Discuss
cannot regulate heat in the oven
 in
i cannot regulate the heat in the oven. it burns steadily at a blistering temperature. could it be the themostate
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » cannot regulate heat in the oven
  #1 (permalink)
Old 02-08-2011, 08:59 AM
Junior Member
gergilein is on a distinguished road
Default cannot regulate heat in the oven
Brand: -brand-   Age: More than 10 years
i cannot regulate the heat in the oven. it burns steadily at a blistering temperature. could it be the themostate or the dial. thanks for helping me with this problem! gerhard
  #2 (permalink)
Old 02-09-2011, 09:09 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Yes, it could be, and most likely is a bad temperature control/ thermostat.
You failed to mention wether it was a gas or electric range, and a proper model number would give us a lot better opportunity to advise you.
On rare occasions, I have found Knobs loose or forced onto a shaft in the wrong position, causing the temperature to be higher than the setting indicated, you probably should check the knob first.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Temperature Control will not Regulate enspector Oven Repair (including Ranges and Cooktops) 1 07-12-2010 05:17 AM
Burner does not regulate heat i81too Oven Repair (including Ranges and Cooktops) 2 06-24-2009 01:25 PM
Oven does not regulate the temperature lizlopeza Oven Repair (including Ranges and Cooktops) 1 03-24-2009 08:28 PM
1954 Tappan Deluxe Oven Temp Will Not Regulate alboyee Oven Repair (including Ranges and Cooktops) 0 03-24-2009 09:55 AM
