Discuss
oven door stuck closed
 in
I think the oven is from 1974. The lock (for self-cleaning oven) was accidentally put on by pushing the lever
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » oven door stuck closed
  #1 (permalink)
Old 12-09-2008, 09:21 PM
Junior Member
ybbob is on a distinguished road
Default oven door stuck closed
Brand: Caloric   Age: More than 10 years
I think the oven is from 1974. The lock (for self-cleaning oven) was accidentally put on by pushing the lever to the right. When I returned the lever to the left, the door would not open. The self-clean had not been activated. An appliance repair man recommended that I run the self-clean, which I did, but it will still not open. I also unplugged the range and plugged it in again, with no results.
Ads By Google
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven Door Won't Stay Closed MATCHR3 Oven Repair (including Ranges and Cooktops) 4 09-03-2011 09:37 PM
Oven door won't stay closed d07282 Oven Repair (including Ranges and Cooktops) 0 01-11-2010 06:47 AM
FL Error Code, Door Latch Stuck Closed buccolts Washer Repair 1 10-01-2009 02:53 PM
door stuck closed with broken linkage to interlock bloomerang Microwave Repair 0 01-15-2009 06:06 AM
Oven door doesn't stay closed timbass Oven Repair (including Ranges and Cooktops) 1 05-27-2008 01:49 AM
