Discuss
Dual element or switch troubleshoot
 in
I have a glass top electric range with a dual element which only works in the 6" mode, not
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Dual element or switch troubleshoot
  #1 (permalink)
Old 10-15-2007, 05:17 PM
VincentDR VincentDR is offline
Junior Member
VincentDR is on a distinguished road
Default Dual element or switch troubleshoot
Model Number: FED367CEBA   Brand: Frigidaire   Age: 5 - 10 years
I have a glass top electric range with a dual element which only works in the 6" mode, not the larger 9" mode. this function is controlled by a rocker switch on the front panel. Please see attached URL for you site diagram location.
Model FED367CEBA
My question is; How do I access the Switch to short out the terminals so that I can test if this problem is a switch or element issue? Assuming it is the element, how do I lift the glass and replace the element?
Thanks for any help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dual Burner switch on the blink again macmaxim Oven Repair (including Ranges and Cooktops) 4 07-17-2008 02:40 PM
How To Remove The Lid Switch? Gotta Try Washer Repair 3 12-17-2007 04:10 PM
Washer lid switch janie Washer Repair 1 08-29-2007 10:29 PM
Lid Switch CAN I DO IT Washer Repair 0 07-24-2007 05:56 PM
change out the lid switch jreythomas@hotmail.com Washer Repair 1 07-20-2007 06:14 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
