Discuss
Roper stove/oven F3 error
 in
I can't remember the model #, but my question is pretty simple. My oven gave me an error of F3,
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Roper stove/oven F3 error
  #1 (permalink)
Old 10-16-2007, 09:44 AM
kmccutcheon5 kmccutcheon5 is offline
Junior Member
kmccutcheon5 is on a distinguished road
Default Roper stove/oven F3 error
Brand: Roper   Age: 5 - 10 years
I can't remember the model #, but my question is pretty simple. My oven gave me an error of F3, the repair site said to replace the temp. sensor. I replaced it and i'm still getting the same F3 error. Should I replace the clock, or is there somthing else wrong.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-16-2007, 12:12 PM
Pegi's Avatar
Pegi Pegi is offline
Senior Expert
APP Volunteer
Pegi is on a distinguished road
Default
F3= sensor circuit, could be the sensor, wiring harness or the clock, check the harness first from the clock to the sensor...
__________________
-Serving North Central Texas and Southern Oklahoma since 1978.
www.samsservicesenter.com
  #3 (permalink)
Old 10-25-2007, 05:16 PM
Roggy Roggy is offline
Junior Member
Roggy is on a distinguished road
Default
Our Roper was doing the same thing. I have replaced the sensor & the Control Board (Clock). I don't know if yours has one or not but mine has a wiring piece that plugs between the Sensor Leads and the Control Board. It's about 3" long. It has two wires between the plugs. A tech told me I wasn't getting any continuity from one plug to the other. I tried to replace this piece but it's not available. It's not on anyone's drawings, not even Whirlpools (Roper). I ended up buying a new Thermal Cut-off (Which is one of the wires on the wiring piece) and cutting the old one out and soldering the new one in it's place. After ALL this I plugged it in and still got the F-3 code. It looks like we will be buying a new oven! About a $1500 expense for a $3 piece. If you find something else that works I'd like to know about it.
  #4 (permalink)
Old 10-26-2007, 03:42 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Roggy
Does the sensor on your oven have a quick disconnect plug? If it does get rid of it and reconnect wires using a wire nuts. It could solve the problem.
If you can, post a picture of the piece you found.
__________________
Professional appliance repair in Los Angeles, California.
  #5 (permalink)
Old 10-31-2007, 06:30 PM
Junior Member
Default
I fixed my problem!
It was the wiring piece that plugged in between the "Clock" and the Leads coming from the Sensor. One of the wires as I described between the plugs was a Thermal Resistor. I ordered one from Mousser Electronics and replaced it. I had to cut the old one out and the new one comes with crimp lugs. (Don't solder it or you'll blow the resistor again) I tried that. Good thing I ordered two. ($1.22 ea) I am beginning to think the problem started when we had the oven go through a "Self Clean". The high temperature must have blew the resistor. kmccutcheon5, does your oven have one of these wiring pieces? If so It may be your problem. It has a different plug on each end so you can't wire it direct to the "Clock".
  #6 (permalink)
Old 10-31-2007, 07:14 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Good job!
__________________
  #7 (permalink)
Old 12-18-2007, 01:07 PM
tmswartz tmswartz is offline
Junior Member
tmswartz is on a distinguished road
Default Same issue w/F3 error
Greetings to everyone!
While researching the F3 error on my Roper model# B9458B0 oven I came across this thread.
We have the same issue; I have disconnected the top panel and found the short pigtail coming from the clock to another wire pair leading into the top/back of the oven. One side of the pigtail has a thermistor, both wires read 0 ohms when measured plug to plug. Is this correct? Also, the temperature sensor disappears into the back of the oven, how can I disconnect it from what it is plugged into? Should I be able to measure any resistance across the wires at the end of the sensor to determine whether it is defective or not?
Thanks in advance for your expert input!
tmswartz
  #8 (permalink)
Old 12-18-2007, 01:56 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The oven temperature sensor resistance suppose to be about 1100 Ohms at the room temperature.
Locate the two wires plug at the control board, remove the plug and measure the resistance.
Make sure there is a good connection at the plug.
In order to replace the oven temperature sensor and, especially to check the sensor wire harness, the oven has to be removed from the cabinet.
If there is nothing wrong with the sensor, then the control board has to be replaced.
- The part number for the oven temperature sensor is AP3130719
- The part number for the control board is AP3104626
- Here are the break down diagrams and the wiring diagram for the Roper
oven Model B9458B0
Good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Error Codes Admin / APP Team Oven Repair (including Ranges and Cooktops) 55 Yesterday 07:43 PM
roper gas oven Kswick313 Oven Repair (including Ranges and Cooktops) 3 12-19-2007 06:42 AM
stove top works/clock on/oven controls dead jrob Oven Repair (including Ranges and Cooktops) 5 10-12-2007 07:29 PM
stove top works/clock on/oven controls dead jrob Oven Repair (including Ranges and Cooktops) 4 09-20-2007 10:31 AM
Ceramic Cooktop slide-in oven/stove EVdelRsoario Oven Repair (including Ranges and Cooktops) 1 09-19-2007 01:48 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
