW PRIOR TO S/N 9708
Thermador RDF30QW S/N 9708 & UP
Thermador RDF30RS PRIOR TO S/N 9707
Thermador RDF30RS S/N 9707 & UP
Thermador RDFS30
Thermador RDFS30 PRIOR TO S/N 9708
Thermador RDFS30 S/N 9708 & UP
Jenn-Air RDK100W MISC / ACCESSORY
Jenn-Air RDK226W MISC / ACCESSORY
Jenn-Air RDK246W MISC / ACCESSORY
Roper RDP34502 ELECTRIC RANGE AND OVEN
Whirlpool RDP34582
Amana RDS-648-UK RANGE- S/C S/I DDRAFT GAS
Thermador RDSS30 S/N 9707 & UP
General Electric RE101101 Electric range
General Electric RE101102 Electric range
General Electric RE101103 Electric range
General Electric RE102101 Electric range
General Electric RE102102 Electric range
General Electric RE102103 Electric range
Whirlpool RE123 Air-conditioner/heat pump
Whirlpool RE123A1 Air-conditioner/heat pump
Whirlpool RE123A2 AIR CONDITIONERS
Whirlpool RE123F0 AIR CONDITIONER
Whirlpool RE123G0 AIR CONDITIONER
Amana RE14010C2D ROOM AIR CONDITIONER
Amana RE14010C2D REV ROOM AIR CONDITIONER
Amana RE14010C2DR ROOM AIR CONDITIONER
Amana RE14010C2DR REV ROOM AIR CONDITIONER
General Electric RE140901 Electric range
General Electric RE1409G01 Electric range
General Electric RE1409G02 Electric range
General Electric RE141001 Electric range
General Electric RE142001 Electric range
General Electric RE144001 Electric range
General Electric RE1440G01 Electric range
General Electric RE1440G02 Electric range
General Electric RE1440H01 Electric range
General Electric RE1440H02 Electric range
General Electric RE145001 Electric range
General Electric RE1450G01 Electric range
General Electric RE1450G02 Electric range
General Electric RE1450H01 Electric range
General Electric RE1450H02 Electric range
Amana RE18010C2D ROOM AIR CONDITIONER
Amana RE18010C2D REV ROOM AIR CONDITIONER
Amana RE18010C2DR ROOM AIR CONDITIONER
Amana RE18010C2DR REV ROOM AIR CONDITIONER
Amana RE18090C2D ROOM AIR CONDITIONER
Amana RE18090C2D REV ROOM AIR CONDITIONER
Amana RE18090C2DR ROOM AIR CONDITIONER
Amana RE18090C2DR REV ROOM AIR CONDITIONER
Whirlpool RE183 Air-conditioner/heat pump
Whirlpool RE183A AIR CONDITIONER
Whirlpool RE183A1 AIR CONDITIONER
Whirlpool RE183A2 AIR CONDITIONER
Whirlpool RE183A3 AIR CONDITIONER
Whirlpool RE183G0 AIR CONDITIONER
Whirlpool RE243K0 ROOM AIR CONDITIONER
Whirlpool RE253E AIR CONDITIONER
Whirlpool RE253F0 AIR CONDITIONER
Whirlpool RE253G1 AIR CONDITIONER
Frigidaire RE32BNL1 Frg(v2) / Electric Range
Frigidaire RE32BNL2 Frg(v2) / Electric Range
Frigidaire RE32BNM1 Frg(v3) / Electric Range
Frigidaire RE32BNW1 Frg(v1) / Electric Range
Frigidaire RE32BNW2 Frg(v1) / Electric Range
Frigidaire RE34BAA3 Frg(v4) / Electric Range
Frigidaire RE34BAA4 Frg(v9) / Electric Range
Frigidaire RE34BAA5 Frg(v3) / Electric Range
Frigidaire RE34BAF3 Frg(v3) / Electric Range
Frigidaire RE34BAF4 Frg(v8) / Electric Range
Frigidaire RE34BAF5 Frg(v2) / Electric Range
Frigidaire RE34BAH2 Frg(v1) / Free Standing Electric Range
Frigidaire RE34BAH3 Frg(v5) / Electric Range
Frigidaire RE34BAH4 Frg(v10) / Electric Range
Frigidaire RE34BAH5 Frg(v4) / Electric Range
Frigidaire RE34BAL2 Frg(v2) / Free Standing Electric Range
Frigidaire RE34BAL3 Frg(v2) / Electric Range
Frigidaire RE34BAL4 Frg(v7) / Electric Range
Frigidaire RE34BAL5 Frg(v5) / Electric Range
  #2 (permalink)
Old 02-09-2011, 03:05 AM
Senior Expert
APP Volunteer
denman is a glorious beacon of light
Default
Are you sure it is a RDB.
I am assuming that this is a typo and it is actually a RBD.
Replacement parts for WHIRLPOOL RBD275PDB14 27`` BUILT-IN ELECTRIC DOUBLE OVEN STD-CLEAN LOWER SELF-CLEAN UPPER | AppliancePartsPros.com
And finally here is a service manual
KR-30 Whirlpool Electric Built-In Double Oven Service Manual - ApplianceDigest.com
You will have to join the site to download the manual but it is free and has many manuals for many appliances. A great resource for the appliance DIYer.
Is this the same as the original problem?
If yes then I also would have assumed a bad control board as your error codes are not related so it is likely that the control board is messing up.
The first code is related to the latch and the second to the key[pad.
Have you tried flipping the breaker off for 10 minutes or so to see if the board will reset.
The keypad problem may just be a bad connection.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
  #3 (permalink)
Old 02-09-2011, 06:58 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Yes, on the F2 E1 error code, that means the touch pad is unplugged, or not put back on correctly, by the last service man. So, that would be the first thing I would do. Make sure you kill the power to the oven, before you take the control panel off. It is very possible that the serviceman, due to his inexperience, did not plug in the touch pad properly. Sometimes, they can be a fight. The F5/E1 error code is a door latch issue. Tom ********************************************
  #4 (permalink)
Old 02-15-2011, 04:47 PM
Junior Member
Default
You are right, it's a RBD not RDB model. Thanks for the information. I'll post when I'm done.
Unplug the unit
Open it up
  #5 (permalink)
Old 02-15-2011, 04:50 PM
Junior Member
Default
Thanks for the information. I'll post again once I'm done.
Quote:
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board hddman Oven Repair (including Ranges and Cooktops) 0 04-26-2010 12:09 PM
Control Panel or Electronic Control - which causes blinking panel lights? MarcLCH Dishwasher Repair 1 02-25-2010 03:25 AM
GE Built-In Oven Control Panel - replace entire assembly or just control kit boschuser Oven Repair (including Ranges and Cooktops) 1 01-05-2010 03:11 AM
tranformer blew on control panel need specs for new transformer not control panel kaydog2009 Oven Repair (including Ranges and Cooktops) 0 05-11-2009 07:22 AM
Replace control panel or just control panel housing? Max Strano Dishwasher Repair 1 08-26-2008 06:02 PM
