| » Problem With KitchenAid Wall Oven |
Model Number: KEBV208MSS00 Brand: Kitchen Aid Age: 1 - 5 years
I have a problem with one of a pair of wall-mounted KitchenAid Pro Line convection ovens. The ovens will sound a beep when they are pre-heated to a specific temperature. My top oven, however, sounds off at a very much lower temp than was set: for example, beeping at say 250 degrees when it's been set for 400 or 475, etc.. The lower oven does not have this problem. The top oven eventually comes to the correct temp (in about 10-12 minutes) and the food is cooked just fine, at the correct time. It does mean I have to set the temp much higher, then when it beeps reset the temp to the lower, desired temp. Oven temp controls have been adjusted, but when the oven comes to the desired temp it is spot on. Any ideas?
| Display Modes | |
| Kitchenaid superba elect wall oven no heat | 96ws6 | Oven Repair (including Ranges and Cooktops) | 9 | 09-23-2012 06:38 AM |
| Kitchenaid wall oven | mtburns | Oven Repair (including Ranges and Cooktops) | 0 | 02-01-2010 06:17 PM |
| Help with KitchenAid Wall Oven F-5 Error | lovethesea | Oven Repair (including Ranges and Cooktops) | 1 | 12-09-2009 05:56 PM |
| Kitchenaid Combo Wall Oven Problem | rob_s | Oven Repair (including Ranges and Cooktops) | 6 | 10-30-2009 10:51 AM |
| Kitchenaid Double Wall Oven Error E1-F2 | iraslotnick | Oven Repair (including Ranges and Cooktops) | 14 | 12-17-2008 08:49 PM |
