Discuss
F2 E1 error code
 in
Error code F2 E1 key pad error; had repair man come look and see what was wrong he said that
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » F2 E1 error code
  #1 (permalink)
Old 02-06-2011, 03:03 PM
Junior Member
sparker is on a distinguished road
Default F2 E1 error code
Model Number: KEMS307GBL0   Brand: Kitchen Aid   Age: More than 10 years
Error code F2 E1 key pad error; had repair man come look and see what was wrong he said that the key pad is broke, i could only get in white, biscuit and almond, my oven is black. Can i get a black or stainless steel one for Mode#KEMS307GBLO. Any help will be appreciated.
Ads By Google
Related Models
Whirlpool KEMS307GBL0
Whirlpool KEMS307GBL1
Whirlpool KEMS307GBL2
Whirlpool KEMS307GBL3
Whirlpool KEMS307GBL4
Whirlpool KEMS307GBS0
Whirlpool KEMS307GBS1
Whirlpool KEMS307GBS2
Whirlpool KEMS307GBS3
Whirlpool KEMS307GBS4
Whirlpool KEMS307GBT0
Whirlpool KEMS307GBT1
Whirlpool KEMS307GBT2
Whirlpool KEMS307GBT3
Whirlpool KEMS307GBT4
Whirlpool KEMS307GWH0
Whirlpool KEMS307GWH1
Whirlpool KEMS307GWH2
Whirlpool KEMS307GWH3
Whirlpool KEMS307GWH4
Whirlpool KEMS308GBL0
Whirlpool KEMS308GBL1
Whirlpool KEMS308GBL2
Whirlpool KEMS308GBL3
Whirlpool KEMS308GSS0
Whirlpool KEMS308GSS1
Whirlpool KEMS308GSS2
Whirlpool KEMS308GSS3
Whirlpool KEMS308GWH0
Whirlpool KEMS308GWH1
Whirlpool KEMS308GWH2
Whirlpool KEMS308GWH3
Whirlpool KEMS308SBL00 30" Built - in Electric Thermal Convection Combo Oven
Whirlpool KEMS308SSS00 30" Built - in Electric Thermal Convection Combo Oven
Whirlpool KEMS308SWH00 30" Built - in Electric Thermal Convection Combo Oven
Whirlpool KEMS375SBL0
Whirlpool KEMS375SBL1
Whirlpool KEMS376SBL0
Whirlpool KEMS376SBL1
Whirlpool KEMS376TAL0
Whirlpool KEMS376TAL1
Whirlpool KEMS376TBL0
Whirlpool KEMS376TBL1
Whirlpool KEMS376TBL2
Whirlpool KEMS376TBL3
Whirlpool KEMS376TWH0
Whirlpool KEMS376TWH1
Whirlpool KEMS376TWH2
Whirlpool KEMS377BBL0
Whirlpool KEMS377BBL1
Whirlpool KEMS377BBL2
Whirlpool KEMS377BWH0
Whirlpool KEMS377BWH1
Whirlpool KEMS377BWH2
Whirlpool KEMS377DAL1
Whirlpool KEMS377DAL2
Whirlpool KEMS377DAL4
Whirlpool KEMS377DAL6
Whirlpool KEMS377DBL1
Whirlpool KEMS377DBL2
Whirlpool KEMS377DBL4
Whirlpool KEMS377DBL6
Whirlpool KEMS377DBS2
Whirlpool KEMS377DBS4
Whirlpool KEMS377DBS6
Whirlpool KEMS377DBT6
Whirlpool KEMS377DWH1
Whirlpool KEMS377DWH2
Whirlpool KEMS377DWH4
Whirlpool KEMS377DWH6
Whirlpool KEMS377GAL0
Whirlpool KEMS377GAL2
Whirlpool KEMS377GAL3
Whirlpool KEMS377GAL4
Whirlpool KEMS377GBL0
Whirlpool KEMS377GBL2
Whirlpool KEMS377GBL3
Whirlpool KEMS377GBL4
Whirlpool KEMS377GBS0
Whirlpool KEMS377GBS2
Whirlpool KEMS377GBS3
Whirlpool KEMS377GBS4
Whirlpool KEMS377GBT0
Whirlpool KEMS377GBT2
Whirlpool KEMS377GWH0
Whirlpool KEMS377GWH2
Whirlpool KEMS377GWH3
Whirlpool KEMS377GWH4
Whirlpool KEMS377XBL0
Whirlpool KEMS377XBL1
Whirlpool KEMS377XBL2
Whirlpool KEMS377XWH0
Whirlpool KEMS377XWH1
Whirlpool KEMS377XWH2
Whirlpool KEMS377YBL0
Whirlpool KEMS377YWH0
Whirlpool KEMS378BAL0
Whirlpool KEMS378BAL1
Whirlpool KEMS378BAL2
Whirlpool KEMS378BAL3
Whirlpool KEMS378BBL0
Whirlpool KEMS378BBL1
Whirlpool KEMS378BBL2
Whirlpool KEMS378BBL3
Whirlpool KEMS378BWH0
Whirlpool KEMS378BWH1
Whirlpool KEMS378BWH2
Whirlpool KEMS378BWH3
Whirlpool KEMS378GBL0
Whirlpool KEMS378GBL1
Whirlpool KEMS378GBL2
Whirlpool KEMS378GBL3
Whirlpool KEMS378GSS0
Whirlpool KEMS378GSS1
Whirlpool KEMS378GSS2
Whirlpool KEMS378GSS3
Whirlpool KEMS378GWH0
Whirlpool KEMS378GWH1
Whirlpool KEMS378GWH2
Whirlpool KEMS378GWH3
  #2 (permalink)
Old 02-07-2011, 04:51 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
It does look like the black panel is obsolete.
With luck perhaps another person will know where to get one.
If the repair person did nothing but look at the unit and tell you what the error code means then I woyuld try the following.
F2E1 is a keypad not connected so could be just a bad connection.
I would try the following first.
1. Unplug the unit for 5 minutes or so to see if it will reset.
2. Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Error code E0 F3 firefighter1971 Oven Repair (including Ranges and Cooktops) 2 09-28-2010 04:23 PM
Error Code F3 Jjahn Oven Repair (including Ranges and Cooktops) 1 09-22-2010 04:43 PM
GE Error code f7 db sam kirk Oven Repair (including Ranges and Cooktops) 0 08-22-2010 06:15 PM
frigidaire error code F10 - not listed in your error codes Skully26 Oven Repair (including Ranges and Cooktops) 2 02-16-2010 04:29 AM
error code f1 aleo64 Oven Repair (including Ranges and Cooktops) 3 11-29-2009 06:13 AM
