My oven won't heat. The burners are fine. Tried ALL the troubleshooting that was in the guide -- nothing. Oven is less then 5 years old. Hope part is under warranty.:(
Most warranties are only for a year, so it probably won't be under warranty.
Chances are it's the control board, valve or ignitors. If you have an ohm meter you can check these yourself or call a tech for service.
Nat
