| » keeps sparking |
Model Number: JGP637WEJ2WW Brand: GE Age: 1 - 5 years
I have a GE cooktop that has 5 burners that all spark every 2-3 seconds when they are all off.I have replaced the spark module thinking that this was the common part to all of the burners. The problem still exists after I replaced the spark module.Any suggestions??
Thank you Ads By Google Related Models |
Quote:
DK, First, check and make sure the outlet for the cooktop is a properly polarized, grounded outlet,very necessary for a spark ignition range/cooktop. Check and make sure the burner caps and bases are clean, and the caps are in the correct burner position and properly seated on the burner base. Next check the igniter wires for cracks and breaks in the insulation, and make sure no wires are pinched or shorted to the chassis, and all ground connections are good and tight. It doesn't sound like you have a bad valve igniter switch,or wiring, I'd expect a more rapid and constant spark, if it were a problem there.
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| magnetron sparking? | dvcant5 | Microwave Repair | 0 | 10-04-2009 12:42 PM |
| cooktop always sparking | egonzalez | Oven Repair (including Ranges and Cooktops) | 7 | 08-01-2009 10:31 PM |
| sparking when humid | dmbuyer | Oven Repair (including Ranges and Cooktops) | 0 | 07-24-2009 01:32 PM |
| Continuous sparking | johnmf | Oven Repair (including Ranges and Cooktops) | 0 | 05-10-2009 11:02 AM |
| GE Microwave sparking | katlatigo | Microwave Repair | 1 | 01-20-2009 09:27 AM |
