Discuss
OVEN WILL NOT IGNITE (but igniter glows)
 in
I have a Kenmore stove that has a problem with the oven. The tenants who use the stove told me
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » OVEN WILL NOT IGNITE (but igniter glows)
  #1 (permalink)
Old 02-07-2011, 06:44 PM
Junior Member
dennis728 is on a distinguished road
Default OVEN WILL NOT IGNITE (but igniter glows)
Model Number: 362.72205891   Brand: Kenmore   Age: 5 - 10 years
I have a Kenmore stove that has a problem with the oven. The tenants who use the stove told me it started to take longer and longer for the stove to warm up and finally it just didn't do anything.
The igniter glows a nice bright red when the oven knob is turned on but no gas is sent to the burner. The burners on top of the stove work fine.
It is a simple stove with no electronics other than the clock. I replaced the gas valve but still no gas. I did get a new thermostat and wired it up as it is part of the front oven switch but again no results.
FYI: Rather than take the time to completely remove the switch and feed the thermostat through the stove into the oven chamber I just connected the two wires from the old switch to the new one without it being secured to the stove. I was able to turn on the stove and have the igniter glow a nice red but since no gas came out I assumed the problem was something else and connected the wires back to the present switch. Would it have mattered if it wasn't screwed and secured in place?
The fact that I was able to turn the igniter on gave me the impression that it worked but was not the problem.
Any ideas on what the problem could be or what is left to replace?
Your suggestions are very welcome.
Ads By Google
Related Models
Magic Chef 3621WPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621WRW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3621XRW RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XPA RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XPW RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XRA RANGE- F/S CONT CLEAN ELE
Magic Chef 3624XRW RANGE- F/S CONT CLEAN ELE
Amana 36261 REF - SXS/I&W
Kenmore 3626101190 GAS RANGE
Kenmore 3626101191 GAS RANGE
Kenmore 3626101192 GAS RANGE
Kenmore 3626101194 GAS RANGE
Kenmore 3626101195 GAS RANGE
Kenmore 3626101196 GAS RANGE
Kenmore 3626101197 GAS RANGE
Kenmore 3626101890 GAS RANGE
Kenmore 3626101891 GAS RANGE
Kenmore 3626101892 GAS RANGE
Kenmore 3626101894 GAS RANGE
Kenmore 3626101895 GAS RANGE
Kenmore 3626101896 GAS RANGE
Kenmore 3626101897 GAS RANGE
Kenmore 36261020101 GAS RANGE
Kenmore 36261020102 GAS RANGE
Kenmore 36261020103 GAS RANGE
Kenmore 36261021890 GAS RANGE
Kenmore 36261021891 GAS RANGE
Kenmore 36261021892 GAS RANGE
Kenmore 36261021893 GAS RANGE
Kenmore 36261021894 GAS RANGE
Kenmore 36261028890 GAS RANGE
Kenmore 36261028891 GAS RANGE
Kenmore 36261028892 GAS RANGE
Kenmore 36261028893 GAS RANGE
Kenmore 36261028894 GAS RANGE
Kenmore 36261061690 GAS RANGE
Kenmore 36261101000 ELECTRIC RANGE
Kenmore 36261101001 ELECTRIC RANGE
Kenmore 36261108000 ELECTRIC RANGE
Kenmore 36261108001 ELECTRIC RANGE
Kenmore 36261111699 KENMORE GAS RANGE
Kenmore 3626111190 GAS RANGE
Kenmore 3626111191 GAS RANGE
Kenmore 3626111192 GAS RANGE
Kenmore 3626111193 GAS RANGE
Kenmore 3626111194 GAS RANGE
Kenmore 3626111195 GAS RANGE
Kenmore 3626111196 GAS RANGE
Kenmore 3626111197 GAS RANGE
Kenmore 3626111198 GAS RANGE
Kenmore 36261118699 KENMORE GAS RANGE
Kenmore 3626111890 GAS RANGE
Kenmore 3626111891 Free Standing, Gas
Kenmore 3626111892 GAS RANGE
Kenmore 3626111893 Range (gas)*
Kenmore 3626111894 Range (gas)*
Kenmore 3626111895 GAS RANGE
Kenmore 3626111896 GAS RANGE
Kenmore 3626111897 GAS RANGE
Kenmore 3626111898 GAS RANGE
Kenmore 36261120101 GAS RANGE
Kenmore 36261120102 GAS RANGE
Kenmore 36261120103 GAS RANGE
Kenmore 36261120104 GAS RANGE
Kenmore 36261121890 GAS RANGE
Kenmore 36261121891 GAS RANGE
Kenmore 36261121892 GAS RANGE
Kenmore 36261121893 GAS RANGE
Kenmore 36261121894 GAS RANGE
Kenmore 36261121895 GAS RANGE
Kenmore 36261121896 GAS RANGE
Kenmore 36261128890 GAS RANGE
Kenmore 36261128891 GAS RANGE
Kenmore 36261128892 GAS RANGE
Kenmore 36261128893 GAS RANGE
Kenmore 36261128894 GAS RANGE
Kenmore 36261128895 GAS RANGE
Kenmore 3626121190 GAS RANGE
Kenmore 3626121191 Free Standing, Gas
Kenmore 3626121192 GAS RANGE
Kenmore 3626121193 GAS RANGE
Kenmore 3626121194 GAS RANGE
Kenmore 3626121890 GAS RANGE
Kenmore 3626121891 GAS RANGE
Kenmore 3626121892 GAS RANGE
Kenmore 3626121893 GAS RANGE
Kenmore 3626121894 GAS RANGE
Kenmore 3626125190 KENMORE GAS RANGE
Kenmore 3626125191 GAS RANGE
Kenmore 3626125192 GAS RANGE
Kenmore 3626125193 GAS RANGE
Kenmore 3626125890 GAS RANGE
Kenmore 3626125891 GAS RANGE
Kenmore 3626125892 GAS RANGE
Kenmore 3626125893 GAS RANGE
Kenmore 36261741000 ELECTRIC RANGE
Kenmore 36261741001 ELECTRIC RANGE
Kenmore 36261742000 ELECTRIC RANGE
Kenmore 36261742001 ELECTRIC RANGE
Kenmore 36261748000 ELECTRIC RANGE
Kenmore 36261748001 ELECTRIC RANGE
Kenmore 36262020300 GAS RANGE
Kenmore 36262020301 GAS RANGE
Kenmore 36262021300 GAS RANGE
Kenmore 36262021301 GAS RANGE
Kenmore 36262492000 ELECTRIC RANGE
Kenmore 36262492001 ELECTRIC RANGE
Kenmore 36262780100 ELECTRIC RANGE
Kenmore 36262780101 ELECTRIC RANGE
Kenmore 36262780102 ELECTRIC RANGE
Kenmore 36262780103 ELECTRIC RANGE
Kenmore 36262781000 ELECTRIC RANGE
  #2 (permalink)
Old 02-08-2011, 05:00 AM
Senior Expert
APP Volunteer
kayakcrzy will become famous soon enough
Default
Replace the ignitor. The ignitor seems to be glowing bright, but it is not. If the ignitor is not glowing bright enough, It will not open the gas valve. The shear fact that the ignitor glows, tells me that the control is good, and so is the gas valve. Because if either one ogf them would be bad, the ignitor would not come on. Tom ********************************************
  #3 (permalink)
Old 02-08-2011, 05:13 PM
Junior Member
Default
Thanks! I just ordered that part and it really is the only part left that I have not replaced that controls things.
  #4 (permalink)
Old 02-08-2011, 05:25 PM
Senior Expert
APP Volunteer
Default
That will do it!! Tom ********************************************
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven doesn't always ignite Jimbobup Oven Repair (including Ranges and Cooktops) 4 07-01-2010 03:29 PM
maytag gas oven boiler and oven will not ignite joe319 Oven Repair (including Ranges and Cooktops) 0 02-08-2010 06:49 AM
Oven does not ignite pghhoover Oven Repair (including Ranges and Cooktops) 0 12-17-2009 04:23 PM
Oven will not ignite gordo634 Oven Repair (including Ranges and Cooktops) 1 07-22-2008 08:58 AM
Oven does not ignite Dan Damiata Oven Repair (including Ranges and Cooktops) 0 08-09-2007 06:36 AM
