| » Error code 4d21 |
Model Number: jmw8530dab Brand: Jenn-Air Age: 5 - 10 years
When broiling or baking, oven turns on begins to heat up and error code 4d21 appears. Looked this up and the problem is:
"no/low cooling fan rotation. Check connection at cooling fan. If ok, replace blower. Do not replace control." We looked with flash light and can see that the fan is blowing, however, wondering if it could be blowing at too low of rpm. If so, should we replace fan or could this be a connection problem? Is this a typical problem and how could it be a connection problem if fan is running? Ads By Google Related Models |
So, were you able to fix the problem?i have the same error code on my wall ovens. When I turn on oven to pre heat it will start to heat, then shut off and error code 4d21 appears. Feature not available. If I re set breaker several times, it will come back on and work for that time. Next time I try to use oven(s), same thing occurs. Do you know the fix?
Thanks |
| Display Modes | |
| Error code E0 F3 | firefighter1971 | Oven Repair (including Ranges and Cooktops) | 2 | 09-28-2010 04:23 PM |
| Error Code F3 | Jjahn | Oven Repair (including Ranges and Cooktops) | 1 | 09-22-2010 04:43 PM |
| frigidaire error code F10 - not listed in your error codes | Skully26 | Oven Repair (including Ranges and Cooktops) | 2 | 02-16-2010 04:29 AM |
| f4 error code? | blackwater | Oven Repair (including Ranges and Cooktops) | 1 | 02-19-2009 06:09 PM |
| F5 error code | kenro | Oven Repair (including Ranges and Cooktops) | 1 | 06-28-2008 10:06 AM |
